Logitech f710 pad problem - Logitech f710 pad changed Y axis in the fify 19 demo
simijimmy 7203 9
How can I fix the inverted Y axis on a Logitech F710 controller in the FIFA 19 demo?
Switch the Logitech F710 from D mode to X mode before launching the game; this fixed the inverted Y axis for multiple users [#17467131][#17467212] One reply says it worked after installing the Xbox emulator and then switching the pad to X mode [#17467212] If the controller is not detected in X mode, another user resolved the “not working under X” issue by following a YouTube guide for X input [#17467630]
  • #1 17441438
    simijimmy
    Logitech f710 pad does not work properly in the fify19 demo. The problem is that analogs shifted upward cause downward movement and vice versa. In previous fifs the pad works normally so it's probably a problem with the game settings and it doesn't rain but I can't handle it and please help.
  • #2 17441845
    Ramiro Roberto
    Help: 12
    Rate: 28
    First check that the analogues work properly, to do this run the gamepad configuration program.
    What is the problem with the controller configuration in the game? Can't find the option there or something else?
  • #3 17441962
    simijimmy
    The analogs work properly because in the previous fifs and in the configuration program they work as they should the problem with the configuration in the game is that there is no such ... only ready sets of settings for manual configuration control are missing or I am not aware of it
  • #4 17441993
    daminek1234
    Help: 61
    Rate: 88
    Inversion of the vertical axis in options.
  • #5 17442070
    simijimmy
    If I knew where I would find such an option I would probably do it
  • #6 17467131
    dusiajanuary
    hey, same problem but solved, I think I will please a lot of F710 owners ;)
    in the middle at the top you need to switch mode d -> x
    do not do during the game only before running
    it worked for me as he took it away
  • #7 17467194
    pkrmistrz
    I have the same problem with the inverted Y axis, but after switching d> x I can't see the controller. Anyone have any ideas on how to deal with this problem?
  • #8 17467212
    pekirahu
    I installed the xbox emulator and switched to X and it works :)
  • #9 17467630
    pkrmistrz
    I dealt with the problem of not working falls under X - https://www.youtube.com/watch?v=pfQ8HN5QEks
    Regards
  • #10 17696381
    UBiaszek
    I have the same problem and when I want to do the same as in the guide from yt above, there is a problem that you can't choose xbox drivers in drivers
The Logitech F710 gamepad experiences an issue in the FIFA 19 demo where the Y-axis controls are inverted, causing upward movements to register as downward and vice versa. Users confirmed that the analog sticks function correctly in previous FIFA titles and in the gamepad configuration program. A suggested solution involves switching the gamepad mode from D to X before launching the game, which resolved the issue for some users. However, others reported difficulties in recognizing the controller after switching modes and issues with selecting Xbox drivers. Additional solutions included using an Xbox emulator to enable proper functionality.
