Computer Starts Then Shuts Off: Phenom II 550, Chieftec 560W, BFG GTS 250 OC, Kingston DDR2 RAM
SirBufor 74244 13
Why does my PC turn on briefly, shut off, and only restart after the PSU is switched off for about 30 seconds after a motherboard repair and Phenom II 550 upgrade?
The most likely causes are a CPU cooling problem, a bad connection, or a fault in the motherboard/PSU, so start by reseating the cooler with fresh thermal paste, because a poorly mounted heatsink can make the system switch off immediately [#8436818][#8434778] Check that all power plugs are firmly connected to the motherboard and GPU, and test whether the case power switch is stuck or faulty [#8434808][#8434778] Next, strip the system down to just CPU and RAM, then reconnect the other parts one by one to see which device causes the shutdown [#8439675][#8441194] Also measure PSU output voltages and, if possible, test during an OCCT load, since a weak PSU or bad rail can cause this symptom [#8437156][#8437543] If the issue remains, inspect the motherboard for faulty capacitors or other board damage [#8439675]
  • #1 8434578
    SirBufor
    Rate: 12
    I have a problem with my pc.
    after pressing the switch, the computer turns on for a moment, the fans start and everything goes out. I have to turn it off on the power supply and only turn it on after about 30 seconds, otherwise it will not turn on even for a moment. The motherboard came back from the warranty (replacement of the network card), and at the same time I bought Phenom II 550, I unlocked its cores (now it has 3 because when unlocking the fourth windows 7 it did not want to start the blue screen).
    Chieftec 560W power supply
    Card BFG GTS 250 OC 1GB
    Ram Kingston DDR2 4GB 2x2GB Slim
    Network card
    Creative Audigy 2ZS music card
    2 x 1SATA 1ATA disks
    Before replacing the prock and returning the motherboard from the warranty, there was no problem.
    Please help
    $pryciarz
    Hello!!
    Check if the cooling is well pressed to the processor, and if the switch is ok, e.g. not pressed.
    artaa
    Help: 1819
    Rate: 1700
    Of course, have you checked that everything is well connected to the MB as well as the MB and GPU power supply?
  • #4 8434987
    Szczepaniii
    Rate: 26
    I would bet on the power supply, the power supply is dry?
  • #5 8435020
    SirBufor
    Rate: 12
    Yes, I checked everything, but when I had an AMD Athlon 600+ (2x3000mhz), the cooling was cooler and this is scythe big shuriken, it should also do well, paste is arctic silver 5. Can I do an OCCT test and upload screenshots here ??
    but I forgot to add that when you try to turn on the computer (after 30 seconds) it happens the second time or the computer works normally and works all day without a problem, for example, now I write from it
    kret855
    Help: 62
    Rate: 59
    Do so, reattach the cooling of the paste to the processor, apply as much as a grain of rice because at 99% of this is the fault, put the computer on its side and check if it is the same.
    Di-Tech Usługi Informatyczne Sklep i Serwis Komputerowy
    Dąbrowskiego 1B, Świnoujście, 72-600 | Tel.: 721XXXXXX (Show) | Company Website: www.ditech.cba.pl
  • #7 8436868
    Informacja
    Rate: 26
    At first glance, I would be betting on a heating up processor.
    But the power supply may also be overloaded.
    I propose to check the parameters (power) of the new and old prock, and compare the power of the power supply to the power consumed before and after replacement.
    artaa
    Help: 1819
    Rate: 1700
    How old is the power supply, did you measure the voltage with a meter during the OCCT test?
  • #10 8438212
    SirBufor
    Rate: 12
    The power supply is half a year old
    Computer Starts Then Shuts Off: Phenom II 550, Chieftec 560W, BFG GTS 250 OC, Kingston DDR2 RAM Computer Starts Then Shuts Off: Phenom II 550, Chieftec 560W, BFG GTS 250 OC, Kingston DDR2 RAM Computer Starts Then Shuts Off: Phenom II 550, Chieftec 560W, BFG GTS 250 OC, Kingston DDR2 RAM Computer Starts Then Shuts Off: Phenom II 550, Chieftec 560W, BFG GTS 250 OC, Kingston DDR2 RAM Computer Starts Then Shuts Off: Phenom II 550, Chieftec 560W, BFG GTS 250 OC, Kingston DDR2 RAM
    The motherboard is the range790x-ud3p supports the latest 6 core phenomes and I uploaded the latest bios a week ago
    Amazingly, according to the manufacturer, Phenom 550 (current) consumes 80W and Athlon 64 X2 6000+ 125W or 90W, which is less, but I emphasize that my 550 now has 3 cores and I did not raise its voltage
    sniegulik
    Help: 5
    Rate: 9
    I had the same on the old album. It turned out that faulty capacitors on the motherboard were the culprit.
    1) Take out the CPU and memory and put them back in again. Check if it works.
    2) Unplug everything possible from the board (except CPU, memory) and switch on selectively and see what "bites".
  • #12 8439831
    SirBufor
    Rate: 12
    Sometimes it seems to me that the problem is with the music card.
    For now, yesterday I changed the paste on the prock. I have installed a new chipset cooler and nothing is normal so far
  • #14 8441598
    SirBufor
    Rate: 12
    For now I will wait because yesterday is ok for now, thank you very much for the advice ;) greetings
The user reports a problem with their PC, where it powers on briefly before shutting off. The setup includes a Phenom II 550 processor, Chieftec 560W power supply, BFG GTS 250 OC graphics card, and Kingston DDR2 RAM. After replacing the motherboard and CPU, the issue arose, despite previously functioning without problems. Responses suggest checking the cooling system, ensuring all connections are secure, and verifying the power supply's condition. Potential causes include overheating, power supply overload, or faulty components. The user has attempted to troubleshoot by reapplying thermal paste and changing the chipset cooler, with intermittent success.
