How to Check Drive Joint: Outer Joint Play & Vibrations in Passat 1.9 TDI 105 KM 2006 Model
T5 95482 15
Can I check whether the outer CV joint on a 2006 Passat 1.9 TDI has acceptable play, and what causes steering/body vibrations and knocking at speed?
The outer CV joint should not have any noticeable play; if you lock the driveshaft and can still move the wheel, the joint is worn and should be replaced [#9839236][#9841996] Some worn joints only knock under load or at full steering lock and may not show obvious looseness when checked by hand, so a quiet test does not prove the joint is good [#9839157][#9839676] For vibrations, also check the inner joints, because play there can transmit vibrations into the body, and verify wheel balance, tire bulges, rims, and suspension/stabilizers [#9841970][#9839157] One practical diagnosis is to cool the outer joint housing with spray freezer during the noise and then drive again; if it gets quieter for a while, the outer joint is likely the source because heat can increase the play [#9842389] If the joint is already clattering, cleaning or relubricating usually will not fix it, so replacement is the real repair [#9842389][#9842440]
  • #1 9839101
    T5
    Admin of Cars group
    Help: 1004
    Rate: 4182
    Can the outer joint have play? When I grab the driveshaft, I can move the wheel about 0.5 cm. Patient is a passat 1.9 tdi 105 KM. 2006. You can feel vibrations on the steering wheel, but the steering wheel does not fly. You can also hear the knock, which starts at about 80 km / h and increases with the speed. the outside temperature, the warmer it is, the louder it breaks. Most of the key is on a smooth road as smooth as a table. If the road is slightly uneven and you drive up to 100 km / h - quieter. In the morning, these are typical symptoms of a damaged bearing reacting to turns after a dozen or so kilometers passes. The car with this symptom is already driving about 7000 km and nothing wants to fall apart until the end :D .
    On corners, when starting quickly on twisted wheels - silence.
    How to check the joints?
    jastrzą1975
    Help: 6
    Rate: 23
    First, a few words about the wrist. There should be no play at all, but the more kilometers on the dashboard, the greater the wear. When it is really damaged at the maximum turn and drive on one, you will hear a knocking.
    You can remove the vibrations on the steering wheel in a workshop with a wheel balancer. Check the balance and carefully check the tread for a lump. There will probably be a tumor.
    Once the bearing starts to rustle, it will stop only after replacement.
  • #3 9839195
    T5
    Admin of Cars group
    Help: 1004
    Rate: 4182
    New tires. The same for the old ones. For the trial, I put on winter tires - no changes.
    There is no vibration on the steering wheel, but you can feel the vibration. On the counter 120,000 real.
    Can the outer joint have play? What is allowable?
    zeimp
    Moderator on vacation ...
    Help: 548
    Rate: 2345
    Yes, the joint may have play, but it shouldn't. If you lock the driveshaft, you cannot move the wheel. It does not have to knock when turning, as the colleague described above, and the vibrations will be transferred to the car body in such a way that sometimes it is really hard to find the cause. If there is play, just replace it (joint), but I assume that the suspension and stabilizers are ok! There is no slack in there!
    Because it will not fall apart if the client can skillfully start with the wheels turned. There were just such joints (I've already changed a few myself) that after a dozen or so thousand. kilometers were just getting this kind of slack ...
  • #5 9839576
    mczapski
    Level 40  
    Help: 468
    Rate: 1659
    The clearance mentioned here is probably total of the joints, the spline and the differential. that is, about 0.5 cm around the circumference is not much. I would look for reasons in suspension in this geometry. The placenta can cause this behavior, but it breaks down quickly. If you do not hear a knocking noise when turning, the articulation is not likely to be excessively worn.
    ociz
    Help: 1379
    Rate: 3486
    Sometimes a damaged joint has no play and sometimes they ride with a lot of slack. I take the joints apart and wash them as I want to be sure of the damage.
  • #7 9841382
    jastrzą1975
    Help: 6
    Rate: 23
    Did you put these tires on the same rims? If you are sure about the tires, check the rims for sideways runout. You can remove the wheels, engage the gear and watch for the discs to run out sideways. Perhaps some caliper rubbed on the guide and the slightly curved disc will give a similar symptom, only when braking it will feel vibrations on the steering wheel.
    toku74
    Help: 123
    Rate: 729
    It is probably only new that there is no slack. I don't know if it will help you, but:
    1. I hit a mazda once, which "clicked" on a bend. I say the wrist. Out of curiosity, I take it apart, wash it, and watch it. Balls- flash, runners zero wear / without any breaks in the middle part /, basket- great. I think multi-wedge. Check, tight. Put it back on, with new grease and cover. twist-click. Customer brought some quinol. I assume, twist-silence.
    2. volvo and bmw. Knocks when starting and braking. Suspensions after replacement. It turns out lumpy grease in the joints. In the service point, the repair of this is called: lubrication of the axle shaft spline.
    As for the vibrations on the cooker, none of them was supposed to vibrate.
    bandi21
    Level 30  
    Help: 126
    Rate: 655
    Check the inner joints, if there is any play, there will be vibrations on the body.
    robokop
    Help: 1763
    Rate: 6372
    The hinge must not have any play. I will say more - the so-called The "apple" inside should sit tightly and it is difficult to move your fingers. I would take them out, clean them and lubricate them, both inside and outside.
  • #11 9842093
    T5
    Admin of Cars group
    Help: 1004
    Rate: 4182
    The inside have no slack. I mean how grandpa check. I know for sure that it's the left side.
    The external person on a trip to this model costs about a cent. I will buy it and see if it comes.
    However, the topic is as topical as possible. rate with all due respect-you undress the one that has slack and works flawlessly and the one that has no slack. How to verify if it is a clatter?
    bandi21 I know a typical symptom of an inner joint (the shed flips sideways) and here is something else, it is not typical.
    in progress74 I found a sharan who started to patter after 200km of continuous driving, it was external.
    robocop The cover is whole and still original, where would the dirt come from? On the other hand, be honest, did disassembling, cleaning and re-lubricating ever help?
    In the old years there was such a patent "on the stock exchange". A plasticine box under the cover and the wrist was silent.
    Where does the temperature dependence come from? Something like - the hotter the asphalt, the louder the rattling noise.
  • #12 9842389
    zeimp
    Help: 548
    Rate: 2345
    Well, because the outer part of the joint is closest to the brake disc and it heats up more than the "center" (physics and reality), and at that time even more play is created on the driveshaft / wheel. If you have a spray freezer, then during the loudest work / knock, I recommend that you cool the outer part of the joint quite strongly (the one that you put on the flexible cover) of the joint and perform a test drive. It should be quiet for a while.
    As for lubrication and washing, I will say that if the joint is already "clattering", nothing will help it!
    wopor
    Level 32  
    Help: 175
    Rate: 705
    Hello, often the reason for such a knock is a sharp hitting the curbstone or something similar and bad luck that at this point it will hit the ball perpendicularly and it will squeeze a hole, and knock only in the setting of the hit, :D I have already met a few such joints and replaced them, and the tapping one I dismantled and only under the glass it was visible, and washing and cleaning the joint and reassembling it is unprofitable and dirty :D , the joints do not cost money.
  • #14 9842476
    T5
    Admin of Cars group
    Help: 1004
    Rate: 4182
    wopor I know that they do not cost a fortune, but I am looking (and not only me) for a method to find out which clicks it is.
    Not so long ago, I found out in a car that it was the left side. I replaced it with a new one and a dup ... So I quickly put the left side on the right side (I put a new one on the left side) and it helped.
    zeimp My dear friend, the discs are unlikely to heat up when driving on the motorway.
    And today the t5 driveshaft has been replaced.
    Maybe you have a link to a page on a similar topic.
  • #15 13193769
    hipeck
    Rate: 18
    I will come back to the topic, because after reading the posts, I have some unusual symptoms. It's not a knock-knock. On twisted wheels, I can hear and feel like I'm driving on a coarse grater. Something like running into the stripes painted with structural paint. About 2 weeks ago I attacked the curb with my left wheel too hard. What do you think about this situation? greet
  • #16 13197392
    zeimp
    Help: 548
    Rate: 2345
    We think that without checking exactly what has broken, it is a wish for everything and nothing! You have to check, fix and that's it - don't philosophize!
The discussion revolves around diagnosing issues with the outer drive joint of a 2006 Passat 1.9 TDI 105 KM, particularly concerning play, vibrations, and knocking noises. Users confirm that while some play in the outer joint is possible, it should ideally be minimal. Symptoms such as vibrations felt in the steering wheel and knocking noises at higher speeds are noted, with suggestions to check wheel balance, tire condition, and suspension components. Recommendations include inspecting the inner joints for play, cleaning and lubricating joints, and considering replacement if excessive wear is detected. The impact of temperature on joint performance is also discussed, with advice to cool the joint during testing to identify issues.
