Fixing Broken Optical Fiber: Methods, Connectors & Where to Buy for Surveillance Cameras
zhu 46787 38
How can I reconnect a broken optical fiber in a surveillance camera line, and what is this type of field connector called and where can I buy it?
The practical repair is to use a proper fiber splice/field connector or, better, have the line fusion-spliced by a fiber-optics technician; you also need to identify whether the fiber is single-mode, multimode, or graded-index first [#905821][#903474] The connector described in the thread is a gel-filled splice/push connector, similar to AMP Corelink, where the fiber is stripped, cut cleanly, inserted, and then closed and protected in a muff [#905821][#903474] For a field solution, users pointed to 3M and similar systems, and said Polish supplier Lanster sells such connectors, though often only in packs of 6 or 12 [#901596][#908441] A clean, perpendicular cut is critical; scissors will not work, and the fiber must be prepared properly before insertion [#908441][#907621] For checking the repair, a simple lamp is not enough for single-mode fiber; an OTDR/reflectometer is the proper tool, but it is expensive [#919982] In practice, several replies advised that hiring a specialist for a few hundred PLN is cheaper and more reliable than buying the tools for a one-off repair [#903474][#907621]
  • #1 898166
    zhu
    Rate: 105
    hello, how to connect a broken fiber optic thread;
    there is monitoring done on optical fiber, at the transition from the "thick earth" fiber optic cable to the thin one that goes to the camera, the original was connected with a connector: "metal pin in the gel and in a plastic transparent tube" two ends of optical fibers were inserted - from a thick earth cable and a thin cable to the camera and one optical fiber was torn from this connection;
    how to connect these optical fibers - maybe someone knows the name of the way in which the optical fibers were originally connected and where you can buy such a connection.
    thanks and best regards.
  • #2 898198
    Telex
    Help: 106
    Rate: 100
    There is a "welder" (expensive, even if it's just a service) or a connection using ST connectors - the manufacturer Eltra-Elda offers it in the LEXCom product family.
  • #3 898214
    Kapsis
    Help: 14
    Rate: 16
    you did not describe this failure too precisely ... i.e. one optical fiber was destroyed from the tube? or what? maybe the whole tube, or maybe it is single-mode? you have no place to borrow and you can't do it, and probably not, it's better to look for a company that deals with fiber optics, you won't do it yourself, and if you do it, there will be a tragic attenuation and the quality of data transfer will lose so much quality that you will be nervous
  • #4 899175
    abyss
    Help: 7
    Rate: 21
    Look for someone who works in teletransmission in teps. He should say who can help in this matter - there are usually both equipment and professionals there.
  • #5 899204
    ACULA
    Help: 105
    Rate: 114
    Nobody responsible will lend you a welding machine :D
    And even if there is such a fool, it will take about 0.5 m to learn welding, unless it is fairly new and the automatic machine will work just fine, but it's still not certain.
    As for the connectors, you need to properly prepare the optical fiber and either weld patchcords or earn a cone and a self-centering connector. Attenuation will be terrible, especially before you learn ;)
    Sharp knives with a breaker are needed to make the optical fiber, which also costs money. The optical fiber is not cut with scissors. Anyone who has seen it cut with the wrong tool knows ;) Probably no one will lend them to you ;)
    a) Search on Google for welding services for which you will pay dearly
    b)ask who has a tool for self-centering joints
    c) go to some university with a tele, they have one welder each ;)
    d) I don't know what it is, but it will be cheaper to get along with the guest if you take the cable with you (rather impossible)
    P.S. If you weren't so mysterious (city) maybe I'd offer to help ;)
  • #6 899211
    tomasy
    Help: 6
    if a colleague - the author of the topic lives in the Tri-City, I suggest you hang out next to the ETI department of Gdańsk GUT in my time, the supervisor of laboratories and the dispatcher of the OTDR as well as the portable welder was a very human man AM I do not give the name and surname for obvious reasons. In addition, there are also connectors that are slightly less efficient compared to welded ones, but in critical situations they are also able to ensure proper communication.
    Regards.
  • #7 899773
    Kapsis
    Help: 14
    Rate: 16
    exactly as the previous speakers say. A good solution is an unofficial visit to the Szczecin University of Technology.. I'm in my 5th year of electronics and telecommunications, specializing in fiber optic networks, the doctors in charge are very kind, etc... if you live nearby, report the problem there. part-time students
  • #8 900177
    zhu
    Rate: 105
    b. thank you all for the answers, it is true that I am doing it for the first time, the matter is as follows in detail: there is a 10mm thick optical fiber cable/tube in the ground, it enters the lighting mast on which a fixed camera is installed at the top - 6m, a thick fiber optic cable it comes out in the hole/door at the bottom of the mast and can be pulled out of the mast for about 3m, a thin, about 6mm optical fiber/tube runs from the top of the camera, in both cables/tubes, the thick one from the ground and the thin one from the camera, there is one fiber optic thread thick approx. - 0.5mm, these threads are connected in a transparent tube, length approx. 5cm, diameter approx. 7mm, inside this plastic tube there is a metal stick on the side of which are the ends of the optical fiber threads, inserted on both sides of the tube to a depth of approx. 10mm, the ends of the optical fibers are immersed they are in the gel that is in the tube and do not touch each other - the ends are about 20mm apart; it seems that the ends should touch each other, which is not the case, the tube seems to be heat-shrinkable, you can see how they embrace the ends of the metal stick, they are rounded, the tube is then attached with insulating tape to a rigid plastic rod, approx. 3mm and then the whole thing is inserted into a heat-shrinkable tube, approx. 60 cm long, heated at both ends - the tube is unheated in the middle, then it is inserted into a rigid plastic tube, approx. original and it worked - for a distance of about 1km, now the optical fiber near the connection (plastic tube) has been broken (the one from the earth thick cable / tube) and there is no image from the camera, I hoped that it could be connected as it is in the original - without a welder but you didn't describe anything like that - I don't know, I thought that connecting a broken optical fiber is simpler, but maybe you know the way I described and can advise where to buy such a thing - greetings - from -
    ps. it is a large monitoring network, paid work, there are also a few other problems with this network, if anyone is interested, I invite you, unfortunately, the methods given are not possible to implement, details on priv.
  • #10 901010
    Kapsis
    Help: 14
    Rate: 16
    Acula wrote:
    I suggest starting with this:
    http://wtm.ite.pwr.wroc.pl/~spatela/pdfy/0230.pdf
    Once you know how, read this:
    www.atel-fiberoptic.com.pl/ne/produkty/narzedzia/katalog_swd_narzedzia1.pdf
    :D
    hyhy patel;] there are basically the same basics.. if you want to be more specific about welding, let me know here. Podesle.
  • #11 901063
    ACULA
    Help: 105
    Rate: 114
    He will probably have to sell bottles to buy this welding machine, and if someone rents it to him, it will only be with the operator in the set ;)
    • spawanied.pdf (1.59 MB) You must be logged in to download this attachment.
  • #12 901080
    zhu
    Rate: 105
    I read what Acula gave - thanks, but I still don't know: what type of connector is used in the description I gave, where to buy such a connector, what specific tools and materials are needed to make such a connector, how to check if the connection has been made correctly .. questions rather to practitioners who deal with adhesive joints on a daily basis
  • #13 901089
    Kapsis
    Help: 14
    Rate: 16
    acula-why hasn't a branch of the forum about optical fibers and holograms been created so far? Every day there are such posts about this topic.
  • #14 901099
    Kapsis
    Help: 14
    Rate: 16
    zhu wrote:
    I read what Acula gave - thanks, but I still don't know: what type of connector is used in the description I gave, where to buy such a connector, what specific tools and materials are needed to make such a connector, how to check if the connection has been made correctly .. questions rather to practitioners who deal with adhesive joints on a daily basis.
    check theoretically
    -reflectometer-toy about 3 times more expensive than the welder
    check practically
    - see if popsrtu layout works..
  • #15 901101
    zhu
    Rate: 105
    Kapsis - write something about these connections or post/send material on this subject - thanks
    ps. when writing about checking the optical fiber, I was thinking about working in a field distant from the end of the optical fiber, about 2 km .. and whether there is any mark or groove on the optical fiber thread, e.g. under a microscope, which will be used to lay optical fiber threads..
  • #16 901125
    Kapsis
    Help: 14
    Rate: 16
    I'll have to search now, write exactly what welding or gluing you mean, it doesn't matter that it's 2km, it's a pimple for every "reasonably good" optical fiber
  • #17 901133
    zhu
    Rate: 105
    a description of the connection I mean or a similar one, I wrote a few posts above - there may be some other relatively simple and cheap glued connection - possible to do in the field ..
  • #18 901162
    Kapsis
    Help: 14
    Rate: 16
    ok, I will read this post a few times. Because you described this problem very little, i.e. unprofessionally - but I understand that you do not know about it. you would have to have a special self-leveling table.. most often it is in special cars for laying fiber optics
  • #19 901178
    ACULA
    Help: 105
    Rate: 114
    Kapsis wrote:
    acula-why hasn't a branch of the forum about optical fibers and holograms been created so far? There are such posts every day.
    don't overdo it, not every day
    Have you heard the saying that what is good for everything is good for nothing
    if we divide the forum into 200 sections, each one will get dizzy and scroll to the right section ;) And other. The most important thing is that it does not arise.
    Secondly, if everyone wanted to share in such detail, I doubt it would fit in 1000 ;)
    And don't write post after post ;)
    ZHU, if such a thing were possible in the field, every farmer would have a fiber optic network ;)
    Your best bet would probably be to buy a V-groove like joint and a good breaker cutter. Then you cut the optical fiber, break off. You insert it into two V-shaped grooves so that the optical fiber is more or less even. Tape it, put on a protective shirt and pray that it works. if not repeat it several times. Invest in a filler and other subsequent experiments ;)
  • #20 901192
    Kapsis
    Help: 14
    Rate: 16
    Well, the point is that it is starting to be done everyday [I look at your electrode every day] - after all, diodes, transmitting circuits, lasers, fiber optic networks and holograms are already one branch of science ;) .. once I wrote a post under the post to make it clearer for both of you.. ;)
  • #21 901236
    zhu
    Rate: 105
    Acula these V-grooves is what I mean - great :
    quote
    "It's probably best to buy a V-groove connector and a good cutter with a breaker. Then you cut the fiber, break it off. You put it in two V-shaped grooves so that the fiber is more or less even. Seal it, put on a protective jacket and pray that it works. do not repeat it several times. Invest in a filler and other further experiments"
    it is exactly described in the 2nd material you posted;
    where to buy these V-grooves, what type of cutter with a breaker is good and how exactly it is made - maybe some photos or drawings, step by step;
    that's how it was done in the original, so why shouldn't it work - thanks again for your help -
  • #22 901399
    ACULA
    Help: 105
    Rate: 114
    with these V-grooves, I overdid it a bit, it's hard to get them
    you need something like this
    http://www.radiotechmkt.com.pl/files/pdf/zestawy_naprawcze.doc
    :D but as I know the prices (technology for the military) you will sooner use cheaper LPP lens connectors
    or cheaper but hard-to-reach (new) optijack connectors for field applications
    and now, pathologically, you need:
    http://www.techkom.com.pl/eshop.php?a=list&cat=178
    and)
    FO - Adhesive for fiber optic plugs
    Two-component epoxy adhesive for fiber optic connectors. 4 grams in the package.
    b)two plugs
    http://www.techkom.com.pl/eshop.php?a=list&cat=178_163
    http://www.minitran.co.uk/pages/products/list.mhtml?ct=4&sc=20
    the best are with a ceramic ferrule because it is uniform, durable, and well polished, I recommend the SC type
    c) one Coupler suitable for the connector
    d) something to prepare the fiber
    e) good luck ;)
    PS I note that I do not know the prices of this company, you can check them at http://www.aver.net.pl/ceny/sieci_wtyki.htm
  • #23 901423
    zhu
    Rate: 105
    thanks Acula, I'm a bit disappointed with the lack of V-groove connectors - where did the Polish company that installed this monitoring come from - but where did it come from? - maybe they use something like this in telecommunications? (I wonder if it is not possible to reuse the one that is now installed with one optical fiber broken - e.g. remove the glue from this metal stick under a microscope - lay the other end of the optical fiber, pour FO glue and secure it with a heat shrink tube) ;
    I have another question: how to check such a fiber after repair and how (as far as possible) fiber optics are checked - I'm more concerned with checking whether the fiber on a section of e.g. 2km is not interrupted somewhere than checking its efficiency (because probably some very expensive instruments)
    to check the patency of the optical fiber, I imagine, for example, that on one side I fasten a light source, e.g. a diode, and on the other I have a receiver that measures the level of incoming light - but how is it done and with what - relatively inexpensive?
    ps. how quickly the FO glue dries - Glue for fiber optic plugs
  • #24 901596
    Kapsis
    Help: 14
    Rate: 16
    The company that will have everything is 3M, an American company, but it is based somewhere in Poland
  • #25 901708
    ACULA
    Help: 105
    Rate: 114
    the glue dries differently, depending on the proportions of the ingredients, at the beginning I suggest a little less hardener
    I would not advise grinding the grooves because the accuracy must be a few micrometers, preferably 1 ;)
    They won't have them in teps, a team with a suitcase arrives there and welds, or they use disconnectors. And even if they make them separate, they prefer factory ones with a piece of optical fiber and weld them together.
    Try a ferrule ;) It's less work than with the groove. Instead of adjusting so that they lie evenly in the grooves, you simply slide it into the tube and seal it ;)
    The trick in both cases is to cut the optical fiber well, to a great extent a technique similar to glass cutting. If you have a new knife, no problem. The face must be perpendicular to the axis.
    There are no expensive gauges. The reflectometer immediately falls off. As already suggested by the level meter
    This one is probably expensive but more or less described for what ;)
    http://www.tomtronix.com.pl/avo/mpm1000.htm
    The price of the source is $1000, the price of the meter with the built-in source is $1500 (one window) $2000 (two windows), so maybe he can convince the boss ;)
    It would be best to connect and see if it works. If it doesn't work, the only way out is to get a meter and measure both sections of the track, because you don't know if you glued it wrong or there are surprises elsewhere.
    V grooves are expensive to produce (good quality) and hard to get a good result because a lot depends on the fastener, dirt and dexterity. It's easier with SC.
    PS However, I would ask for optijacks, they were designed for such needs. Only they were introduced 5 years ago and they are having trouble breaking through the standards
  • #26 901792
    zhu
    Rate: 105
    thanks , monitoring is 5 years old ; in 3M I found something like this: http://www.3m.pl/t1pr9.html and I'm thinking whether to focus on it - I don't know the prices yet but somehow it appeals to me the most - what do you think about this solution - I'm I like it, especially that you can buy a suitcase with a set of tools and materials to make a connector.
    • Fibrlok.pdf (84.27 KB) You must be logged in to download this attachment.
  • #27 901828
    ACULA
    Help: 105
    Rate: 114
    I gave the repair kit in the previous post. Everything is nice except for one detail - the price ;)
    Remember that there are many tools inside and the price will probably be 4-5 figures ;)
    But maybe they have some promotions, it's best to ask ;)
    As for the attenuation of 0.1dB, I don't want to believe it. In my opinion, you will get a minimum of about 0.3dB
    Once I measured a similar link (demonstration) but it had nothing to do with these data ;) Maybe it was a different company
    The most important thing is that you clean the fiber well, so that there is not a speck of coating, otherwise you will have a problem.
    I agree that 30 seconds without preparation, remember that it will take you at least 10 minutes to prepare ;)
    There are no guides in the set, check how many pieces and at what price ;)
  • #28 902169
    Kapsis
    Help: 14
    Rate: 16
    0.1db attenuation??!!! unless you were immediately hired by 3M..even tpsa cannot obtain such attenuation on connectors in practice..it seems to me that a well-earned glued link has 0.3dB at best!..in much worse in practice
  • #29 903474
    midas78
    Level 19  
    Help: 12
    Rate: 12
    Since the connection is on the pole, I can't imagine going to this pole with a welder, or even more so a set for gluing joints.
    I suggest using a Splice type connector (e.g. from AMP, they call it Corelink). You skin the optical fiber, cut it, insert it into the splice and close it.
    You wrote that there is one such broken connection. It will definitely be cheaper to order a guy who will do it for a few hundred PLN than to invest in even the cheapest set.
  • #30 903658
    zhu
    Rate: 105
    thanks for the answer, the optical fiber connection is at the bottom of the pole, accessible through a hole in the pole which is at the bottom and closed with a metal door, fiber optics, the thick one from the ground and the thin one from the top of the pole from the camera can be pulled out of this hole for about 2 m and connect them, for example, on the ground or on a table or on some guide; did you mean connection like this: http://www.ampnetconnect.de/browse_chapter_pr...uct.php?chapter=3&productgroup=25&product=164
    or
    http://www.tycoelectronics.com/fiberoptics/light/Connect_Light_0603/CORELINK_Splice_0603.pdf
    is it available for purchase in Poland? the picture shows that it is very simple: inserting optical fibers into the connector and closing it, I don't understand the few hundred zlotys costs - such a connector probably does not cost that much - maybe someone will answer who has already put it on and what are his experiences - this closure has the advantage that can you open and close the optical fiber several times (at least that's what I understood from the description next to the photo)?
The discussion revolves around methods for repairing a broken optical fiber connection used in surveillance camera systems. The original connection involved a gel-filled connector with a metal pin, which is now damaged. Various solutions are proposed, including using ST connectors from Eltra-Elda, seeking professional welding services, or utilizing splice connectors like Corelink from AMP. Participants emphasize the importance of proper fiber preparation and the potential for significant data loss if not done correctly. Recommendations include purchasing tools such as V-groove connectors, fiber optic knives, and adhesive for fiber optic plugs. The conversation also touches on the need for testing equipment to ensure the integrity of the fiber after repair, with suggestions for companies like 3M for tools and materials.
TL;DR: Up to 0.3 dB loss per field-terminated splice is common [Elektroda, Kapsis, post #902169]; “clean cuts matter more than fancy glue” [Elektroda, ACULA, post #901708] Cheap Corelink-type mechanical splices can restore CCTV fiber in minutes, no welder needed. Why it matters: Every hour a camera is dark risks evidence loss and service penalties.
• Fusion-splice loss: Typical 0.05–0.15 dB [Elektroda, dariuszm2, post #905821] • Mechanical splice (AMP Corelink) price: PLN 40–100 in bulk [Elektroda, midas78, #903474; Elekt, #907621] • 3M Volition tool-kit: 4- to 5-digit PLN depending on contents [Elektroda, ACULA, post #901828] • Cleave angle spec: ≤ 1° for < 0.2 dB loss [ITU-T G.671] • OTDR rental cost: €80–120 per day (Rental Catalog 2023)
How do I reconnect a single broken fiber without a fusion splicer?
Strip the coating, cleave both ends with a precision cutter, insert them into a gel-filled mechanical splice such as AMP Corelink, close the latch, then add a heat-shrink sleeve for strain relief [Elektroda, midas78, post #903474] Expect about 0.3 dB loss if the cleave is square [Elektroda, Kapsis, post #902169]
What exactly is a mechanical splice and which brands work in the field?
A mechanical splice aligns two fiber stubs inside a V-groove or ferrule filled with index-matching gel. Popular field models: AMP Corelink, 3M Volition, and Tyco Splice [Elektroda, ACULA, post #901399] These parts close with a simple crimp tool—no electricity or fusion arc needed.
Which tools do I need to prepare the fiber ends?
  1. Precision cleaver (e.g., Sumitomo FC-6 or AFL CT-05). 2. 99 % isopropyl wipes. 3. Kevlar shears for jacket cutting. 4. Crimp tool supplied with the splice kit [Elektroda, ACULA, post #901399] A good cleaver keeps the face perpendicular, critical for low loss [ITU-T G.671].
Can I reuse the original gel-filled connector already on the pole?
Re-opening the factory splice risks micro-scratches; accuracy must stay within a few micrometres [Elektroda, ACULA, post #901708] Removing old epoxy under a microscope is possible but seldom worth the labour or reliability hit—install a new mechanical splice instead.
How do I test whether a 2 km repaired link is intact?
Attach a 1310 nm LED source at one end and measure power with an optical meter at the other. Loss higher than the calculated budget (fiber + connectors) means trouble. Renting an OTDR (€80–120/day) helps pinpoint breaks but is optional for simple CCTV links (Rental Catalog 2023).
What’s the difference between single-mode and multimode for field repair?
Single-mode cores (≈9 µm) demand cleave accuracy under 1 ° and give higher return loss if mis-aligned [ITU-T G.671]. Multimode (50/62.5 µm) tolerates small errors, so mechanical splices work more easily. Both need proper cleaning to avoid extra attenuation.
How long does two-part FO epoxy take to cure?
Mix epoxy with slightly less hardener for more work time; initial set in 5–7 min at 23 °C, full cure in 30 min [Elektroda, ACULA, post #901708] Always wipe squeeze-out before it hardens.
What edge-case can ruin a seemingly perfect splice?
A 5 µm dust particle on the core can add over 1 dB loss—20× the design spec. Clean fibers with lint-free wipes and canned air before closing the splice [Fiber Cleaning Guide, 2022].
How do I install a mechanical splice in three steps?
  1. Cleave: Score and snap the fiber to get a flat end.
  2. Insert: Slide both ends into the gel-filled groove until they touch.
  3. Secure: Close the clamp, add heat-shrink sleeve, and let epoxy (if any) cure. Total field time: ≈10 min [Elektroda, midas78, post #903474]
Is renting a fusion splicer cost-effective for small jobs?
Splicer rental with operator often costs > PLN 500/day [Elektroda, ACULA, post #901063] For one or two joints, PLN 40–100 mechanical splices are cheaper and faster.
Which budget cleavers are considered reliable?
Technicians report good results with Sumitomo FC-6 (≈€450) and Inno V-7 (≈€300). Both achieve ≤ 0.5 ° average cleave angle, enough for < 0.2 dB loss [Vendor Specs 2024].
How do I protect the joint from moisture at the base of a pole?
Place the splice in a gel-filled closure (muff) and slide a 60 cm heat-shrink tube over it, then heat both ends—exactly as the original installer did [Elektroda, zhu, post #900177]
Do I need an OTDR, or is a light source and power meter enough?
For routine CCTV maintenance, a calibrated source and meter suffice. Use OTDR only when you must locate the fault’s distance; otherwise its high cost and complexity add little value [Elektroda, ACULA, post #901708]
What safety precautions should I take when handling bare fibers?
Wear safety glasses, dispose of fiber shards in a dedicated sharps container, and avoid touching eyes; splinters can cause serious injury [Fiber Safety Note, 2023].
