Realtek HD Audio Microphone Issue: Input Not Detected, Unmuted & Seeking Solutions
ziomeke 47146 7
  • #1 8172446
    ziomeke
    I have a problem with the Realtek HD Audio Input microphone
    It's just that when I say something, I can't be heard
    1. I don't have it muted. I checked
    I am asking for a quick answer
  • #2 8172486
    chris-s
    Help: 13
    Rate: 11
    Got all the drivers?
  • #3 8172517
    mazi0000
    Help: 32
    Rate: 109
    Check the microphone on another computer.
  • #4 8172546
    ziomeke
    I don't have another computer
    I have all the drivers installed
  • #5 8172793
    dinos83
    Help: 205
    Rate: 180
    In the realtek settings, increase the microphone volume + boost and check if you have it selected for recording.
    In the communicator, check the microphone configuration.
  • #6 8172880
    DriverMSG
    Help: 3984
    Rate: 4883
    In the Realtek panel, disable the front jack detection, if you connect the microphone there.
  • #7 8188151
    MrVovek
    You probably have the same problem as me, realtek HD already have it :P you need to turn on the boost by the microphone but of course you can't find it? He's there, just in a very strange place, don't look for him in recording, only in playback. Run realtek HD manager->mixer tab->wrench icon->press and select advanced controls->scroll with the small arrows located on the right until you find FRONT PINK IN and REAR PINK IN->there are these tiny icons with 2 dots of Advanced -> check the option : increase microphone performance. And that's probably all, just go to the windows control panel and set the appropriate volume or do the same using the realtek application in Program files\realtek\Audio\Drivers\WDM\MicCal.exe
  • #8 12521096
    pavcior
    Rate: 19
    If after installing Realtek HD Audio Drivers in Realtek HD Manager I have the microphone set and selected as default (checked with a tick) and it still does not work and it is a problem in the laptop, I will add. There could be several reasons, but I think the problem is:
    Clock bar->Speaker->select Playback devices->Speakers->Properties->LEVEL!!! and here somewhere should be our Microphone, it's probably muted.
    If I helped please message me.
The discussion revolves around issues with the Realtek HD Audio microphone, specifically that the input is not detected despite being unmuted. Users suggest several troubleshooting steps, including ensuring all drivers are installed, testing the microphone on another computer, adjusting microphone volume and boost settings in the Realtek HD Manager, and disabling front jack detection if applicable. Additional advice includes checking the microphone settings in the Windows control panel and ensuring it is set as the default recording device. Users emphasize the importance of locating the microphone boost option, which may be hidden in the playback settings rather than the recording settings.
