Online Video Playback Issues on Pentium IV 2.8GHz, Radeon HD3450 512Mb, DDR DIMM 1.25 Gb
Drezyn 107121 9
How can I fix online videos that stutter or freeze during playback on my computer?
Check whether the problem also happens at the lowest quality (240p), because that can show whether it is a playback problem rather than bandwidth [#9479108] Update Flash Player and other browser components, and test the same video in Internet Explorer, Firefox, or another browser to see if Chrome is the cause [#9479108][#9479177] One suggested fix was to delete the contents of the cookies and temp folders, including Windows\Temp, after enabling hidden files and folders [#9544694] If the issue only affects some videos, it may be local software/cache trouble rather than the internet connection [#9550041]
  • #1 9479045
    Drezyn
    The problem is that when I start a movie online (e.g. YouTube), the movie cuts as if the disc was scratched. It's not the internet's fault, because only some of them freeze on my sister's computer. The question is: What can be done about it?
    The moderators told me to write the parameters (although in this case I don't know what it has to do with anything):
    Pentium IV 2.8GHz
    Radeon HD3450 512Mb
    DDR DIMM 1.25 Gb
  • #2 9479108
    wariato
    Help: 1213
    Rate: 840
    What quality do you watch these videos in? Even at the minimum setting (240p) is it the same?
    Do you have all Flash Players, Active X, Java, etc. updated?
    BTW, what browser?
  • #3 9479177
    Paolo1976
    Help: 43
    Rate: 424
    Does the same occur in Internet Explorer and Mozilla FireFox and other browsers?
  • #4 9479204
    Tommy82
    Help: 455
    Rate: 1074
    Maybe your switch is overheating and losing packets.
    Start->run->cmd
    Ping wp.pl -t
    and observe the moments whether they all arrive and whether their times are relatively stable.
  • #5 9479244
    wlw_wl
    Help: 208
    Rate: 148
    Maybe let's give the author a chance to fill in the necessary information before we delve into distant theories.
  • #6 9483631
    Drezyn
    Google Chrome browser, unfortunately my computer is currently under repair, so I can't check if it works, I don't know how to check it. is the flash player updated, etc. I will check in other browsers when I find a movie that jams on my sister's computer
  • #7 9483924
    wariato
    Help: 1213
    Rate: 840
    You can check the required updates using, for example: http://screen317.spywareinfoforum.org/SecurityCheck.exe
    BTW, after this repair it may turn out that the problem will disappear and we will probably not find out what is the cause. However, we are waiting for some information.
  • #8 9544694
    kajor85
    Hello, your problem (like mine until today) is related to the "junk" you have on your computer, it does not depend on the Internet connection, no lost packets or anything like that. Just go to "folder options", check it to show you hidden folders and files, and then go to the documents of all users via c: and delete all "cookies" files in them, i.e. the so-called cookies, and all files from the "temp" folders, also delete all files in the windows/temp folder. Just be careful not to delete the entire "temp", "cookie" etc. folders, just delete their contents. If you need anything, please write - I will help or guide you on how to do it. Regards!
  • #9 9548068
    jarecki221
    I'll join in on the topic. I have a problem with weak buffering of videos. Net works fine.
    I cleaned: ccleaner, clean registry, malwerbytes.
    When I entered the cmd command ping wp.pl -t: times from 49s to 250, i.e. varied.
    Where could the problem be? Browsers reinstalled: opera, mozilla. flash reinstalled.
  • #10 9550041
    Drezyn
    none of these things helped... I remind you that ONLY SOME online videos stutter. e.g. recently I wanted to watch the movie "Trainer" and it got stuck
The discussion revolves around online video playback issues experienced on a computer with a Pentium IV 2.8GHz processor, Radeon HD3450 512MB graphics card, and 1.25GB DDR DIMM RAM. The user reports that certain videos, such as those on YouTube, stutter during playback, while others do not. Various suggestions are made, including checking video quality settings, ensuring all necessary software (Flash Player, ActiveX, Java) is updated, and testing playback across different browsers (Google Chrome, Internet Explorer, Mozilla Firefox). Some responses suggest potential overheating issues or packet loss, while others recommend cleaning up system junk files, including cookies and temporary files, to improve performance. The user indicates that the problem persists even after attempting these solutions and emphasizes that only specific videos are affected.
