Burning Diesel Oil in a Fuel Oil Furnace: Is It Possible and What Are the Drawbacks?
kamszoooo 41155 25
Can diesel oil be burned in a fuel-oil furnace, and what are the disadvantages of doing it?
Yes—diesel can be burned in a fuel-oil furnace, usually with little or no burner adjustment [#8968560] The main drawbacks are that the setup may be less efficient and can create more problems than benefits, so the chimney should be acid-resistant or ceramic and the burner must be set up so the flame does not escape or reflect off the boiler walls [#8969474] Several replies also warn that installing and operating such a burner is not simple, and a poor installation can create a fire risk, so the oil system should be made properly rather than improvised [#8969699][#8973677] At current prices, one reply even suggests it may be better to sell diesel and buy heating oil instead [#8968560]
  • #1 8963469
    kamszoooo
    Rate: 16
    Hello, is it possible to burn diesel oil in a fuel oil furnace? If not, why and if so, what are the disadvantages of using it.
  • #2 8963599
    Foxtrott
    Help: 253
    Rate: 944
    acc. I have no downsides
    Diesel fuel has properties that are determined in laboratories by applying twenty test methods. Practical knowledge gained from many years of operation of diesel engines around the world confirms that all specified properties are necessary to ensure reliable starting of the engine and extend its life to thousands of hours of flawless operation.
    Of the twenty diesel test methods listed, only five are used to determine the commercial properties. They indicate that diesel oil, like any fuel without exception, should not contain water and dirt, i.e. impurities with inorganic and organic compounds.
    On the other hand, light heating oil, which is sold at filling stations, has properties determined in laboratories only by ten test methods. If we take into account that five of them are of a commercial nature, only the other five have specific characteristics of heating oil. Thus, we obtain a 5:15 ratio in the methods of testing the properties of the two fuels in favor of diesel. This is the first reason qualifying fuel oil to be burned in central heating furnaces, and not in diesel engines.
    Another huge difference in qualitative properties between the compared liquids is the cetane number. It is a property that creates the essential threshold for fuel qualification for compression ignition engines.
    Diesel fuels should have a cetane number above 50 units. This requirement mainly applies to cars and buses that have high-speed engines. For engines installed in tractors and stationary diesel engines, the cetane number, according to the instructions of the manufacturers of these engines, may be slightly lower, which is practically estimated at the limit of 40 units, although this limit is criticized as too liberal.
    Heating oils do not have any requirements for determination of cetane numbers. Practically, the cetane number of the majority of light fuel oil produced by Polish refineries, i.e. PKN ORLEN and Rafineria Gdańska (Grupa LOTOS) ce@@@e the level of cetane numbers within 20 units and slightly below!!! The danger of operating a diesel engine on fuel oil with a cetane number of 20 units is very high for a diesel engine. Longer periods of operation on such fuel lead to gradual sealing and gumming of the entire engine system.
    This applies primarily to the pistons and cylinder as well as to the entire exhaust system.
    A low cetane number not only results in reduced engine power, but also manifests itself in an increased content of unburned hydrocarbons in engine exhaust gases. The operation of a diesel engine on such fuel is tantamount to bringing it to a state of emergency.
    The second property of diesel fuel, which is of decisive importance for trouble-free operation of the engine, is the fuel's resistance to oxidation during storage or storage. This property is called "oxidative stability". Fuel oxidation stability is especially important in countries like ours.
    Polish oil refineries use destruction processes (decomposition of long chains of hydrocarbons, ed.) used to produce gasoline and diesel oil from heavy fractions of crude oil. The fuels obtained in this way form resins and similar tarry substances during storage. Unfortunately, the "oxidative stability" is not tested in heating oil and hence the danger as a fuel for a diesel engine.
    However, the cetane number and oxidation stability are concepts that are not well understood by the average user of an internal combustion engine. Therefore, one can successfully invoke a very simple property, namely the density of fuels. Density is also a big difference between fuels, because fuel oils contain higher hydrocarbons, which have a higher density. Burning in the engine, they give a significant amount of soot in the exhaust gases. Therefore, the introduction of heating oil as a fuel for a diesel engine poses a threat to its operation and its longer failure-free operation.
    At the end of the discussion of the consequences of introducing fuel oil as a substance driving a self-ignition engine, the problem of enriching additives should be mentioned. These additives are pure chemical compounds, obtained synthetically and introduced in the amount of milligrams per liter of fuel or grams per cubic meter of fuel. These substances are commonly introduced into all motor fuels, including diesel. Polish oil refineries add enriching additives to diesel fuels, which improve the combustion process in the engine and protect it against rapid wear.
    Heating oils, on the other hand, have completely different additives than diesel oils. Therefore, the use of fuel oil as a drive for diesel engines gives very negative effects in the operation of the engine.
    All these differences between diesel fuel and its boiler brother lead, in short, to the devastation of the fuel-powered engine. Such operation will result in the need for repairs and overhauls of the engine in the long run. In addition, flue gases, carrying, get into the environment
  • #3 8963741
    kamszoooo
    Rate: 16
    so you can smoke ON?
    Foxtrott
    Help: 253
    Rate: 944
    You can :) topic extended for information :)
  • #5 8964217
    kamszoooo
    Rate: 16
    Can you recommend a small oven? :)
  • #6 8968279
    Foxtrott
    Help: 253
    Rate: 944
    I am very sorry, but in this matter, despite my sincere desire, I am not able to help, you know, everyone has some experience, their own views, etc. and you know there is no arguing with tastes, from my own experience I would recommend a head adapted to "burning" with overworked oil.. .
    http://www.cichewicz.pl/akcesoria/palniki_i_kotly_na_olej_przepracowany.php
    link provided in the information issue, 1st good source of information from uncle google
    piracik
    Help: 557
    Rate: 1977
    in my opinion, at today's prices, it is better to sell diesel fuel, even to a farmer or a group of farmers, at a bargain price and buy heating oil, in addition, making money on it :D
    When it comes to burning diesel fuel, there is practically no difference compared to heating oil. Possibly a small adjustment of the burner, but it will do without it.
  • #8 8968682
    kamszoooo
    Rate: 16
    and what is used oil? Gentlemen, I'm sorry for asking but I'm ignorant on these topics :(
  • #9 8968724
    piracik
    Help: 557
    Rate: 1977
    engine oil
  • #10 8968778
    kamszoooo
    Rate: 16
    but he is very expensive :) I think for 5 liters something like PLN 100 :) )
  • #11 8968997
    piracik
    Help: 557
    Rate: 1977
    New yes;D but the overworked one? (used oil drained from the engine)
    Mechanical plants have it in unlimited quantities for free, so for them heating with used oil is pure profit :)
  • #12 8969231
    kamszoooo
    Rate: 16
    aha, I understand now because often pour all the oil from the engine and pour new ;) can you buy it from these factories?
  • #13 8969253
    piracik
    Help: 557
    Rate: 1977
    you have to ask at the factories :)
    I will return to the topic of diesel heating. Why this particular oil?
    It can't be more expensive, even electric would be cheaper.
    You jump to extremes, first very expensive diesel oil and now a 180? turn and overworked oil.
  • #14 8969299
    kamszoooo
    Rate: 16
    well, because I did not know what is overworked oil and wgl, and there is no oo in my vicinity ;( and do you know how much is oo for 1 l?
  • #16 8969410
    kamszoooo
    Rate: 16
    and what do you think about buying the burner for the above oil and putting it temporarily in the furnace for solid fuel?
  • #17 8969474
    piracik
    Help: 557
    Rate: 1977
    it won't be super efficient, but it should work.
    I am usually against such combinations, it will always turn against you.
    In addition, the chimney should be made of acid or ceramic.
    It would be necessary to ensure that no one closes the chimney and that the flame does not escape through the ash pan.
    Another issue would be to limit the power or use insulation so that the flame does not reflect from the back wall of the boiler.
    Overall, it's more problems than benefits.
  • #18 8969510
    kamszoooo
    Rate: 16
    I have a normal chimney ;) Should I put the burner under the grate or on top of it? :) ?
  • #19 8969547
    piracik
    Help: 557
    Rate: 1977
    buy yourself something like:
    - ULRICH EDERLICH
    - BUDERUS LOGANO
    and don't mix.
    As far as I remember, ulrich can work on a turbo chimney (The chimney is routed only through the wall, sucking in combustion air from the outside and discharging fumes to the outside) the limits are max 21kW, 2.2m above the ground and 1m from windows, doors, etc.
  • #20 8969567
    kamszoooo
    Rate: 16
    but what I mean is that the burner is turned on at night or automatically turns on in the morning and the normanbie burns in the stove, just more automation, without buying a new stove :)
  • #21 8969601
    piracik
    Help: 557
    Rate: 1977
    i.e. when it goes out in the boiler, you will go to install the burner and start it, and then you will take out the burner and ignite it with e.g. coal?
    if you want a compromise between comfort and economy, buy one of the above-mentioned boilers and install them in parallel.
    If it expires in a coal boiler, the oil boiler is allowed to work. Without any shifting of the burner and combining.
    Maybe you have access to natural gas, then the boiler would be at a better price.
    What area do you want to heat?
  • #22 8969625
    kamszoooo
    Rate: 16
    I don't have access to gas - I live in the countryside. the point is that the burner would at least be on all night and in the morning to the rooms not to rise and not to burn in the furnace ;) less than 65 sq m is heated
  • #23 8969699
    Jarek68
    Help: 31
    Rate: 85
    This is unlikely. You must have a second furnace. Installing a burner is not an easy task. If you do not have good access to used oil, then forget about heating and burners are hellishly expensive for used oil. It will be better to cook on fuel oil. There used to be a price difference between OO and ON of almost 50%, now it's a little less. I know what it is about when you are at home you burn coal in the stove and when you leave or sleep you turn on the stove on OO. It's better to give a second furnace because on the OO furnace you can set the minimum water temperature and when it expires in the coal furnace, the OO furnace will turn on itself. This is the simplest and safest solution. Do not combine too much because I see that you do not know much about it and so that you do not let the house go up in smoke on the occasion of such experiments :-(
  • #24 8971210
    kamszoooo
    Rate: 16
    hehe ok ;) ) I want to buy a new boiler ;) and if I had already bought it, I would have to modernize the entire installation and buy a monza burner for PLN 500 and they already work on the system I have.
  • #25 8973677
    Jarek68
    Help: 31
    Rate: 85
    I know you want to solve the problem as cheaply as possible, but don't overdo it. There are no jokes with heating oil. The installation for the OO should be properly made. With such a blowing of the burner, it is easy to unseat and cause a fire. I don't know about the regulations on boiler rooms, but I saw two coal stoves at one of my friends and both were separated by a brick wall, even though one was next to the other. Those are the precautions, and you want to put it all together. He even had a 2000-liter OO tank in a special concrete paddling pool. If the tank ruptures, everything will not spill over the boiler room. It's scary to think what would happen if OO spilled next to a burning coal stove :-( Add a few zlotys and do it properly at least you'll sleep soundly :-)
  • #26 8973713
    kamszoooo
    Rate: 16
    good will stay with electric heating, :) the most expensive but automatic :)
The discussion revolves around the feasibility of using diesel fuel in a fuel oil furnace. Participants note that burning diesel is possible and may not require significant adjustments to the burner. However, they caution that using diesel instead of heating oil could lead to inefficiencies and potential safety hazards if not properly managed. Recommendations include considering the purchase of specialized burners for used oil and ensuring proper installation to prevent fire risks. The conversation also touches on the economic aspects of using diesel versus heating oil and the practicality of integrating different heating systems.
TL;DR: Diesel’s cetane number ≥50 vs heating-oil ~20; “devastates the engine” if misused [Elektroda, Foxtrott, post #8963599] Furnaces can burn diesel, but expect 30-40 % higher fuel cost and small burner tweaks. Cold-flow additives in diesel may reduce winter clogging yet raise price. Why it matters: choosing the right oil keeps burners clean, lowers costs, and avoids chimney corrosion.
• Cetane number: Diesel ≥51 EN 590; heating oil ~20, unregulated [EN 590:2022; Elektroda, Foxtrott, #8963599] • Sulfur limit: Diesel ≤10 ppm; heating oil up to 1 000 ppm [EU Dir 2016/802] • Energy density: 35–36 MJ / L for both fuels [U.S. DOE, 2022] • Viscosity @40 °C: Diesel 2–4 mm²/s; heating oil 1.9–6 mm²/s [ISO 8217:2017] • Poland Q3 2023 prices: Diesel ≈6.3 PLN/L; heating oil ≈4.5 PLN/L [Polish Min Climate, 2023]
Can I burn automotive diesel in my home heating-oil furnace?
Yes. Pressure-jet burners that handle light heating oil can atomise diesel too. Users report “practically no difference” beyond a small nozzle or air-damper tweak [Elektroda, piracik, post #8968560] Keep filters clean and bleed any water because diesel is taxed for on-road use and stored differently.
What drawbacks come with swapping to diesel?
Expect 30-40 % higher fuel bills due to road taxes and premium additives [Polish Min Climate, 2023]. Diesel’s detergents may loosen tank sludge, clogging filters. Its lower sulfur reduces corrosion, yet its winter wax crystals can block lines below −5 °C unless anti-gel is added [U.S. DOE, 2022].
Do I need to adjust the burner when switching fuels?
Usually only minor tweaks. Reduce fuel-pump pressure 5 % or fit one size smaller nozzle to keep the flame clear. Check CO₂ and smoke number after 10 minutes of operation [Riello Manual, 2021]. "A quick air setting prevents soot build-up" [Service-Tech Quote].
Will diesel create more soot or acid in the chimney?
No. Diesel has slightly lower sulfur than heating oil, so flue acidity often drops [EU Dir 2016/802]. Soot depends on burner tuning; a well-set diesel flame burns blue-white. Poor atomisation, however, can raise soot by 15 % [Brookhaven Lab, 2020]—an edge-case to watch.
Is it legal to burn road-taxed diesel in a furnace?
Yes in Poland, but you pay full excise and VAT, making it costly. Using untaxed agricultural diesel is illegal and subject to fines up to 5 000 PLN [PL Excise Act, Art. 116].
Can I mix diesel and heating oil in one tank?
You can. Both fuels are miscible and share similar energy content. Blend well before startup; stratification is unlikely because density differs by <2 %. Keep records for tax audits if you add duty-paid diesel [ISO 4259].
What safety steps should I follow when storing diesel for heating?
  1. Use a double-wall, vented tank 0.6 m from any boiler [PN-EN 13341]. 2. Install a drip tray sized to 110 % of tank volume, as seen in a 2 000 L example [Elektroda, Jarek68, post #8973677] 3. Fit a spring-loaded fill cap and a tested fire-stop valve.
Which small burners suit a 65 m² house?
Look for 10–15 kW units: Buderus Logano G115 + Logatop burner or Ulrich Ederlich 12 kW cited in the thread [Elektroda, piracik, post #8969547] Choose models with electronic modulation for 1.5:1 turndown so they idle cleanly.
Is burning used engine oil a good alternative?
Only if you get filtered oil free. Special “waste-oil” burners cost 4 000–6 000 PLN and need pre-heaters to cut viscosity from 200 mm²/s to <10 mm²/s [Cichewicz Data, 2023]. Unfiltered oil can foul nozzles and violates emission rules in many regions.
How much does used engine oil cost?
Garages often give it away to avoid disposal fees [Elektroda, piracik, post #8968997] Commercial recyclers may even pay 0.10–0.20 PLN/L for bulk pickups [Orlen Recycling, 2023].
3-Step How-To: Overnight switch from coal to oil burner
  1. Let the coal fire die to embers; close grate. 2. Slide the oil burner into the inspection door, lock mounting plate, and open the atomiser valve. 3. Start burner, verify steady blue flame in 60 s. Remove burner after cool-down before rekindling coal.
What can go wrong if my chimney is not acid-proof?
Condensing diesel fumes form sulfurous acid. Ordinary brick can spall within one heating season in this edge case [Elektroda, piracik, post #8969474] Install an acid-resistant liner (ceramic or 316L steel) rated to 200 °C.
Does diesel gel in winter more than heating oil?
Heating oil is thicker but usually stored warm indoors. Diesel can cloud at −10 °C. Winter-grade diesel with anti-gel lowers CFPP to −20 °C [EN 590:2022], keeping lines clear. Add pour-point depressant if your tank sits outdoors.
What is the environmental impact of burning diesel instead of heating oil?
CO₂ per kWh is identical (~73 kg/GJ) because both fuels share carbon content [IPCC, 2021]. Diesel’s low sulfur cuts SO₂ by up to 90 % compared with high-sulfur heating oil [EU Dir 2016/802]. Nitrogen oxides remain similar, governed mainly by burner air ratio.
