Peugeot 307 2004 1.6 HDI 110HP: Sudden jerks, P0335 & P1351 errors - Crankshaft/Camshaft Sensor?
87mafia 26997 4
  • #1 17190510
    87mafia
    Hello! Peugeot 307 2004 1.6hdi 110HP While driving (there is probably no rule when-usually on a highway) interrupts. Usually when accelerating and then it even when I take my leg off the gas. As if for a split second he did not get fuel or even went out because the tachometer at the moment falls down and immediately returns to normal speed. No lights are off from the error but the computer shows error p0335 incorrect signal from the crankshaft rotation sensor and p1351 error in the control circuit of the relay for reheating not connected. Only once did it stop moving, went out and fired in three. He was spinning but he wouldn't get fuel.
    Two questions
    Can this interruption actually be just from the shaft position sensor? Or maybe a camshaft fight?
    And is it possible that something like this can happen from the map of the engine? (It was modified some time ago, slightly increased power. At first, the turbo was cut off, but it was improved and it was ok, and this interruption seems to have appeared a little later. At the beginning and now as soon as it jerk, then every now and then.
    DriverMSG
    Help: 3984
    Rate: 4883
    Yes. This is a common fault. The sensor may be damaged or incorrectly mounted.
    To begin with, unscrew it, clean the sensor and its plug (socket) - test.
    diodabg
    Level 30  
    Help: 133
    Rate: 627
    The harness may be damaged, often the case in a bale.
    Also clean the contacts at the ecu cube.
  • #4 17234745
    87mafia
    I didn't have time to go about it but finally I replaced the sensor today. The beam was ok. For now, it drives without jerking. We'll see how tomorrow the longer route because usually that's when the problems started.
  • #5 17240644
    87mafia
    On the road for now is ok so I hope after the problem. Thanks for the suggestions
