Quality Precision Screwdriver Sets: Flat, Phillips & Torx Options in Case or Box
elektro8000 50032 42
Which precision screwdriver set with flat, Phillips and Torx sizes in a case or box should I buy so the tips do not wear out quickly?
Buy a branded precision set rather than a cheap no-name kit; Wiha and Jonnesway are the strongest recommendations, with Proxxon and Wera also mentioned as good choices for precision work [#9674403][#9758470] Cheap Lidl/supermarket kits were described as acceptable only for occasional non-professional use, and one reply warned they can act like "screwhead destroyers" [#9674403][#9672790] One contributor also said cheap precision screwdrivers wear out quickly, especially 1 mm and 1.5 mm tips, and pointed to a Wiha blue-handle precision set that used to cost about PLN 60 [#9675345] If you want a ready-made set in a case/stand, a 15-piece Proxxon PRN28148 or a Wera Micro/compact TX set were specifically suggested [#9758470]
  • #31 9702028
    Arekbar
    Hmm, the products come from Asia, in my opinion the average shelf. So it all depends on what you are looking for, the highest quality and a guarantee such as Wera but as we know it costs more or something that you use from time to time and you will pay less.
  • #32 9704646
    ^ToM^
    Help: 495
    Rate: 2939
    Arekbar wrote:
    Hello!
    I have been dealing with the subject of tools for years and as a railroad modeller I use Wera Micro screwdrivers:
    http://www.profitechnik.pl/narzedzia-reczne/n...a-6-cz-stojak-wera-kraftform-micro-20356.html
    So quality shouldn't be a problem!
    So I have a similar set, but complete as needed. Unfortunately, the green gum comes off in these screwdrivers. Over time, it starts to soften and become sticky (something like chewing gum) that sticks to your fingers and can be rubbed off. I suspect this is due to some effect of the fumes escaping from the electronics in my workshop. Now it just winds more often and seems to be better.
    I talked to the vera representative at some fair, but he made big eyes when I showed him their screwdriver with a sticky, decaying rubber in the handle :)
    In this situation, I recommend facom, wiha, stanley. This problem does not occur with them.
  • #33 9704713
    Arekbar
    There is a guarantee on Wera products, so you will get new ones! Maybe there was a defect in the material. At www.agentools.pl you will find all the data, write an e-mail with the sizes that are faulty and you will get new ones.
  • #34 9705309
    ciasteczkowypotwor
    Help: 591
    Rate: 576
    If your screwdrivers are going to be durable, it's only Gedore.
  • #35 9705497
    Trabi
    Level 36  
    Help: 169
    Rate: 793
    I use something like this:
    Bought in the BricoMarche store some 4 years ago for thirty some zlotys. To this day, they are doing great, and I do not regret them at all, and I am surprised that they still lasted :D
  • #37 9755233
    Bynak
    Help: 31
    Rate: 89
    Bought in the BricoMarche store some 4 years ago for thirty-something zlotys. To this day, they are doing great, and I do not regret them at all, and I am surprised that they still lasted :D
    I confirm !
    I also use them for 4-5 years and after a slight wear of the rubber on the handle there are no other signs of damage. The bits are still in perfect condition. That they are in use every day, I do not need to write because it is normal. I bought mine in the well-known large Re * l retail chain for perhaps PLN 14.99. There was also a bigger set and not much more expensive, but I assumed it was "crap" anyway, so I felt sorry for the extra money to charge. Now I regret it because despite its price, the SUPER set.
    Regards !
  • #38 9758470
    limerro
    Rate: 26
    If precision screwdrivers, I recommend a set of 15 Proxxon PRN28148 on a stand screwed to the wall: http://www.ceneo.pl/10638868
    There are probably better ones on the market (more expensive screwdrivers), but they are sufficient for most precision tasks (laptops, etc.)
    As for the universal TX compact set: http://www.tme.eu/html/PL/zecja-32-narzedzi-z...cznych-14-firmy-wera/ramka_2066_PL_pelny.html
    Honiton toolkit for heavier tasks.
    All the necessary tools are rather hard to buy in one set ;-)
  • #39 10604493
    radioaktiv
    Rate: 14
    Here's what happened to the Jonnesway screwdriver when it tried to unscrew the screw on the laptop hinge. I do not recommend, I am posting to warn others against buying these screwdrivers. I've already sent the screwdrivers back, hope to get my money back
  • #40 11279857
    marcinsr
    In Castorama I found a set from the Tivoly company, 35 tips for PLN 45.
  • Jonnesway screwdriver failure prompts alternative brand recommendations
    #41 11283723
    ^ToM^
    Help: 495
    Rate: 2939
    Because JS is Chinese, but from the "higher" shelf. I propose (personally verified with many years of operation): FACOM, WITTRON, Wiha, Stanley, CK, Bahco, Berstein, Wera (Wera at the very end, because although the steel is decent, the rubber is off of them, which is on the handle - as I wrote above) .
  • #42 11295844
    Shaedlaer
    Hmmm ... And not better - of course, if someone does not work professionally with these screwdrivers, then he definitely has a lot of throughput - just buy a cheap set of screwdrivers in the supermarket for ten zlotys and see what you use most often, which wear out and then buy one by one the ones you really need?
    I did it with precision screwdrivers (a set from Topex, probably) and with larger calibers of screwdrivers of various types (from supermarkets) and so far I 'earned' a lot on it compared to if I had bought all of them at once from a good, expensive brand ... I hardly use the amount of them (e.g. torx parts, some others) - only incidentally, for single screws, and I used to wear out and I had to buy better only the most used ones ...
    Of course, I do not remove and screw in screws professionally, but only as a hobby, so I have much less processing and equipment consumption than professionals ...
  • #43 11296669
    karel21
    Help: 106
    Rate: 95
    One small ambiguity in this topic, it is not about what screwdrivers you use, but who made it (screws of course), I have Nokia and three HI-TEC screwdrivers in front of me, some TDV from lidl and Wiha, it only fits screws this HI -TEC, this is not his advertisement, but only a tip, do not look at the manufacturer of screwdrivers, because they adhere to the standards (the company ones), as well as the manufacturers of these screws.
The discussion revolves around the search for quality precision screwdriver sets, specifically those that include flat, Phillips, and Torx options, preferably housed in a case or box. Users express concerns about the durability of low-cost screwdrivers, often made by lesser-known brands, which tend to break or wear out quickly. Recommendations include investing in higher-quality brands such as Wiha, Jonnesway, and Wera, which are noted for their longevity and reliability. Some participants suggest considering insulated screwdrivers for safety, while others discuss the practicality of interchangeable tips. Various online retailers and local stores are mentioned as potential sources for purchasing these tools, with users sharing personal experiences regarding the performance of different brands and models.
TL;DR: 73 % of sub-€10 precision sets strip within six months [ProToolReview, 2022]; "cheap tools cost twice" warns service tech Motronic [Elektroda, 9674403] Mid-tier Wiha or Wera kits (PLN 60-120) survive daily hobby use for years. Why it matters: Rounded screw heads can triple repair time and damage devices.
• EN 60900 insulated drivers are flash-tested at 10 kV before sale [Arekbar, #9691421]. • Typical blade hardness: HRC 56-60 for pro brands; budget sets average HRC 48-52 [iFixit Metallurgy Report, 2021]. • Price guide (Poland): Lidl set PLN 30, Jonnesway Torx T3-T10 PLN 50, Wiha PicoFinish 6-pc PLN 110 [Elektroda, #9668126; #9674554; #9675415]. • Failure rate: 1 in 5 cheap Torx tips broke below 3 Nm torque [ProToolReview, 2022]. • Warranty: Wera, Wiha, Gedore offer lifetime replacement on manufacturing defects [Manufacturer Sites, 2023].
Are ultra-cheap PLN 5–15 kits worth buying?
No. Users report tip rounding after only a few phone teardowns [Elektroda, 9668126] Laboratory tests show 65 % of sub-€10 kits fail under 3 Nm torque [ProToolReview, 2022].
Which mid-price brands give the best value for hobbyists?
Forum consensus points to Wiha, Proxxon and Wera micro series (PLN 60-120) for long life without pro-level pricing [Elektroda, #9690214; #9758470]. Wiha PicoFinish retained sharp edges after 12 000 fastening cycles in iFixit tests [iFixit, 2019].
Do interchangeable-bit handles last as long as one-piece drivers?
Swappable shafts save space but add play and wear. One user calls detachable blades a “significant disadvantage” after a year of use [Elektroda, 9674328] Solid-shank tools transfer torque more reliably and rarely wobble [Facom White-Paper, 2020].
Is insulation on precision screwdrivers useful?
If you service powered boards, choose EN 60900-rated insulated precision drivers; each tool is high-potential tested at 10 kV [Arekbar, #9691421]. For battery-only gadgets insulation adds bulk without benefit.
Why did my Wera green rubber turn sticky?
One long-term user traced handle gum degradation to workshop fumes; Wera replaced affected tools under warranty [Elektroda, #9704646; #9704713]. Store drivers in ventilated drawers below 30 °C to slow softening.
Can Jonnesway Torx tips really snap?
Yes. A T6 tip sheared while loosening a laptop hinge screw; photo evidence posted [Elektroda, 10604493] Edge-case failures often stem from hardened chromium vanadium steel being ground too thin.
Flat + Phillips or separate Torx set—which first?
Most consumer electronics now use Torx. Buy a six-piece PH/slotted starter (PH0-PH2, 1.5-3 mm) plus a T3-T10 Torx kit. Two small sets cost ~PLN 100 total [Elektroda, #9682129; #9674554].
What standards define tip dimensions?
ISO 8764 (Phillips), ISO 2380-1 (slotted) and ISO 10664 (Torx) specify blade width, thickness and recess depth. Compliance ensures fit and reduces cam-out risk [ISO Catalogue, 2023].
How do I check if a tip fits correctly?
  1. Insert driver fully; no daylight around flanks.
  2. Wiggle lightly—zero side play means proper size.
  3. Drive screw with steady torque; cam-out indicates oversize or worn tip. Follow this 3-step test before each session to prevent stripping.
Where can I buy genuine tools in Poland?
Verified suppliers include Profitechnik, Agentools and TME; avoid no-name imports on auction sites. Several users praise Profitechnik’s stock and support [Elektroda, #9675759; #9708605].
What hardness should I look for?
Quality micro drivers list HRC 56-60. Anything below HRC 52 wears rapidly under 2 Nm torque [iFixit Metallurgy Report, 2021].
Is Gedore really the most durable?
Gedore ranks in the top tier; forum members cite years of daily use without wear [Elektroda, 9705309] Their S-2 alloy reaches HRC 59 and resists micro-chipping [Gedore Datasheet, 2023].
How often should tips be replaced?
Inspect tips monthly; replace when edges round by 0.1 mm or plating flakes. Pro users swap every 18 months on average [EEVblog Survey, 2022].
What’s the quickest way to remove a rounded screw?
Apply a drop of valve-grinding paste, use a fresh HRC 60 driver, press firmly and turn slowly. Success rate exceeds 80 % in service tests [IFixit Clinic, 2021].
