Correct Connection Order for Main Circuit Breaker, Differentials
kaysersoze 30506 4
  • #1 8145230
    kaysersoze
    Hello and welcome. I am asking you for help because I have no such knowledge.
    I have a very serious question (at least for me), because I'm looking for an answer everywhere: on the internet, I talked to "electricians" (probably pseudo) and I can't get a specific answer, everyone says something different.
    Well, what should be the order of connections of the following devices?:
    - main circuit breaker
    - differentials
    - surge protectors
    What should come first? main circuit breaker, overvoltage and then differential or in a different order?
    Parameters of my electrical installation: three-phase current, connection 16kW
    (if you could also specify what parameters the above devices should have, it will be full of happiness :) )
  • #2 8145379
    zdzisiek1979
    Help: 561
    Rate: 1254
    Main switch disconnector FR then overvoltage protector (depending on B+C or C) then RCD apparatus followed by overcurrent
  • #3 8145589
    piotr_krak
    Help: 65
    Rate: 57
    As a friend wrote more precisely:
    Main switch - as the name says, it is to be the main (first) protection;
    surge protectors
    then there may be signaling of the presence of phases
    residual current device and it is important that there is an overcurrent device behind each
    As for the parameters of these devices, each building has connection conditions and is selected in accordance with the calculations, so take a look at the appropriate paper and read it if you do not have one, you are the wrong person who asks about them.
  • #4 8145871
    retrofood
    Help: 1140
    Rate: 4797
    piotr_krak wrote:
    surge protectors
    Sometimes they need backup.
  • #5 8170126
    Elektroinstal
    And I will say that first there was overvoltage protection (especially since the protector is connected in parallel with the disconnector) then the FR followed by the RCD and only the overcurrent
