  • #1 18339531
    spxch
    Hello, 3 weeks ago I bought a Genesis PV58 game controller. Recently, unfortunately, during the game in FIFA 20, instead of one diode, four were blinking vigorously. This is how it is until now, no matter what device I connect to. It's just that the LEDs on the pad blink quickly and you can't do anything with the pad itself (only when I click the HOME button, the LEDs change the blinking frequency). I will add that the computer detects the controller. I can't return it under warranty because I lost the receipt. Thank you in advance.
  • #2 18339906
  • #3 18340595
  • #4 18340614
  • #5 18340622
  • #6 18341144
    spxch
    Thank you all for your reply. Unfortunately, none of the given ways helped, if anyone else has an idea, please do; I care a lot about it.
  • #7 19248479
    fifi0298
    Hello, I had the same problem, in my case it helped to unscrew the pad and disconnect its battery for a while.
  • #8 19642103
    CalixGames
    Temporarily disconnecting the battery from the pad really works, thank you in advance ;)
The discussion revolves around issues with the Genesis PV58 game controller, specifically a malfunction where four LEDs blink rapidly, indicating a failure to connect with the transmitter. Users suggest troubleshooting steps, including checking USB connections, ensuring the controller's battery is charged, and minimizing interference by using different USB ports. Some users report success by temporarily disconnecting the battery of the controller. Despite these suggestions, the original poster has not found a solution that resolves the issue.
