Replacing Soldering Iron Tip: Guide for Beginners Using Cheap Models
nintendog 31433 12
How do I replace the soldering iron tip on a cheap soldering iron so solder will stick again?
Replace the tip with a copper one cut to the same size, fitting tightly in the heater hole; on this model you unscrew the two screws, remove the old tip, and insert the new one [#8935115] Use rosin-core solder and keep a separate rosin handy; on first heating, dip the new copper tip in rosin and then tin the end with solder [#8934846][#11463980] If the tip has turned dull or tarnished, clean it before use so the solder will stick again [#11463598] Make sure the tip diameter is correct so it transfers heat well from the heater [#8935115] Practice on old boards or scrap parts until the tinning and soldering become easy [#8934846]
  • Replacing a worn soldering iron tip with copper wire
    #1 8924128
    nintendog
    I have this soldering iron
    I know it's not the best, but I'm just starting my adventure with electronics and at the beginning I preferred to buy something cheap.
    For the first few days everything was ok, but after some time the tin started to fall off the soldering iron tip - it doesn't stick at all.
    I read on this forum that it is necessary to replace the tip with a new one (preferably with a copper cable) - how to go about replacing it?
    Regards
  • #2 8924139
    yogi009
    Help: 850
    Rate: 2658
    Try to touch the hot tip with salmiak (such a white stone that helps in soldering) and then pick up a bit of tin. You can also try to lightly grind the top layer of this tip, maybe it will help.
  • #4 8934593
    dipol
    Help: 168
    Rate: 259
    yogi009 - electronics soldering and salmiak!!! don't make fun of your friend. Buy rosin and whiten it elegantly, and at the beginning solder a 1cmX1cm cube. As you solder, you will already know everything about soldering.
    Also read what my friend wrote above.
    Good luck.
  • #5 8934846
    Dreamer93
    Rate: 11
    Use tin already with rosin, preferably 'ones'. In addition, buy yourself a rosin separately - it is very useful. I would suggest you drill holes on the printed circuit board and practice soldering some old stuff on it.
    Also, clean the tip from time to time. He can't be trusted and scorched. I had the same problem with practically the same soldering iron (mine has 30W and 130W operating ranges). After soldering a few boards and reading a few PDFs, the practice comes by itself. I have no problems with it anymore.
  • #6 8935079
    tfx85
    Rate: 47
    Secondly, it is better to add tin to the place heated with the tip where the solder is to remain, and not to transfer it on the tip.
  • #7 8935115
    Błażej
    Help: 1923
    Rate: 3627
    If you complain about the tip in this soldering iron, actually replace it with a copper one. You unscrew two screws and the old one falls out. And you make a new copper one to its size. The most important thing here is the diameter, so that it fits quite tightly into the hole and receives as much heat as possible from the heater.
    The set includes tin, rosin, some paste, and a steel wool or special sponge cleaner. And practice...
    Although a classic transformer soldering iron would be better for you, and not some attached heater wonder...
  • #8 8935224
    Dreamer93
    Rate: 11
    I wouldn't complain because I solder this one 100x better than the transformer one. But that's personal feeling.
  • #10 11463598
    snopa
    In the video you can see that there is a tarnish on the tip, clean it and it should be ok.
  • #11 11463627
    kamil195
    Ok, I'll check, and by the way, does anyone have an interesting idea for such a Sunday "lutmaster" how to scrape it inexpensively? enough sandpaper?
    Does it have to be some kind of cellulose sponge?
  • #12 11463980
    ciasteczkowypotwor
    Help: 591
    Rate: 577
    kamil195, take a 1.5mm2 copper wire and make a new tip, dip it in rosin during the first heating, and then whiten the end with tin.
  • #13 11464024
    kamil195
    Thank you for your help.
The discussion revolves around the challenges faced by beginners using inexpensive soldering irons, particularly regarding the soldering iron tip that fails to hold solder. Users suggest various methods to improve soldering performance, such as using salmiak or rosin, cleaning the tip, and practicing on scrap materials. A key recommendation is to replace the soldering iron tip with a copper one, which involves unscrewing the old tip and ensuring the new one fits tightly for optimal heat transfer. Users also emphasize the importance of using rosin-core solder and maintaining the tip to prevent tarnishing and improve solder adhesion.
