HDMI Cable: Identifying Functions of Green, Orange, White, Brown Cables - DATEs, CLOCK, GND
DoktorVanHelsing 23586 4
  • #1 16581418
    DoktorVanHelsing
    I need help because I don't know what some of the HDMI cables are responsible for.
    What I know:
    - pink cover - DATE 2
    - blue cover - DATE 0
    - green cover - DATE 1
    - brown cover - CLOCK
    - clean cable - GND
    I need to know what the cable is:
    - green
    - orange
    - white
    - brown
    Additional info:
    - there are 2 cables in the covers, 15 cables in total (i.e. the mass is common for DATA 0, 1, 2, CLOCK and the gray cover)
    - green, orange, brown - 5V
    - white - 3V
    Picture showing the situation:
    Thank you in advance for your help ^^.
  • #2 16581504
    foxxer672
    Help: 47
    Rate: 161
  • #3 16581586
    DoktorVanHelsing
    I am very happy that you read my problem and saw what you sent, but the colors of the wires in my cable are different.
    But thank you for trying to help ^^.
    pepe150
    Level 36  
    Help: 288
    Rate: 939
    You can't measure from the other side is it an adapter?
  • #5 16581614
    DoktorVanHelsing
    That's right, I can check with a multimeter on which pin the wire is.
    Thank you ^^. I close the topic.
