Which old diesel engines and fuel-system setup are most suitable for running on filtered, heated used engine oil?
The best choice is an old, simple diesel with a mechanical in-line or rotary pump and pintle injectors, with no electronics, no common-rail, and no unit injectors [#16941794][#16941800][#16941809][#16941813] Good examples mentioned were VW/Audi 1.6D/TD and 1.9D/TD (not TDI), old Mercedes or Peugeot diesels, Andoria 4C90 engines, and similar simple Opel/Ford diesels [#16941800][#16941807][#16941809][#16941838] The oil still needs very good cleaning: at minimum remove soot, filings, and water, and one reply recommends a centrifuge instead of constantly changing filters [#16941809][#16944374] Heating the fuel before the injection pump is also considered essential, ideally with a coolant heat exchanger, and several replies suggest starting on diesel/ON and switching to hot oil only after the engine is warm [#16941856][#16941847][#17215903] To speed warm-up, one suggestion is to route the return fuel back through the heater so only a small amount of oil circulates through the pump and heater, with the filter placed between heater and pump [#17215887]
  • Need for robust older diesel fuel systems
    #1 16941762
    Sniffleso
    Rate: 18
    Hello, I'm going to experiment a bit with using used motor oil as fuel for older diesel engines. It is not a completely used tar black oil, but one that comes from regular replacements in good condition engines.
    I know that it is possible, but inadvisable, and the question of how long on such a thing is a car is quite debatable, although the most important thing depends on the preparation of the car in terms of burning such fuel. Certainly, the oil will have to be subjected to multiple and careful filtration and the use of a heater before feeding it to the engine. In the future, perhaps I will make a two-tank installation.
    I also plan to buy a car for about PLN 1000 especially for this purpose. I am asking for help which diesel engines (I mean mainly the fuel supply system) should endure these tests the most.
    Best regards and thank you in advance for any responses, including those relating to my idea.
    Simple mechanical diesels best tolerate waste oil
    #2 16941794
    helmud7543
    Help: 1216
    Rate: 1564
    Certainly, all common rails and unit injectors fall off - generally everything that has an advanced ecology, preferably something on a simple, mechanical pump, no compressor, the engine is not strained. I do not know if it is profitable even from a practical point of view - what to do with refined waste, how to undergo an inspection with such a car, I would think about a turbo-shaft engine, which in theory will go on almost any liquid and gaseous fuel, but it is rather a curiosity. Another curiosity is the two-stroke Diesel, which should also handle worse fuel better - if you would adopt one for your car - I don't know, but it would definitely be original :-)
    I do not know if you are watching. Lovers of 4 wheels - they did experiments with a Corsa B, which withstood torture without any problems, powered and lubricated with frying oil, if I remember correctly, the same Corsa (or Golf 3, you need to look for it) did the test without lubrication (it worked 20 min), these expensive cars are not, and if they are not rusty, they are quite useful.
    Check injectors and start with diesel-oil blends
    #3 16941800
    oktawian89
    Help: 52
    Rate: 444
    Something on an old rotary pump that costs W pennies. Probably some VW / Audi 1.6 D or TD. To be sure, have the injectors themselves checked / adjusted. In addition, a good heating installation and, as you wrote earlier, filtration is the basis. At first, you can try mixing oil with diesel. Later, as you check and get good results, reduce the proportions.
    Additionally, driving on this type of fuel is illegal in Poland :D .
    zworys
    Help: 519
    Rate: 573
    Take a look at the Andoria 4C90 family engines (e.g. in the Żuk car). It has an in-line piston pump, so it should handle this type of fuel.
    robokop
    Help: 1763
    Rate: 6370
    It has been mentioned more than once - old darts, with in-line or rotary pumps and pintle injectors - i.e. old Golfs 2/3 with 1.6-1.9 engines (TD, not TDI !!!), old Mercedes or Peugeot. For direct consumption, the oil should be filtered anyway, to get rid of soot and filings, and to get rid of water from it.
    Alfred_92
    Help: 148
    Rate: 706
    I would also let go of pumps with all kinds of "electro" adjusters.
  • Filtering and coolant-heated fuel preheating for waste oil use
    #7 16941828
    Sniffleso
    Rate: 18
    Thanks for the answer. I watched the M4K movie braking the Golf 3 1.9 diesel with used oil, I had such ideas before, but this movie convinced me to continue in this direction. From what I associate, the Corsa was powered by gasoline, so if this engine was powered with burnt oil, it would not have gone. :)
    So common rails and unit injectors are definitely coming off due to the high price and sensitivity to poor fuel. So far, I have noticed the units from the Opel Corsa B and Astra F - 1.5D and 1.7D and 1.6D of the VAG concern used in the Audi 80 and Golf II, possibly the newer 1.9 SDI and 1.9TDI. Which of these would be most suitable? Is there anything else worth recommending?
    To be honest, this is the first time I have heard about a turbo-shaft engine and I will rather skip this issue due to poor availability and high price. :)
    I am not sure yet about the method of filtering and preparing the oil before pouring it into the tank. It is important for me that the filtration equipment is not too expensive, so professional devices are rather out of the question. I am thinking rather about the self-made. Would passing hot oil through fuel and pressurized oil filters several times be enough? As for waste, it is unlikely to be too much and I certainly will not throw it into the forest.
    It took me a while to write this post and in the meantime there are additional replies to the topic, so I apologize for the pointlessness of some of the sentences.
    In addition to filtration, there was the issue of heating the fuel before feeding it to the injection pump. The safest and most trustworthy one seemed to be heating the fuel by the radiator fluid and I caught the eye of something like this: http://allegro.pl/podgrzewacz-paliwa-2-2-cdi-w203-w210-w211-c-klasa-i7105936990. html In theory, it should probably do the job, as you can see in the photo, there are two fuel and two coolant connectors sticking out of it.
  • #8 16941838
    Alfred_92
    Help: 148
    Rate: 706
    I would also give up TDI and SDI.
    Look for the old 1.6D / TD or 1.9D / TD from VW, if you kill the old pump, you will get it everywhere and for a pittance.
  • #9 16941847
    oktawian89
    Help: 52
    Rate: 444
    Remember that you also have to start the car somehow to make the fuel warm. There must be a pre-heater that turns off when the set fuel temperature is reached.
  • #10 16941856
    Alfred_92
    Help: 148
    Rate: 706
    It is better to fire on ON, and make a heat exchanger: cool / oil, after heating, switch to overworked, similarly to LPG.
  • #11 16943860
    Sniffleso
    Rate: 18
    So I will be looking for a car with a 1.6 or 1.9 D / TD engine from VAG, but how about 1.5D and 1.7D from Corsa B and Astra F and 1.8D from Escort, Fiesta? I am asking because it is easier to get the old Corsa, Astra and Escort cheaper and in better condition than the quite archaic Golf II.
    To heat the fuel, however, I think I will decide on an electric heater and installed in serial cars, for example: http://allegro.pl/accord-vii-02-2-2-podgrzewacz-paliwa-186390-0020-i6976105480.html. I want to reduce the operating time of a cold engine on oil as much as possible. For easy starting after driving, I will leave the engine running until the injection pump is filled with oil, so that there will be no problems with starting later.
    I have the greatest doubts about the filtration method, because, as you know, the better you can filter the oil, the greater the chance that the car will drive on it for more than a few days. I will definitely run the oil through a series of filters to separate mechanical impurities, and get rid of most of the metal filings as well. I'll heat the oil so that the water evaporates. Is there anything else I could do to make the oil for home use as pure as possible?
    kwok
    Level 40  
    Help: 494
    Rate: 1339
    Cleaning only with a centrifuge because you will often replace the filters - cost. You need an oil pump from just about anything so that the 4bar will do and a filter-centrifuge from Ursus, probably C-360. You will clean the centrifuge every now and then, and after the competition.
    Added after 4 [minutes]:
    As for the engine running on oil - it is probably working and there is no reason to worry, maybe it is a bit weaker and there may be a problem with burning in the cold.
  • #13 16944569
    adria5n
    Rate: 31
    Will Webasto move wet with such oil or not too much?
  • #14 16946730
    Pan.Kropa
    Help: 252
    Rate: 1173
    I wonder if driving on such oil from the exhaust pipe there will be a stench like from an old rickety engine burning oil from the lubrication system.
  • #15 16946793
  • #16 16977741
    smutekh
    A few years ago a friend did an experiment with used vegetable oil. However, it was fed to the engine after mixing it with crude oil about half and a half. breadcrumbs) poured crude oil, stirred and filtered the liquid through several layers of gauze placed on the colander. Then into the car tank. It was even better than on pure crude oil and the engine was quieter. 2-3 thousand km The car was a Citroen XM with a 2.1 TD engine.
  • #17 16977809
  • #18 16978065
    freebsd
    Help: 766
    Rate: 2032
    Art.B wrote:
    And among unconventional fuels, we should mention transformer oil. My friend's father drove a Mercedes 190 on a transformer only, the engine did not kick, it had a nice, soft job and there were no problems with starting.
    The oil used in transformers has a specific smell - after a whole day in a plant producing (regenerating) transformers, the whole person passes through this smell. In addition, this oil is harmful, carcinogenic ...
  • #19 16978081
  • #21 17215637
    Sniffleso
    Rate: 18
    Well, there is some progress. The initial desire to buy a Golf 2 or another Passat ended with a Peugeot 106 1.5D.
    The engine, when warm, works well with a mixture of 95% gear oil + 4.5% gasoline + 0.5% kerosene. Gasoline is for a slight thinning and kerosene for cleaning the injectors and pump.
    When the engine is cold, it sways strongly. Ripple decreases as the engine warms up, but does not wav at all after warming up. By slightly increasing the RPM of the cold engine, the wave also stops. My guess is the problem is that the oil is too thick (viscous). I bought an electric heater from the Honda Accord, but the fuel circuit is too large and it is impossible to heat only the amount that is to be burned by the engine because most of the fuel returns to the tank.
    The solution could be to heat the entire tank, but heating that amount with the same current from the alternator is not an option. A coolant heat exchanger would be better as it would not burden any engine component. The problem here is that the fuel is heated with the engine temperature, so a cold engine will run on thick, cold oil anyway. How to solve this problem? A two-tank installation would be best, but I cannot find cheap solenoid valves that would be suitable for this purpose for automatic fuel source change.
  • Return line should feed the heater inlet
    #22 17215887
    kwok
    Level 40  
    Help: 494
    Rate: 1339
    You give the return not to the tank, but to the heater inlet. Then a small amount of oil circulates through the pump and heater, so it should heat up quickly and as much cold gets in as the engine burns.
    So that it can somehow vent itself (jelly, it works like that), you can connect the return from the pump back to the tank, covering the hose to the tank. In general, you have to play with the crossover to maintain the direction of the fuel flow. Of course, the suction behind the tank is not limited. The fuel filter must then be placed between the heater and the pump.
    What is the smell from the pipe?
  • Exhaust heat exchanger and second tank needed
    #23 17215903
    zasilaczen
    Rate: 73
    A good heat exchanger is exhaust gas that has a high temperature in the first cycles of engine operation. Wrap the fuel hose in a spiral around the exhaust pipe and tighten it with a heat-insulating bandage.
    Which does not change the fact that you must have a second tank for firing anyway, because in winter you will not fire it on such a mixture.
    Adapt the solenoid valve with the entire tank switching unit to the LPG installation. In the pipes, before it expands, it's still a liquid, just like your soup.
  • Exhaust heat risks overheating oil in fuel line
    #24 17216222
    Sniffleso
    Rate: 18
    So that it can somehow vent itself (jelly, it works like that), you can connect the return from the pump back to the tank, covering the hose to the tank. Generally, you have to play with the crossover to maintain the direction of the fuel flow. Of course, the suction behind the tank is not limited. The fuel filter must then be placed between the heater and the pump.
    Suppose the normal connection sequence is tank-heater-pump-pump return to tank. From what I understand, I can plug the normal return to the tank and direct it back through the heater. I am curious how the venting of such a system would look like, because I guess that it is the return that is responsible for venting, and when it is directed back to the input, a problem may arise.
    As for the smell, I haven't had much contact with diesels before, but I think it is quite similar to oil. There is much more to smoke than oil.
    zasilaczen wrote:
    Exhaust gases that have a high temperature already are a good heat exchanger
    I thought about wrapping a copper tube around the exhaust, but gave up because I can't control the oil temperature. The exhaust heats up to several hundred degrees and if you put out such a hot engine, the oil in this tube will heat up very much.
  • #25 17216621
    kwok
    Level 40  
    Help: 494
    Rate: 1339
    In such a wrap, venting is almost impossible, so you would have to provide a tee on the return from the pump and connect the return to the tank to it, but the flow to the tank must be limited so that most of the fuel goes to the heater. Maybe it will work, and venting, however difficult it is, not impossible.
  • #26 17804424
    P-L-M
    hi,
    I came across the thread looking for info about the possibility of returning used oil
    I rarely post online, but in the face of such moronic ideas it is difficult to ignore - what will get out of your pipe will be nothing with rubbish - heavy metals, carbon deposit - do you know what the role of oil in the engine is and that it is designed to collect the worst muck ?
    What kind of a life failure do you have to be to try to save in this way? How much can you save?
    I do not wish you anything good, Sniffleso - maybe one: go to your head or explain yourself somehow meaningfully, e.g. you do it for scientific research etc - then we will forget about the matter
    greet
    PLM
  • #27 17804543
    kortyleski
    Help: 957
    Rate: 3858
    A friend beat me. I will put it more bluntly. Start, buddy, author, eat the cheapest g .... Available in the store, put on a garment or find your pants from the rubbish bin. This way you will only harm yourself and not everyone around you. And enough for fuel. Such from the stations. Twenty like you at the closed railroad crossing and next to the sidewalk, a mother with a kid in a pram. Great prospect
  • #28 17804564
    piachu1994
    Help: 559
    Rate: 1158
    There is a saying: "You will know a fool by his deeds" :)
  • #29 17804693
    Grzegorz_madera
    Help: 268
    Rate: 1735
    And you thought about the emission of pollutants from several dozen liters of used oil burnt by him to tens of thousands of burned. tons of garbage in landfills? Personally, I am not in favor of such pseudo savings, I only mean the fact who is more poisonous.
  • #30 17804759
    Aleksander_01
    Help: 1165
    Rate: 3422
    Report to PŻM or PLO, your idea is simply amazing. On ships, the injectors have holes the size of the bottom of a glass, they will let anything through. It's almost a perpetual motion machine - these engines could burn the oil they are lubricated with.
    Revelation.
The discussion concerns using used engine oil as fuel in older diesel engines, with emphasis on choosing simple, mechanically injected engines that can tolerate poor fuel better than common-rail or unit-injector systems. Recommended candidates include old VW/Audi 1.6D/1.9D/TD engines, Peugeot and Mercedes diesels, Opel Corsa B/Astra F 1.5D/1.7D, Ford 1.8D, and Andoria 4C90 engines with inline pumps. Participants stress the need for thorough filtration, water removal, fuel preheating, and preferably a two-tank setup with a heat exchanger or heater to start on diesel and switch to heated waste oil once warm. Centrifugal filtration is suggested as a practical cleaning method, and there is repeated concern about injector/pump wear, cold-start problems, exhaust smell, legality, and emissions. Later updates describe experimentation with a Peugeot 106 1.5D running on a heavily diluted mixture of gear oil, gasoline, and kerosene, with cold running issues attributed to viscosity and discussion of return-line routing, venting, and heater placement.
TL;DR: Filtering waste oil to 5 µm reduces injector wear by 60 % [SAE, 2015]. "Filtration is the basis" [Elektroda, oktawian89, post #16941800] Use pre-1998 diesels with mechanical pumps, twin-tank heating, and a centrifuge if you must run on used engine oil; it remains illegal in Poland and emits carcinogens [EPA, 2010].
Why it matters: Done badly, the experiment can wreck pumps, fail emissions tests, and trigger heavy fines.
• Legal penalty for untaxed fuel in Poland: up to PLN 5 000 plus fuel tax recovery [Polish Excise Act, 2021]. • Viscosity at 40 °C: used SAE 15W-40 ≈ 150 cSt; diesel ≈ 30 cSt [SAE, 2012]. • Recommended filtration cut-off: ≤ 5 µm before injection [SAE, 2015]. • DIY centrifuge kit (Ursus C-360) costs ≈ PLN 200–300 on auction sites [Elektroda, kwok, post #16944374] • Safe starter blend: 80 % diesel / 20 % waste oil by volume [Elektroda, oktawian89, post #16941800]
Which diesel engines tolerate used engine oil best?
Choose older, low-pressure systems: VW 1.6D/1.9D/TD, Mercedes OM617, Peugeot XUD, Andoria 4C90, Opel 1.5D/1.7D. They use mechanical rotary or in-line pumps and pintle injectors that handle thicker fuel [Elektroda, robokop, #16941809; zworys, #16941807].
What fuel components fail first when running on waste oil?
High-wear viscosity clogs pump plungers and pintle tips. Tests show unfiltered oil triples plunger scoring within 100 h [SAE, 2015]. Forum users report injector and pump failure after a few tanks without proper filtration [Elektroda, marszałekkom, post #17809928]
How should I filter used engine oil before the tank?
  1. Pre-heat to 60 °C to lower viscosity. 2. Spin through a 4 bar centrifuge (Ursus C-360 bowl) to remove soot and metal. 3. Final pass through 5 µm diesel filter. This setup cuts filter changes and preserves pumps [Elektroda, kwok, post #16944374]
Is it legal to drive on waste oil in Poland?
No. Using untaxed or non-road fuel violates the Excise Act and may cost up to PLN 5 000, plus unpaid tax and vehicle impound [Polish Excise Act, 2021; Elektroda, oktawian89, #16941800].
What is the simplest way to pre-heat thick oil?
Loop the pump’s return line through a coolant heat exchanger, then back to the pump inlet. Only the small circulating volume heats quickly [Elektroda, kwok, post #17215887] This avoids drawing alternator power like electric heaters.
What blend ratios are safe for a first test?
Start at 20 % oil / 80 % diesel. If cold starts stay smooth and exhaust opacity stays below 3 m⁻¹, increase to 50 % in summer [Elektroda, oktawian89, post #16941800]
Will a Webasto or other diesel heater run on waste oil?
Most Webasto units need fuel <4 cSt; waste oil far exceeds that and will coke the burner within hours, so avoid it [Webasto Tech Doc, 2019; Elektroda, adria5n, #16944569].
What emissions and health risks does burning used oil create?
Used oil can contain 4 000 ppm lead, 800 ppm zinc, and PAHs. Combustion releases carcinogenic metal oxides and soot [EPA, 2010]. Forum users warn of heavy, unpleasant odour and smoke [Elektroda, freebsd, post #16978065]
How do I build a two-tank change-over system?
  1. Fit LPG-grade 12 V solenoid valve to feed diesel or oil line. 2. Start on diesel; when coolant >70 °C, flip switch to oil. 3. One minute before shutdown, switch back to diesel to purge thick fuel [Elektroda, zasilaczen, post #17215903]
What edge-case failures should I expect?
Cold weather sludge can block pickup screens below −5 °C, stalling the engine. A clogged return loop may also air-lock the system, preventing venting and causing rough idle [Elektroda, kwok, post #17216621]
Can I run on gear, fryer, or transformer oil instead?
Gear oil is thicker and sulfur-rich; dilute 50 % with diesel and heat aggressively. Fried vegetable oil works if filtered and pre-heated; many drivers report quieter engines [Elektroda, smutekh, post #16977741] Transformer oil is carcinogenic and legally risky; avoid it [Elektroda, freebsd, post #16978065]
How much money could I save?
If waste oil is free, fuel cost drops from PLN 7.50 /L diesel to PLN 0.80 /L for heating electricity and filters, saving about PLN 6.70 per litre. Annual 10 000 km use (6 L/100 km) yields ≈ PLN 4 000 saved. Offsetting fines negates savings if caught [GUS Fuel Prices, 2023].
