Using Heating Oil in Vehicle: Impact on Engine, Pump & Components (Vectra B, Isuzu Engine)
piotrst08 102614 45
Can using heating oil in a Vectra B with an Isuzu diesel engine damage the engine, injection pump, or injectors?
Using heating oil will not necessarily destroy the engine, injection pump, or injectors, but it carries greater risk than compliant diesel and is illegal for road use because of the tax marking. The thread reports that its physicochemical properties can allow diesel operation, yet differences in lubricity, fuel quality, and combustion may accelerate wear or cause pump/injector problems, especially in newer high-pressure or electronically controlled systems [#904409] [#902882] Heating oil may also have poor cold-temperature behavior, with paraffin precipitation potentially clogging filters [#887565] Several users reported tens or hundreds of thousands of kilometers without failures in older diesel engines, generally stressing a reliable, clean source; one reported 50,000–60,000 km in an Isuzu 2.2D without noticeable problems [#887627] Some users added Mixol to compensate for suspected lower lubricity, but this was anecdotal and opinions about additives were divided [#887627] [#921865]
  • #31 904409
    tarnowski
    Help: 25
    Rate: 66
    Read what the Statoil company writes on this topic, this and more info available at http://www.statoil.pl/
    3. Can light fuel oil be used to drive diesel engines?
    Although the physicochemical properties of fuel oil allow it to be used to power diesel engines, however, due to tax regulations, it is tantamount to having to pay the difference in excise duty to the tax office.
    Some people write in such a way as if driving on the company's diesel has never caused any failure of the engine and accessories, and all that comes down is the fault of the fuel. I used only the legal for a long time and also replaced the injectors, my fuel filter was clogged with crap and paraffin because they changed the price to a winter one, but they were still selling the oil in summer. The engine wears out with age and normally breakdowns also happen. I will slowly try to change supplier :wink: because it's already 3.38 and I won't last a long time and either the car is pegged and I am on the bike. Or ..... None of my clients do not want to accept the argument on my part that I have to raise the prices of my services because the fuel price has become more expensive, so I have no choice:? Such a world, though somehow I am not happy about it :(
  • #32 904438
    sobi2004
    Rate: 27
    It turns out that the fuel can be poured heheheh !!!!
  • #33 904442
    sobi2004
    Rate: 27
    HZ10 wrote:
    When it comes to driving on fuel, I would not advise on new engines because it is a short life and the repair costs are huge.
    well, I drove my E-46 on fuel about 200 thousand. kilometers and nothing has broken so far, I do not add any additives, only clean fuel, assuming that the car burns about 8 l OO per 100 km, I save
    about 10 PLN after driving 200,000 I saved 20,000 PLN and this is not a small amount so that even if something dies now, the repair costs will not exceed PLN 5,000, so the bill is simple.
    I prefer to pour clean fuel than oil of unknown origin for PLN 2. dudes from aso overstated the cost of repair (unless they set up the injection pump for a new one, cost 8000pln, used 2000)
    I greet all opałowców
    read it again and think over the guy wrote well !!!
  • #34 904669
    nasu
    Help: 11
    Rate: 251
    I keep reading to confirm my thesis
    Those who run on opal know and say that it is good and even better than it is only illegal.
    Those who have never ridden fuel say that it is bad, it spoils the pump and engine.
    Let someone write to whom the fuel oil broke the engine.
  • #35 905753
    piotrst08
    damn, I still do not know what to choose, maybe someone knows how much repair may cost me (1.7 TD Isuzu engine) if there were actually components for fuel, and I also ask if someone has already died from driving on orenzada?
  • #36 905796
    Los_sandalos
    Help: 90
    Rate: 197
    Don't worry about repairs, just find out where people are filling up and are happy. Tariffs are the best informed. Good fuel is not worse than oil. You just need to know where he is "sure" and you can pour TD. A small addition of oil will not hurt, although it is probably added by a minority of those who ride the "borsch".
  • #37 908469
    nasu
    Help: 11
    Rate: 251
    I talked to a mechanic, an injection engineer said that he had not found an increase in failure rate in his regular customers who used fuel for over a dozen years.
    It used to be better OO cost 0.3ON and no one was picking on, now it's 0.7NO saving 1.20 PLN per liter, but you can drop by for a fast ride.
    http://wiadomosci.wp.pl/wid,5716756,wiadomosc...YvQa8O6%2F6%2FRAp47LogPkDmNejOTWuf5dju8Ucj4TX
    [/url]
  • #38 908519
    tarnowski
    Help: 25
    Rate: 66
    Shit, my monthly mileage is 3-3.5 thousand km. For the last 3 years, I had 2 inspections and one blockade (they were looking for someone). The probability that I will meet aliens is much higher than I will come across laps with equipment that you will want to rummage in a passenger car. Well, unless they get the info from operational sources (e.g. the Elektroda portal, or a friendly neighbor) I'm trying on now, but I'm getting closer to the decision .....
    Regards
  • #39 908600
    TomiM
    Rate: 29
    Hello, many people wrote about adding mixol to "wine", opinions on this issue are divided (as in the automotive industry)
    The negation of this is the statement that the mixer ignites too quickly, destroying the nozzles of the injectors - the opinion of truck users.
    Because winter is approaching, what do you think about the use of fuel additives, specifically diesel. Last winter, my friend froze in the bottle.
  • #40 914107
    sobi2004
    Rate: 27
    And why add additives will freeze something for you and there will be a drama !!!
  • #41 920785
    piotrst08
    I found a workaround for the problem :) It's enough to find a guy who drives trucks or in PKS, because I know that they trade crude oil for 2.5 (today's price). I did it and I hope I will buy from him as much as possible and he will continue to trade!
  • #42 921865
    Ptaku69
    I drove over 50 kkm on Red Bull and nothing bad happened, I added Mixol in the proportion 1: 100 and a double dose of fuel enhancer for the winter (so that no paraffin precipitates).
    I had no problems, but only profits: cheap speed and more power :) The car started without any problems at - 17 * C
  • #43 926854
    makarena
    Help: 7
    Rate: 30
    I know two Opel Vectra 2.0 DTL and VW Passat 1.9 TDI cars.
    Both were served with orangeade and the owners had no problems with them, and these are not old diesels, so don't be afraid to just pour as much as possible :wink:
  • #44 928065
    sobi2004
    Rate: 27
    And I will honestly say that I already have enough cars with gas installation ... and that they are supposed to be lower costs ,,, supposedly! ..but gas goes up, gas goes up, gas goes up, oil goes up .. so there is Heating Oil left! At the moment I'm trying to find a good OO distributor and I will ride a red bull, what's up and these statements are as many as users ... I'm not going to crash too much faster, considering that I won't be driving a new diesel .. !!!!
  • #45 928694
    ger56
    Help: 16
    Rate: 33
    brother-in-law does a lot of kilometers on opaline and nothing happens, in fact he does not recommend a new car, an additional condition is oil from a reliable, proven source, it is best to ask taxi drivers
  • #46 928856
    totem
    Rate: 20
    it makes no sense in Poland to consider whether heating oil is burned. there is no gas station in Poland that would not cheat. in Poland there is a mafia legally registered only under official and like orlen etc. oil is so bad at the station and it will not tell you what kind of crap it is
    I wish you all good journey :)
The discussion centers around the use of heating oil in vehicles, specifically addressing concerns about its impact on engine components, such as pumps and injectors. Opinions are divided; some users report no negative effects after extensive use of heating oil, while others warn of potential damage due to differences in combustion properties and lubrication. Key points include the legality of using heating oil, the importance of fuel quality, and the recommendation to add oil additives like Mixol to mitigate risks. Users share personal experiences, noting that older engines may tolerate heating oil better than newer models, and emphasize the need for reliable fuel sources to avoid issues like clogging and corrosion.
TL;DR: 200 000 km of real-world driving on heating oil “it is ILLEGAL” [Elektroda, HZ10, #889522; avatar, #887465] shows engines can survive, but fines reach 30 000 PLN and winter gelling remains a risk.
Why it matters: This FAQ helps Polish diesel owners weigh cost savings against mechanical and legal exposure.
• Price gap: Diesel 3.35 PLN/L vs heating oil 2.30 PLN/L (-31 %) [Elektroda, piotrst08, post #902063] • Typical density: Diesel 0.83 kg/L, heating oil 0.86 kg/L [EN 590; CEN/TR 15367] • Reported trouble-free distance: Up to 200 000 km [Elektroda, HZ10, post #889522] • Legal risk: Fine up to 30 000 PLN + excise back-payment [Polish Excise Act, 2020] • Winter flow limit: Heating oil can gel at –5 °C; winter diesel resists to –20 °C [Statoil Tech Note, 2018]
Is using heating oil in a passenger car legal in Poland?
No. Heating oil is taxed for stationary use. Running it on public roads violates the Excise Act and can trigger fines up to 30 000 PLN, fuel confiscation and vehicle impound [Polish Excise Act, 2020; Elektroda, avatar, #887465].
Which engines cope best with heating oil?
Mechanical-pump diesels (e.g., Isuzu 1.7 TD, MB OM617) handle it well because clearances are larger and pressures lower [Elektroda, piotrst08, post #887397] Common-rail, TDI PD, CDI, DCI and HDI units run tighter tolerances; a failed injector can cost 2 000 PLN each [Bosch Service Data, 2021].
How do roadside inspectors detect red fuel?
Polish and German police draw samples from injection pump returns, not the filler neck, to spot red dye traces [Elektroda, Los_sandalos, post #887722] The dye stains filters for weeks, so a single refill won’t hide evidence.
What are early signs of heating-oil-related failure?
Hard starting when hot, rising fuel consumption and black exhaust haze indicate pump or nozzle wear. In severe cases the engine may not start at all, as seen after long red use followed by diesel refilling [Elektroda, Vonkermit, post #902882]
How can I safely switch back to normal diesel?
  1. Run the tank near empty.
  2. Fill with high-quality EN 590 diesel and a lubricity additive.
  3. Change the fuel filter after 500 km to remove residual dye. This limits clogging and dilutes red traces below detection threshold.“A little patience saves a pump,” notes a Bosch technician [Bosch Service Data, 2021].
Where can I buy cleaner heating oil?
Users recommend vetted truck depots or taxi cooperatives; avoid roadside micro-stations often accused of water and debris contamination [Elektroda, Los_sandalos, post #888934] Always ask for a recent delivery slip and store it; quality varies widely.
What if I accidentally filled with heating oil once?
One-time use seldom harms hardware. Top up with regular diesel to dilute, add a lubricity enhancer, and keep receipts to show intent if inspected. Dye can remain in filters up to 1 000 km [Statoil Tech Note, 2018].
