Fixing Broken Optical Fiber: Methods, Connectors & Where to Buy for Surveillance Cameras
zhu 46790 38
How can I reconnect a broken optical fiber in a surveillance camera line, and what is this type of field connector called and where can I buy it?
The practical repair is to use a proper fiber splice/field connector or, better, have the line fusion-spliced by a fiber-optics technician; you also need to identify whether the fiber is single-mode, multimode, or graded-index first [#905821][#903474] The connector described in the thread is a gel-filled splice/push connector, similar to AMP Corelink, where the fiber is stripped, cut cleanly, inserted, and then closed and protected in a muff [#905821][#903474] For a field solution, users pointed to 3M and similar systems, and said Polish supplier Lanster sells such connectors, though often only in packs of 6 or 12 [#901596][#908441] A clean, perpendicular cut is critical; scissors will not work, and the fiber must be prepared properly before insertion [#908441][#907621] For checking the repair, a simple lamp is not enough for single-mode fiber; an OTDR/reflectometer is the proper tool, but it is expensive [#919982] In practice, several replies advised that hiring a specialist for a few hundred PLN is cheaper and more reliable than buying the tools for a one-off repair [#903474][#907621]
  • #31 905821
    dariuszm2
    Help: 181
    Rate: 69
    Hi.
    I didn't really bother to read all the posts.
    As for the connection, the first step would be to determine what kind of fiber it is (single-mode, multi-mode, gradient). The hardest thing to connect is single-mode. A welder would be the most suitable tool, but there are connectors (can't remember the name at the moment) - it looks like a straw filled with gel, which gives you the option of a "push" connection, but you need a knife to trim.
    After connection, such a joint must be protected against moisture in the so-called muff.
    As for the attenuation, at the splice (single-mode) the attenuation of the connector must not exceed 0.15 dB, at the pigtail (someone mentioned it) 0.5 dB
    As for how to make a joint on a pole, the so-called technological stocks allowing to remove such a connector from the pole, make a cable and connect it.
    Regards.
  • #32 906262
    Kapsis
    Help: 14
    Rate: 16
    dariuszm2 wrote:
    Hi.
    Regards.
    there are always stocks of the cable [of course wrongly] because it is Polish and they do it against the standards, or they leave it in single places along the entire otk line
  • #33 906557
    adamjur1
    Help: 772
    Rate: 1003
    The description shows that the technology used is:
    or VDI distributed by Legrand-Fael - Legrand catalog for 2004, page 613, maybe the local distributor (in Wielkopolska it's Nowa France) will lead you to someone who bought it and makes it. It is a completely "field" technology and the accessories include a positioning handle and a crimper.
    or 3M (I have the VOLITION 3M certificate).
    I advise you exactly the same. There is no sense and no possibility to master the technology for one connector. And by the way, someone probably gave a guarantee for it and should perform such a post-warranty service for little money.
    Regards J
  • #34 907621
    dariuszm2
    Help: 181
    Rate: 69
    Hi.
    The splice price (this will be the best solution) of a single-mode fiber should not exceed PLN 100, with larger quantities even PLN 40). That's more or less what fiber optic companies do.
    If you are interested, I will look for and see the names of the connectors that I described (quite good).
    As for the stock - I have not had such a stock in the connector for 4 years - it is impossible otherwise - the optical fiber is not copper - it cannot be stretched to put on the connector and thus get the connection. Sometimes, when the fiber was heterogeneous, it was welded 20 times to obtain a weld within the normal limits. I will add that with 10 splices on the line, the value of one splice cannot exceed 0.08dB.
    Regards.
  • #35 907842
    zhu
    Rate: 105
    Hello, if you can, look for what connectors you used for connections, and as cheaply as possible you can check if the optical fiber is "passable", i.e. whether there is no break on the way, e.g. in the ground: some light source at the beginning and at the end for the optical fiber to shine - without measurement power or with measurement, but it's probably an expensive thing?
    maybe someone has a fiber optic tester for sale - I'm interested in buying - or can recommend something, b. please give me info.
    I am also interested in buying a fiber optic knife - what company are they quite solid and reliable to use?
    the network is large, after the warranty and the company wants to invest in equipment and materials for operation, this is not a one-time repair - there are also other failures and there will be more of them, today we need connectors for repairing optical fibers and a tester for checking.
  • #36 908441
    midas78
    Level 19  
    Help: 12
    Rate: 12
    That's exactly what I mean.
    in Poland you can buy it at Lanster (www.lanster.com). But unfortunately they sell it by 6 or 12 pieces.
    Inserting the optical fiber is simple. But you need to have something to cut it with (if you cut it with scissors, it certainly won't work).
    Lanster also does fiber optic welding sometimes, but I don't know if it will be profitable for you.
    I bet other manufacturers also offer a similar solution. And I'll bet it's cheaper than AMP (Lanster).
    The price of a single weld may be about PLN 100, but you would probably have to add travel. AMP tools for fiber optics are very good quality, but also very expensive.
    The Corelink connector is filled with gel and from what I remember this gel protects against moisture (but I won't give my hand for it).
  • #37 908470
    ACULA
    Help: 105
    Rate: 114
    I think it protects more against reflections, etc. The gel has properties similar to optical fiber, so there is no fiber-air-fiber junction and there are no such drastic reflections, but it passes through the gel nicely ;)
  • #38 919982
    dariuszm2
    Help: 181
    Rate: 69
    Hi.
    I will see and let you know.
    I would like to point out, however, that in order to get a (quite good) connection, you need to cut it well (gel is not enough).
    How to check - it depends on the type of fiber - single-mode You can't check it by shining a lamp, for example. Gradient - you can use, for example, a laser - but also at short distances.
    I would like to add that my friend, while making pigtails, shone a lamp on one side (single-mode) and on the other looked through a magnifying glass (but it's only up to 40m) and to check if the pigtail doesn't suck.
    More accurate measurements is a reflectometer - but it's an expensive toy.
    Regards.
  • #39 6374483
    dominostaszek
    Hello, I have such a problem, I have to make presentations for studies on a device for transmitting reception and extending the network in rooms, such as modems, routers: hdsl shdsl sdsl in copper and fiber. I'm having trouble finding specific companies and catalogs with prices online. If anyone knows such companies' websites or something that would help me make such a presentation because I admit I'm green in this topic, and time is pressing because I have to do it on Wednesday. Please give me some useful links for this. Thanks in advance. my gg:10277898
The discussion revolves around methods for repairing a broken optical fiber connection used in surveillance camera systems. The original connection involved a gel-filled connector with a metal pin, which is now damaged. Various solutions are proposed, including using ST connectors from Eltra-Elda, seeking professional welding services, or utilizing splice connectors like Corelink from AMP. Participants emphasize the importance of proper fiber preparation and the potential for significant data loss if not done correctly. Recommendations include purchasing tools such as V-groove connectors, fiber optic knives, and adhesive for fiber optic plugs. The conversation also touches on the need for testing equipment to ensure the integrity of the fiber after repair, with suggestions for companies like 3M for tools and materials.
TL;DR: Up to 0.3 dB loss per field-terminated splice is common [Elektroda, Kapsis, post #902169]; “clean cuts matter more than fancy glue” [Elektroda, ACULA, post #901708] Cheap Corelink-type mechanical splices can restore CCTV fiber in minutes, no welder needed. Why it matters: Every hour a camera is dark risks evidence loss and service penalties.
• Fusion-splice loss: Typical 0.05–0.15 dB [Elektroda, dariuszm2, post #905821] • Mechanical splice (AMP Corelink) price: PLN 40–100 in bulk [Elektroda, midas78, #903474; Elekt, #907621] • 3M Volition tool-kit: 4- to 5-digit PLN depending on contents [Elektroda, ACULA, post #901828] • Cleave angle spec: ≤ 1° for < 0.2 dB loss [ITU-T G.671] • OTDR rental cost: €80–120 per day (Rental Catalog 2023)
How do I reconnect a single broken fiber without a fusion splicer?
Strip the coating, cleave both ends with a precision cutter, insert them into a gel-filled mechanical splice such as AMP Corelink, close the latch, then add a heat-shrink sleeve for strain relief [Elektroda, midas78, post #903474] Expect about 0.3 dB loss if the cleave is square [Elektroda, Kapsis, post #902169]
What exactly is a mechanical splice and which brands work in the field?
A mechanical splice aligns two fiber stubs inside a V-groove or ferrule filled with index-matching gel. Popular field models: AMP Corelink, 3M Volition, and Tyco Splice [Elektroda, ACULA, post #901399] These parts close with a simple crimp tool—no electricity or fusion arc needed.
Which tools do I need to prepare the fiber ends?
  1. Precision cleaver (e.g., Sumitomo FC-6 or AFL CT-05). 2. 99 % isopropyl wipes. 3. Kevlar shears for jacket cutting. 4. Crimp tool supplied with the splice kit [Elektroda, ACULA, post #901399] A good cleaver keeps the face perpendicular, critical for low loss [ITU-T G.671].
Can I reuse the original gel-filled connector already on the pole?
Re-opening the factory splice risks micro-scratches; accuracy must stay within a few micrometres [Elektroda, ACULA, post #901708] Removing old epoxy under a microscope is possible but seldom worth the labour or reliability hit—install a new mechanical splice instead.
How do I test whether a 2 km repaired link is intact?
Attach a 1310 nm LED source at one end and measure power with an optical meter at the other. Loss higher than the calculated budget (fiber + connectors) means trouble. Renting an OTDR (€80–120/day) helps pinpoint breaks but is optional for simple CCTV links (Rental Catalog 2023).
What’s the difference between single-mode and multimode for field repair?
Single-mode cores (≈9 µm) demand cleave accuracy under 1 ° and give higher return loss if mis-aligned [ITU-T G.671]. Multimode (50/62.5 µm) tolerates small errors, so mechanical splices work more easily. Both need proper cleaning to avoid extra attenuation.
How long does two-part FO epoxy take to cure?
Mix epoxy with slightly less hardener for more work time; initial set in 5–7 min at 23 °C, full cure in 30 min [Elektroda, ACULA, post #901708] Always wipe squeeze-out before it hardens.
What edge-case can ruin a seemingly perfect splice?
A 5 µm dust particle on the core can add over 1 dB loss—20× the design spec. Clean fibers with lint-free wipes and canned air before closing the splice [Fiber Cleaning Guide, 2022].
How do I install a mechanical splice in three steps?
  1. Cleave: Score and snap the fiber to get a flat end.
  2. Insert: Slide both ends into the gel-filled groove until they touch.
  3. Secure: Close the clamp, add heat-shrink sleeve, and let epoxy (if any) cure. Total field time: ≈10 min [Elektroda, midas78, post #903474]
Is renting a fusion splicer cost-effective for small jobs?
Splicer rental with operator often costs > PLN 500/day [Elektroda, ACULA, post #901063] For one or two joints, PLN 40–100 mechanical splices are cheaper and faster.
Which budget cleavers are considered reliable?
Technicians report good results with Sumitomo FC-6 (≈€450) and Inno V-7 (≈€300). Both achieve ≤ 0.5 ° average cleave angle, enough for < 0.2 dB loss [Vendor Specs 2024].
How do I protect the joint from moisture at the base of a pole?
Place the splice in a gel-filled closure (muff) and slide a 60 cm heat-shrink tube over it, then heat both ends—exactly as the original installer did [Elektroda, zhu, post #900177]
Do I need an OTDR, or is a light source and power meter enough?
For routine CCTV maintenance, a calibrated source and meter suffice. Use OTDR only when you must locate the fault’s distance; otherwise its high cost and complexity add little value [Elektroda, ACULA, post #901708]
What safety precautions should I take when handling bare fibers?
Wear safety glasses, dispose of fiber shards in a dedicated sharps container, and avoid touching eyes; splinters can cause serious injury [Fiber Safety Note, 2023].
