Gamepad Shark SH814 - reducing sensitivity, setting the knobs from rain
Brianek 43573 5
  • #1 9778529
    Brianek
    Hello. I bought a PC Shark SH814 PC USB PAD http://www.in4.pl/news_SHARK_SH814_PC_USB_PAD_ and_SH822_PS2_GAMEPAD,23217.htm I specially spent the money to play via the net on the pad because of the `` knobs '' that can be controlled at any angle - there is only a problem that the sensitivity is too high, I will slightly move the knob to the right and immediately turn to the max, I have to really move the knob slightly to make it turn slightly. Is there a driver or a program to change the sensitivity of analogues? I have a driver that I installed, but this driver is only for cradle detection, there is no .exe to fire up and bury myself. I would like to ask for help, I spent money on purpose to buy a pad and play with my friends via the net, I couldn't buy a steering wheel, and they have - I would like to ride these analogs on the pad and I would like to reduce their sensitivity, I hope there is some program / addition to F1 2010 to set the knobs from rain.
    Regards.
  • #2 9778912
    DriverMSG
    Help: 3984
    Rate: 4880
    Have you turned on analog mode in your joypad? In the game options there should be settings for the twist sensitivity of the analog controllers.
  • #3 9780649
    Brianek
    Yes, the red light is on, which is the symbol of the analogs turned on. And there are no such settings in the game. There is only steering sensitivity, and the steering wheel does not detect me. - Normal.
  • #4 9780772
    DriverMSG
    Help: 3984
    Rate: 4880
    I don't know about F1, but the emulator from the attachment works well in Dirt3 - check it out.
    Emulates the XBox controller in games adopted from this console.
    • xinputemu3.0.zip (155.58 KB) You must be logged in to download this attachment.
  • Split-screen start button not detected on second pad
    #5 19122239
    raul79
    hello, the emulator works and the game works on the pad.
    The problem arises when I want to play 2 pads on a splitscreen ...
    I have 2 the same pads and although both work under FIFA and you can play both at the same time, here is the problem ...
    At the moment when you need to press start on the second pad, there is no reaction ... it looks as if the game is waiting for a "start" from another pad, because he sees both of mine as one ... (in the 1-player mode, you can play both on one and the second pad, but in the mode for 2, unfortunately not ...)
    is there a magic way out?
    (I will add that if we press this "start", for example with the keyboard, the splitscreen works and goes to play, but only in the pad + keyboard version)
  • #6 19146208
    DriverMSG
    Help: 3984
    Rate: 4880
    Check with the Xpadder application.
