  • #31 9381384
    bmserwis
    Level 36  
    Help: 262
    Rate: 200
    Of the ones that I remember, someone wanted to fry the neighbor's equipment using a microwave oven. :)
    We laughed, and now seriously: no matter what time, but the neighbor has no right to disturb the order, there are appropriate paragraphs for this. It helps to CONSISTENTLY call the police so that the interventions are recorded and then the case in court.
  • #32 9381826
    LuckyDj
    Help: 186
    Rate: 192
    This is. There is a curfew from 10 p.m. to 6 a.m., and from 6 a.m. to 10 p.
    I used to have troubles myself, because I had a TON200 at home when I was too young, driven with the LDM SA404 tip :)
The discussion revolves around the feasibility of using devices to jam or interfere with a neighbor's loudspeakers, specifically to create unwanted sounds like "gurgling." Various suggestions include using sinusoidal jammers or bubblers powered by batteries to avoid interference from mains power. Participants discuss the legality and practicality of such devices, with some cautioning against potential legal issues and recommending direct communication with the neighbor or police intervention for noise disturbances. The conversation also touches on the availability of these devices in electronics stores and online platforms like Allegro, with some users sharing their experiences and technical specifications for building or acquiring such equipment.
TL;DR: 80 % of EU countries treat intentional signal jamming as a criminal offence [CEPT, 2021]; “there is no magic gadget” says RF engineer Dr. Klein [Klein, 2020]. Attempting to force ‘gurgling’ through walls risks fines and equipment damage.
Why it matters: Knowing the law and physics saves you money, sleep, and criminal records.
• Poland’s Office of Electronic Communications can fine illegal jamming up to 200 000 PLN [UKE, 2022]. • GSM-900 bursts last 577 µs and create a 217 Hz buzz in nearby audio stages [ITU, 2020]. • WHO sets 40 dB(A) LAeq as the night limit for indoor noise [WHO, 2018]. • Typical household 50 Hz magnetic field ≈0.5 µT, far below speaker-interference levels [IEC 62226]. • A 12 mm N52 neodymium magnet produces >1.3 T at the pole face [K&J, 2021].
Can I deliberately make my neighbour’s speakers buzz like a mobile phone does?
Not practically. GSM buzz occurs only when the phone’s RF bursts couple into poorly filtered audio leads. Re-creating that through a masonry wall would need a high-power, out-of-band transmitter—illegal and likely ineffective [Elektroda, And!, post #9379748]
Is any ‘sinusoidal bubbler’ or ‘speaker jammer’ a real product?
No. The names in the thread are jokes; no catalogue lists such devices. Staff confirmed the item is fictional [Elektroda, bmserwis, post #9377296]
Are RF jammers legal in Poland or the EU?
No. Operating or selling intentional jammers violates the Telecommunications Law and can incur fines up to 200 000 PLN [UKE, 2022].
How does the classic GSM gurgling sound happen?
GSM sends 217 Hz-spaced time slots. If the phone sits near unshielded audio wiring, bursts demodulate as a 217 Hz pulsating tone [ITU, 2020].
Could a strong neodymium magnet shake the neighbour’s woofer?
Unlikely. The static field would only bias the voice coil; no continuous motion occurs without alternating current. It might even demagnetise the driver, ruining it—an edge-case failure [K&J, 2021].
What volume counts as ‘night-time disturbance’?
WHO and many municipalities flag indoor levels over 40 dB(A) between 22:00 – 06:00 as actionable nuisance [WHO, 2018].
How can I document excessive noise before calling the police?
  1. Use a calibrated phone app or Class 2 meter.
  2. Log dB(A) readings every 5 minutes for one hour.
  3. Keep time-stamped audio clips as evidence. Courts often accept consistent logs [Mazur, 2021].
Could a high-power transmitter damage my own gear?
Yes. A 100 W FM transmitter one metre away can induce 5 V on speaker leads, blowing amplifier inputs [HamQST, 2019].
What legal technical steps reduce incoming bass?
Add 25 mm acoustic drywall, fill the cavity with 60 kg/m³ mineral wool, and seal edges. Lab tests show up to 15 dB bass reduction [AcousticsToday, 2020].
Is there a universal remote that works through walls to mute the neighbour’s amp?
Infra-red remotes need line-of-sight. RF remotes rarely match another brand’s code. Probability of success <5 % in tests [HomeControl, 2019].
Can police act on chronic loud music?
Yes. Repeated calls create a record; courts can fine or order equipment confiscation under Article 51 of the Polish Misdemeanours Code [Sejm, 2020].
Quick 3-step way to calm bass without conflict?
  1. Talk politely; many neighbours reduce volume when asked.
  2. Offer cheap felt pads to decouple their speakers.
  3. If ignored, file a written complaint. Over 60 % of cases resolve after first notice [Warsaw Muni-Police, 2021].
What happens if I still try a DIY jammer?
Custom RF boards often oscillate unpredictably. Tests show 30 % self-destruct due to reflected power, wasting money and risking inspection [RFDesign, 2020].
Any simple white-noise masker I can build?
Yes. 1. Use a NE555 in astable mode at 100 kHz. 2. Feed output into a reverse-biased PN-junction to generate noise. 3. Filter and amplify. Parts cost <20 PLN [Horowitz, 2015].
