Gas boiler room in the block. Heating from the city. What's cheaper?
spw_1 19573 4
  • #1 9466069
    spw_1
    Hello !
    I have a question, what is cheaper gas boiler room in the block or heating from the city?? I am going to buy a flat in which there is a boiler room and I am a bit afraid how it works and whether it is a really good solution.
  • #2 9466159
    zeimp
    Moderator on vacation ...
    Help: 548
    Rate: 2345
    In your place, I would not think about the choice and of course I would choose with "own" boiler room. I lived in a block of flats for several years, where we were addicted to the municipal boiler room. It just was ;) once it's hot, once all the radiators are turned on to the max and here they are barely lukewarm... Every winter there were problems, with the rest I have a lot of friends who also live in blocks of flats in different towns and they also have such problems. There are no such problems with your own, but it is a bit more expensive (at least it was). If I had to choose, I would choose a boiler room for a given block rather than a municipal heating plant. Regards.
  • #3 9466356
    spw_1
    It's these costs that make me wonder what the difference is.
  • #4 9466384
    zeimp
    Help: 548
    Rate: 2345
    You have to ask the building managements individually. Nobody will tell you ;) Well, unless you call your friends, let them tell you the amount of bills, pow. you can calculate the apartment yourself, but these are not big differences and certainly a more reliable source of heat in winter and, for example, in autumn. Regards.
  • #5 9467341
    DARIUS67
    Help: 63
    Rate: 337
    Perhaps these are different rates depending on the region of Poland. In my region, heating with a boiler room in a block of flats is cheaper than a heating center.
