Nissan Navara 2006 2.5 dci: Is P0652 Error Related to Crankshaft Sensor?
arturo13 20636 14
Is P0652 on a 2006 Nissan Navara 2.5 dCi related to the crankshaft sensor, and where should I look for the fault?
No—P0652 is a low 5 V sensor reference-voltage fault, not a crankshaft sensor code [#8418245] It usually points to a missing shared 5 V supply from the ECU or a short in the wiring/sensor circuit, so check the harness and the sensors fed from that line [#8424182] Reported affected sensors include the rail pressure sensor, accelerator pedal sensor, shaft position sensor, boost pressure sensor, and air-conditioning pressure sensor [#8424182][#8422157] In one case, there was no 5 V from the computer to the rail pressure sensor and pedal sensor, and the fault was traced to the 5 V reference line [#8422157][#8439659] Another user found that the same 5 V feed went on to other pressure sensors, and a short to ground on one of them caused the problem; after removing the short, the car drove normally again [#9343384]
  • #1 8417687
    arturo13
    Rate: 103
    In the above-described car, error P0652 appears. Sensor reference voltage B - circuit low, I have a question, is it a crankshaft sensor?
    where is this honkar?
  • #2 8417714
    barubar
    Help: 35
    Rate: 188
    In the above-described car, what was it read ?
    Juras come back because we will drown here ...
  • #3 8418245
    gori92
    Help: 8
    Rate: 107
    Error P0652 - voltage reference sensor B-signal low. This is not the crankshaft sensor.
  • #4 8422157
    arturo13
    Rate: 103
    voltage reference sensor - is there any sensor in the computer that controls the 5 V voltage?
    I would add that in the car there was a 5 V voltage missing from the computer supplying the pressure sensor of the CR strip and circuit 2 of the gas pedal sensor (errors P0192 and P0222).
  • #5 8424182
    chimik1
    error P0652 means improper sensor supply: shaft position, shaft, pressure sensor in the rail, air conditioning pressure sensor, boost sensor - it may be compact beam this error may also affect the failure of the accelerator pedal sensor or any of the previously mentioned - you must check the beam from this what you described it probably caused him lack of power on the sensor in the bar and gas pedal
  • #6 8427827
    arturo13
    Rate: 103
    There is no power supply as I wrote above on the CR pressure sensor and potentiometer gas pedal path 2. So as I wrote the error appears because of the lack of 5V voltage inside the computer so I will not do anything here.
  • #7 8427982
    sc0rpion
    Rate: 42
    you fed the computer and checked the lack of voltage on the pin or just guessing that the computer does not give tension. My taste is short to mass. Unfortunately, I do not have a schematic for this car so I will not help. Car accident and now folded? if so, I would look for a damaged bunch
    Greetings
  • #8 8429311
    barubar
    Help: 35
    Rate: 188
    Is it so hard to answer, what was it read? After all, 5V is common, it's so hard to beat the beam? You have a great avatar, are you doing it? You probably do not do what you see clearly.
  • #9 8429961
    emeryt2
    Help: 717
    Rate: 2302
    Kolego, Awator, this is what I have in the konjoniarce, or in the wallet, because I do not keep up, this world is chasing !!
  • #10 8430035
    barubar
    Help: 35
    Rate: 188
    And what can I advise that se scanners have been bought and all they can do is read errors. :D
  • #11 8439659
    arturo13
    Rate: 103
    I am not guessing, I checked there is no short circuit on the installation and there is no 5V voltage from the computer
    Added after 18 [minutes]:
    What are you so smart, you think that you always know everything best, even clearly see what I'm doing? please, I'm debating farsightedness and a super glass ball. You have eyes so you see, but you prefer a deeper analysis to use.
    There are codes and what was read I do not see the difference you probably have the knowledge that you know the code equivalents for each scanner? LOL.
    You also know that 5V is common, it's also interesting because I came out of measurements that each is separate, but you know better.
    - you're probably the best here.
    Accident auto and now folded?
    I can not see that it was an accident, but I do not know the exact history, but as I wrote above, there is no short-circuit on the beam, the power from the computer does not go out.
    Added after 19 [minutes]:
    And what I can advise that se scanners have been bought and all they can do is read errors.
    you can do everything - including flicking the beam, what a smart thing
  • #12 8441207
    barubar
    Help: 35
    Rate: 188
    No, it's just resoluteness. Knowing yourself and knowing what you can do. It is also an awareness that sometimes I can not deal with something. It's very simple, if I do not understand something, I'm not going to bury it. Unless I'm doing it for myself, then I can experiment. I can even kill myself at my own request. But so as not to hurt anyone. What did you get from these measurements can write, + 5V is common, if you do not understand it, give this car to someone who will do it.
  • #13 8442659
    arturo13
    Rate: 103
    Maybe you can tell me on what basis you rated my skills and knowledge, because I'm not so smart to judge the knowledge of others after a few sentences, but you can do it. Do you write "hard to beat a bunch?", Who said it's hard, why this pretentialism, and you know in advance that I did not do it, as I did not have voltage, I drank the wires from the plug I gave 5V and errors the sensors started to work and errors They disappeared. "You probably do not do what you see clearly." can you tell me where this clarity comes from? "se scanners have been bought and all they can do is read errors." here you can also see what you think about yourself and other people. "Knowing yourself and being aware of what you can ... ... but so that you can not hurt a stranger." yes of course, I just do not know what you drink ...?
    I end this thread and I have a request, think sometimes what you write, and read your posts carefully and think about their usefulness in solving the problem that someone described, because if I judged you after this I will not say what would be the rating!
  • #14 8466747
    arturo13
    Rate: 103
    does anyone have an installation diagram for elek. engine?
  • #15 9343384
    arturo13
    Rate: 103
    An interesting situation, the same power supply (5V) goes even further to the pressure sensors and possibly the boost pressure. There was a short to ground on one of them. Although these sensors did not work, the computer did not give the error code of these sensors. After removing the short circuit, the car drives normally.
The discussion revolves around the P0652 error code in a 2006 Nissan Navara 2.5 dCi, which indicates a low voltage reference for sensor B. Participants clarify that this error is not related to the crankshaft sensor but rather to a lack of 5V supply affecting multiple sensors, including the common rail pressure sensor and the accelerator pedal sensor. The absence of this voltage is attributed to potential issues within the vehicle's computer or wiring harness. Some users suggest checking for shorts in the wiring and emphasize the importance of proper diagnostics to resolve the issue. One user shares a similar experience where a short circuit affected sensor functionality without triggering specific error codes.
