Replacing Burned-out Electronics in Seagate 40GB ST340016A: Compatibility with Other Models?
piotrek power 3722 8
  • #1 921682
    piotrek power
    Rate: 195
    I will start with what happened to the disc: namely, a slightly higher voltage than it should have gone, and the electronics probably burned out because something else.
    I am only looking everywhere: on auction (Allegro), commission etc.
    And I can not find the same hiss with good electronics. does it have to be the same models the same capacity and the same company?
    Because on Allegro I can get rid of disks with good electronics that would come to me, Drive: Seagate 40GB 7200r. model: ST340016A, there are other models and differ eg in ST340014A or other capacity, which electronics would come from me (from which disk).
    Greetings.
    I am asking for advice :)
  • #2 921759
    elbob
    Level 32  
    Help: 211
    Rate: 118
    What to buy - https://www.elektroda.pl/rtvforum/topic188897.html
    You must look for electronics exactly to the model of the disk you have, or
    ST340016A. It would also be good if the version of the electronics board would be compatible with yours.
    Greetings.
  • #3 921785
    Robert B
    Help: 2027
    Rate: 1412
    Version - IMPORTANT!
    I tried to swap places in ST340016A versions 3.05 and 3.75 and none of this :(
    In contrast, 3.05 and 3.10 in the order of :)
  • #4 922163
    satgal
    Level 40  
    Help: 482
    Rate: 428
    Hello in these models must only agree the firmver capacity can
    to be even bigger, if you have efficient electronics and other firmver it is enough to sell a flash from the broken unless it also fell.
    I am looking for a flash since 3.05 I can change it to another.W-wa 608 795 989
  • #5 922872
    dziobass
    I had a similar problem. I was the owner of the Seagate U4 8GB drive, with inefficient electronics (the disk hung the computer). My colleague had a 6GB Seagate U4, with the disc having some physical bugs, and he could not do anything about it, so the disc gave me. After swapping the electronics, the disk is flashing, it is detected as 8GB (this is the capacity of the disks).
    Thus, as satgal wrote, disk capacity is not critical.
    Disks also differ in firmware: initially 8-gig had versions 8.01, while 6-gig versions - 6.01. Now the 8-gig disc works with 6-gig electronics, which means it has older firmware, but it is still detected correctly. In addition, both disks differ in CHS factors. Despite all these differences, the folder is detected correctly, and works very steadily.
    I drew the conclusion that firmware compatibility is not necessary, but it is necessary to have a firmware version that will automatically configure the disk as soon as the computer is started, based on the information read from the hard disk itself (flash systems).
    Greetings,
    dziobass.
  • #6 923047
    kols6666
    And I have a few pins from the cable connection ideally broken. Is it possible to exchange all the electronics or give advice only to solder the connector itself (all this rear rail with connection to voltage, cable and jumpers)
  • #7 930860
    elbob
    Level 32  
    Help: 211
    Rate: 118
    :arrow: piotrek power - you can see - here it is: http://www.hadek.pl/dyski.html
    If not the 8O prices yet
    Greetings.
    Ps.
    Of course, they do not sell electronics here, but in an out of the ordinary situation (it's about making a diagnosis - disk or electronics), the offer can be a good alternative.
  • #8 932442
    havoc666
    kols6666 wrote:
    And I have a few pins from the cable connection ide broken. Can the mouse replace the whole electronics or give advice only to solder the same connector (all this rear rail with connection to voltage, cable and jumpers)
    you can easily crush. I did it many times with different disks and there were no problems. You only have to get the same pins.
  • #9 932986
    radosny1
    Help: 6
    as for moving the electronics itself, the seagate is different: in older discs up to 20gb (medalist), of course, it can be from a disc with different capacity and does not necessarily have to be the same firmware, one of these newer disks (baracuda) are more demanding and it is necessary to find electronics with the same firmware, and even the same p / n
    I've fought the 120gb for the last time, it's the same and it did not start, it was only the third electronics that was all right.
    whereas when it comes to soldering pins, it's only for the steel nerves and very precise hands, and of course the :D equipment because the rest of the pins fall out 8O
The discussion revolves around replacing the burned-out electronics of a Seagate 40GB ST340016A hard drive. Users emphasize the importance of finding compatible electronics, specifically matching the model number and firmware version. While some suggest that electronics from different models (like ST340014A) may work if the firmware is compatible, others caution that newer models, such as Barracuda, require exact matches in firmware and part numbers. Users share experiences of successfully swapping electronics between drives of different capacities, highlighting that firmware compatibility is crucial for proper detection and functionality. Additionally, there are mentions of soldering connections as a potential solution for damaged pins.
