Seagate Momentus 5400.6 (ST9250315AS) 250GB - BIOS Detects Disk, LBA 0 Issue, Terminal Errors
Ryfa 4822 10
How can I access the Seagate terminal and diagnose or recover a drive that is detected by BIOS but shows LBA 0 and terminal errors?
You need a proper terminal connection first, and the symptoms suggest a head/SA problem rather than a simple 7200.11-style LBA0 fix [#10617648][#10630028][#10630272] Press Ctrl+Z to enter the Seagate terminal and get the `T>` / `F3 T>` prompt; if nothing happens, the adapter is likely the issue and you should use a real MAX232-based terminal or a Nokia USB cable instead of the current converter [#10617648][#10630028][#10649661] After the terminal works, the reported `V4` output showed zero alternate sectors, and one reply said this type of case may be handled by terminal/software but will probably need PC-3000 [#10649661] Another reply said the problem may be with the heads or bad sectors in the SA, which matches the LBA0/terminal-error symptoms [#10630272] No one confirmed that the data can be recovered without repair, and no terminal-only 'fork' procedure was provided for this drive [#10649661][#10906247]
  • #1 10615641
    Ryfa
    Hello, I have a problem: Disk detected by bios, the problem is 0 LBA. The disk comes from a laptop, quite new.
    Seagate momentus 5400.6 250GB
    Model ST9250315AS
    FW: 0003SDM1
    the terminal shows it exactly after connecting the power to the disk. the disk works quietly, I would normally say.
    Rst 0x08M
    RW cmd 0002 req = 89 3E 00 00 17 02 00 00 00 00 00 00 08 8D 08 00 87 98 09 00 08 8D 08 00
                opts = 00001121
    RW Err = 43110081
    RW cmd 0002 req = 89 3E 00 00 01 00 00 00 00 00 00 00 08 8D 08 00 87 98 09 00 08 8D 08 00
                opts = 00001121
    RW Err = 43110081
    RW cmd 0002 req = 75 5F 02 00 17 02 00 00 00 00 00 00 08 8D 08 00 87 98 09 00 08 8D 08 00
                opts = 00001121
    RW Err = C3160084
    RW cmd 0002 req = 75 5F 02 00 01 00 00 00 00 00 00 00 08 8D 08 00 87 98 09 00 08 8D 08 00
                opts = 00001121
    RW Err = C3160084
    Is there any advice or do you have to give to someone from PC-3000?
    PS, although I am not sure if my adapter works well, I have connected 100% efficient 3.5 "seagate ST3250318AS drive and in the terminal only this:
    đ
    Rst 0x08M
    (P) SATA Reset
    and nothing happens anymore, no command line etc ... do I do something wrong?
    set at 38400 8 N 1, bushes pop out at 9,600.
    PS2: can I recover any data from this disk without fixing this vulnerability? I care only for one catalog with documents
  • #2 10617648
    PitD
    Help: 431
    Rate: 237
    Press CTRL + Z
    It will appear then
    T>
    Now you are in the terminal.
    Kuźnia Komputerowa
    Marsz.J.Piłsudskiego 17, Kraków, 31-110 | Company Website: https://www.kuznia.pl
  • #3 10618133
    Dragon022
    Rate: 23
    You must enter the commands correctly.
  • #4 10621616
    Ryfa
    I press the CTRL + Z combination, nothing happens. I use putty, I also tried hyperterminal. What else can I do?
  • #5 10623543
    migol21
    HDD Recovery specialist
    Help: 1253
    Rate: 415
    What else can I do?
    Give to someone who has more experience.
  • #6 10625559
    PitD
    Help: 431
    Rate: 237
    Ryfa wrote:
    I
    With which disc does this happen?
    Kuźnia Komputerowa
  • #7 10629415
    Ryfa
    PitD wrote:
    Ryfa wrote:
    I
    I tried with both disks, I also tried on the third disk, as far as it came
    Rst 0x20M
    (P) SATA Reset
    I press ctrl + and nothing happens.
    The adapter: link to the manufacturer
  • #8 10630028
    PitD
    Help: 431
    Rate: 237
    Do yourself a decent terminal on MAX232 or eventually buy a Nokia USB cable.
    Then check these disks.
    And put this converter on the shelf.
    Kuźnia Komputerowa
  • #9 10630272
    michal_aniol
    Help: 182
    Rate: 100
    Problem with heads. There may be bady in SA.
  • #10 10649661
    Ryfa
    Hello again, I already have a TTL controller and it works normally, CTRL + Z and the command line F3 T> appears
    I wonder what to do now - probably it is not a good idea to use LBA0 methods from 7200.11 drives here?
    the result of the V4 command
    Reassigned Sectors List
    Original     New    log log   log     phy     phy
        LBA      PBA    cyl  hd  sctr zn  cyl hd  sctr     SFI
             Alt   Pending  Total    Alted  Total
           Entries Entries Entries    Alts   Alts
    Head 0              0
    Head 1              0
    Total        0      0       0        0      0
    Total Alt Removals:    0
    Checksum = 0000
    from the beginning, I think that it can be done by the terminal and normally available software but you will probably need to use the PC-3000 - I read that there is a new 'fork' option that repairs such drives with one click ;-) SA from scratch?
  • #11 10906247
    tczewiak_
    Can this method of 'fork' be transferred to the terminal, i.e. can it be played with only a terminal?
The discussion revolves around a Seagate Momentus 5400.6 hard drive (model ST9250315AS) that is detected by BIOS but exhibits a LBA 0 issue, leading to terminal errors. The user initially struggles with terminal commands and seeks advice on troubleshooting. Suggestions include using a proper terminal setup, such as a MAX232 or Nokia USB cable, and checking for potential head problems or issues in the Service Area (SA). After acquiring a TTL controller, the user successfully accesses the command line but questions the appropriateness of using LBA0 methods from 7200.11 drives. The conversation also touches on the possibility of using a new 'fork' option in PC-3000 software for repairs.
