Nissan X-TERRA 4.0L V6: Identifying BANK 1 and BANK 2, P0057 Error, Heater & Catalyst Condition
autoas 73402 6
  • #1 10066234
    autoas
    Help: 571
    Rate: 3924
    Hello!
    Maybe a bit lame, and write which is bank1 and which is bank2
    And whether the error P0057 concerns damage to the heater (physically the meter is fine), or maybe the "underheated" second probe ... because the catalysts are "broken"
    Right side - ENGINE - PROBE - CATALYST - PROBE - CATALYST - COMMON END SILENCER
    Left side - ENGINE - PROBE - CATALYST (EMPTY) - PROBE - CATALYST (EMPTY) - COMMON END SILENCER
    T5
    Admin of Cars group
    Help: 1004
    Rate: 4182
    In my opinion, the row of cylinders where the first is - probe 1 bank1, probe 2 bank2.
    and similarly for the other party.
    Pawel wawa
    Help: 1262
    Rate: 4433
    Bank 1 and bank 2 are probe one on the left and right sides. As long as you have two more banks, ie 3 and 4. You will check by disconnecting the two probes on one side.
    While you have Bank 1 and 2 only with the extension (differently described Bank first, first / first right / bank first A / first bank I), this description means that you only have two banks and the differentiation between the parties. The easiest way is to unfasten the wires and deduce after mistakes.
    The T5 Nissan is a broken car in terms of descriptions, the principle of the first cylinder may not apply.
    This error does not apply to underheating of the heater, only the continuity / resistance of the circuit. The controller does not monitor the heating of the heater ;)
  • #4 10066369
    autoas
    Help: 571
    Rate: 3924
    Monitors by "judging" the current consumed
  • #5 10066371
    T5
    Admin of Cars group
    Help: 1004
    Rate: 4182
    And here you are right, it will be the fastest.
    I was modeled on junk.
  • #6 10066387
    Pawel wawa
    Help: 1262
    Rate: 4433
    You are sure that on the Nissan I have nothing to look at now, but I SEEM to check for resistance here. What is partially the same, only the simulation is a bit different ;)
  • #7 10912343
    autoas
    Help: 571
    Rate: 3924
    Hello!
    I will end this
    For V arrangement engines:
    The left or front head is Bank 1, and the right or rear head is Bank2 and the probes
The discussion focuses on identifying Bank 1 and Bank 2 in the Nissan X-TERRA 4.0L V6 engine, clarifying that Bank 1 corresponds to the left or front head and Bank 2 to the right or rear head. The P0057 error code is addressed, indicating it relates to the continuity or resistance of the heater circuit rather than physical damage to the heater itself. Participants suggest checking the resistance of the probes to diagnose issues, emphasizing that the error does not pertain to underheating of the second probe.
