Polish Table Grinder Electric Motor Buzzing: Addressing Overheating & Startup Issues after 15-20s
TheKocur 9801 10
Why does my bench grinder motor buzz and refuse to start after 15–20 seconds of running, but work normally again after cooling down?
The most likely cause is overheating in the grinder’s closed housing, which changes the plastic bearing seats so the rotor rubs the stator and the motor hums and stalls until it cools down [#16356258][#16356320][#16356342] The capacitor was already checked and even replaced, so it is probably not the fault here [#16356205][#16356207][#16356210] Check whether the shaft turns freely, whether the bearings are still OK, and whether there are rub marks or scratches on the rotor [#16356242][#16356275][#16356453] One reply adds that the original axle/shaft construction is split into two parts in a plastic sleeve, so a shaft replacement may be needed [#16356907] In practice, this kind of grinder may also simply be too poorly cooled for long runs and may need replacement [#16356258]
  • Motor buzzes and fails to start after warming up
    #1 16356190
    TheKocur
    Rate: 11
    I have a Polish table grinder Polish Table Grinder Electric Motor Buzzing: Addressing Overheating & Startup Issues after 15-20s When the engine was cold it worked normally, after 15-20 seconds of operation it became warm. I turned it off and on and it did not work anymore, i.e. it buzzed and refused to walk. Sometimes when I move it with my hand it will start to work (but this is rare, when it is not too warm) After cooling down, it works normally ...
    Can anyone help me?
  • #2 16356205
    Józio17
    Help: 204
    Rate: 198
    A colleague checked capacitor?
  • #3 16356207
    technikabasenowa
    Help: 138
    Rate: 445
    Capacitor for replacement.
  • #4 16356210
    TheKocur
    Rate: 11
    I checked the capacitor and it's good, I even gave it a different one, a little bigger and the same
  • #5 16356242
    technikabasenowa
    Help: 138
    Rate: 445
    Is it spinning lightly? bearings ok? specify motor power and what capacitor?
  • Bearing heat causes rotor rubbing and motor hum
    #6 16356258
    kierbedz4
    Level 36  
    Help: 307
    Rate: 1008
    The bearings mounted on the grinder shaft are their outer rings embedded directly in the plastic grinder housings in which there are no retaining rings, as a result of which during the grinder operation the temperature increases inside the grinder body and thus the temperature is transferred to the side of the grinder's body and thus friction of the motor rotor on the stator plate and stopping the rotor itself and the engine humming. I had the same problem. The manufacturer clearly stated how many minutes the grinder can work so that the motor shaft does not stop when the grinder motor overheats. I just gave up in the form of buying a new grinder power 200W in Lidl at a moderate price not exceeding PLN 100. In other stores I was offered 120W grinders, which I did not like.
  • #7 16356275
    TheKocur
    Rate: 11
    I had cleaned the bearings before because they were dirty and loose. Motor power is 180 W and capacitor 3.7 uF
  • Overheating causes bearing misalignment and rotor rubbing
    #8 16356320
    kierbedz4
    Level 36  
    Help: 307
    Rate: 1008
    After all, the motor of this grinder is closed in a closed housing where there is practically no cooling, which changes the parameters of the housings, their heating and decalibration of the dimensions of the holes in the housings of built-in bearings, so that the rotor begins to rub against the rotor plates and becomes the grinder's rotor. up to several minutes. After the grinder has cooled down completely, it can be used again until it stops again by itself, which causes its humming.
  • #9 16356342
    niewolno2
    Level 40  
    Help: 630
    Rate: 1260
    When the temperature increases, there is a loss of rotor alignment with respect to the stator on plastic bearing seats and the rotor rubs against the stator.
  • #10 16356453
    TheKocur
    Rate: 11
    I started it yesterday, as I wrote earlier, to clean the bearings, and I am reminded that there were scratches on the rotor ....
    But it can work a few minutes until it stops, not a few seconds.
    And after 15 seconds it doesn't work, although the rotor turns slightly, but it is hot
  • #11 16356907
    e2rd.o
    Help: 39
    Rate: 111
    A new axle must be added to this grinder, because the mounted one does not pass through the rotor but consists of two parts embedded in a plastic sleeve. Former material saving.
The discussion revolves around a Polish table grinder experiencing motor buzzing and overheating issues after 15-20 seconds of operation. Initially, the motor functions normally when cold, but it fails to start after heating up, only buzzing when turned on. Users suggest checking the capacitor, which was confirmed to be functional. The problem is attributed to inadequate cooling due to the motor's closed housing, leading to rotor misalignment and friction against the stator. Recommendations include cleaning or replacing bearings, addressing rotor scratches, and considering a new axle design for better performance. One user mentioned purchasing a new 200W grinder as a solution.
