Migatronic Delta 160 – how many hours from an 8L argon bottle at 8 L/min?
wylon 123287 20
How long does an 8 L argon cylinder last for TIG welding, and what gas flow should I use?
An 8 L argon bottle filled to about 150 atm contains roughly 1200 L of gas, so at 8 L/min it will last about 2.5 hours of continuous TIG welding [#8753613] The “10 hours” people mention only makes sense at much lower flow, around 2–3 L/min, which is possible for low current work with a good two-stage reducer and a short hose [#9525401][#8763335] If you are losing too much gas at start/stop, a gas saver/optimizer can help by stabilizing the flow and reducing the initial puff and hose losses [#9532178][#9531897]
  • #1 8748750
    wylon
    Rate: 27
    As in the title, for how many hours of welding you need an 8l argon bottle (150At) in the tig method.
    Today I connected the migatronic delta 160 welder to the tig ... I'm just starting to "play" with the tig.
    I wonder how much gas (argon) is available.
    There were 145 atmospheres in the bowl, but after not the whole hour (maybe 40 minutes) from the 8l bottle. 110 atmospheres left gas flow 8 l / min 1.6 electrode and NR7 ceramics (because it was installed in the new cable), but I figured out that a lot of gas went, I read that such a bottle lasts for 10 hours, so where is the problem ?? Let me mention that the reducer by perun ..
    Could you please write me what gas flow settings for given electrodes and ceramics, and in what configurations they should be used. By design, I will be welding with an electrode of 2,4 and ceramics No. 7, is this a good connection? Of course, for welding ordinary sheets, pipes, etc. How and how is it manifested that there is too little and too much gas?
    PS. Is there a virtual course in the network or explanations (tips) about tig welding I watched videos on YouTube and read posts on various forums. But there is not everything in one place, in fact only answers to specific questions .. And there is no step by step (with photos) described what and how.
  • #2 8753544
    gpql
    Help: 17
    Rate: 38
    you can calculate
    Ar chemical symbol
    Atomic number 18
    Molecular weight 40 g / mol
    Boiling point - 185.9 ° C
    Liquid - Gas Conversion Table *
    1 liter of liquid = 0.8243 m3 of gas
    1 m3 of gas = 1.2132 liters of liquid
    1 kg = 0.5915 m3
    the cylinder contains 6 kg of argon
    6 * 0.5915 = 3.549 m3 unit 3549l with a flow of approx. 15l / min 236.6 minutes> 3.94 h calculated but usually it is not exactly 6 kg, which is shorter.
  • #3 8753613
  • #4 8753627
    gpql
    Help: 17
    Rate: 38
    That's right, but as you can see in the calculations, 1 kg is assumed, not 1 liter of liquid.
    The data comes from the gas distributor and there is 6 kg of compressed gas in the description.
    Personally, I measure the contents of the cylinder by weight, i.e. 6 kg. The pressure will be below indications and there is still 0.5 kg in the cylinder
  • #5 8753636
  • #6 8763335
    wylon
    Rate: 27
    How is it possible that they write on various forums that they have enough gas for 10 hours of welding. So they would have to have 2-4l / min gas flow, it is possible to weld at such a low flow ... ??
  • #7 9525401
    H3nry
    Level 32  
    Help: 165
    Rate: 288
    Yes, it is possible to weld with a flow as low as 2-3l / min. Low currents, "wet" handle.
    A small cylinder should last for 10 hours, but on one condition that you are using a good 2-section reducer and you have a short cable connecting to the welding machine. I recommend that you add a gas saver.
  • #8 9531288
    bori1
    Help: 11
    Rate: 74
    The Optimator ELGA is a good solution to reduce the amount of shielding gas loss. It is not a cheap solution, but after "4 months of WORK" a certain reimbursement of the purchase costs of this reducer. After a year, MIGATRONIC DELTA 160 returns. You have not written whether it is DELTA E or HF. If E, you don't have anything to buy super reducers, it remains to accept gas losses. If you have problems with DELTA, I provide warranty and post-warranty service. Website at ww.arc-serwis.pl
  • #9 9531897
    H3nry
    Level 32  
    Help: 165
    Rate: 288
    bori1 wrote:
    The Optimator ELGA is a good solution to reduce the amount of shielding gas loss. It is not a cheap solution, but after "4 months of WORK" a certain reimbursement of the purchase costs of this reducer. One year later, the MIGATRONIC DELTA 160 returns.
    Everything is correct only the cost of the purchase; /
    I recommend optimizers for PLN 100, available here http://www.spaw.info.pl/
    It is an additional single-chamber low pressure regulator. It is connected to the output of the reducer and that's it.
  • #10 9532138
  • #11 9532178
    H3nry
    Level 32  
    Help: 165
    Rate: 288
    Here is descriptive information with additional pictures: Link
    Basically stabilization of the gas flow obtained by an additional section. It is not possible for one chamber to provide a stable gas flow at the start and during the pressure drop in the cylinder. No pumping effect, comfortable operation and savings. ;)
    Some theory for dessert Link
  • #13 10999039
    orwo777
    Rate: 8
    Where in Warsaw you can fill your own 8-10L argon bottle.
    So far, I have met companies that only lease their own gas cylinders for the appropriate Air Products daily fee Air Products
    I deal with jewelry repair and I need to fill 2-3 bottles a year.
    The cost of the lease far exceeds the value of the gas purchased, and I do not want to risk my life by buying "disposable" cylinders converted from a fire extinguisher on Allegro.
    If anyone can help, please do not hesitate.
  • #14 11006015
    elektromechanik
    Help: 61
    Rate: 193
    Don't worry, just make a connector and look for a welder with argon and a large cylinder.
    He will let you go for a few zlotys and after the trouble.
    By the way, I do some TIG welding. occasionally I bought an original 8L cylinder and at the point where large cylinders are replaced, they always have 1-2 small cylinders for replacement.
  • #15 11006075
    orwo777
    Rate: 8
    I understand that it is about transferring gas from a large cylinder to a small one and this should generally work?
  • #16 11007789
    elektromechanik
    Help: 61
    Rate: 193
    It should not and must !!!!!!!!!
    This is how I pass oxygen into the 5l cylinder. It is used for the propan-butane-oxygen burner. Due to the fact that I deal with refrigeration, I use this burner quite often.
    Well, find out at the cylinder exchange point. Preferably a small one, maybe for a few zlotys. they will arrange one legalized and you will have a legal exchange without any problem.
  • #17 11008561
    Jacek1983rr
    Help: 50
    Rate: 367
    Bottles with Allegro sometimes have a counterfeit legalization, which a trained eye will recognize. As for the CO2 cylinder converted into argon, it is possible, but it must have a higher strength test. There are many such cylinders in circulation.
  • #18 13927907
    damix181
    Rate: 11
    More details on the operation of optimizers, gas consumption and the Optimators themselves can be found here
  • #19 14438526
    januss73
    Level 32  
    Help: 193
    Rate: 56
    It will heat up the cutlet a little.
    I had an idea to get rid of the "puff" at startup, which is to save expensive argon. I know that you can mount the optimator, but in my opinion it is a considerable expense for an amateur welder.
    So the idea is this. I buy a solenoid valve, such as is used inside the welding machine (cost about PLN 30), I disassemble the welder and take it out with an additional cable to control this internal valve. I install the purchased valve right behind the reducer and connect it in parallel with that from the welding machine. In this way, the welder closes the gas at the same time in the welder and behind the reducer, thanks to which any increased pressure is created only in the reducer and not in the entire hose, so "pufff" should no longer take place. What do you think about it?
  • #20 14438904
    Michelson
    Help: 82
    Rate: 305
    Maybe a good idea, but the valves would have to close at the same time. It would be best if they were the same. And the question is whether the welder will "handle" two solenoid valves at the same time.
  • #21 14441480
    januss73
    Level 32  
    Help: 193
    Rate: 56
    These valves are usually powered from 230V and pull about 50mA and are switched on by a relay, so it shouldn't be a problem. Even if just one relay will do the trick. Basically, after installing such a valve, this valve in the welding machine becomes unnecessary and it could be unplugged and the gas should be fed directly to the torch lead. Trza will order and test the valve.
✨ The discussion revolves around the usage duration of an 8L argon bottle for TIG welding, specifically with a MIGATRONIC DELTA 160 welder. Users calculate that an 8L bottle, containing approximately 6 kg of argon, can provide around 1200 liters of gas. At a flow rate of 8L/min, this translates to about 2.5 hours of continuous welding. Some users suggest that with lower gas flow settings (2-3L/min), the bottle could last up to 10 hours, provided a good two-section regulator is used. The importance of using gas-saving devices, such as the Optimator ELGA, is highlighted to reduce gas consumption. Additionally, there are discussions about the proper configurations for electrodes and ceramics, with recommendations for using a 2.4 mm electrode and NR7 ceramics for general welding tasks.
