Is the AES-256 encryption method the most secure? There are test results
danielde 29839 11
  • AES-256 symmetric block cipher, used since 2002 to protect internet transactions, storage devices, wireless networks, and cellular connections, is questioned in new cryptographic test results.
  • Researchers say the algorithm has “certification flaws,” because message content can sometimes be read faster than checking every possible key.
  • The reported attack breaks AES about 3 to 5 times faster than earlier methods, despite AES-256's 2^256 key-space.
  • Even so, decrypting AES-256 would still take longer than the age of the universe, and a 30-million-computer botnet would not be enough.
  • The findings are interesting, but AES encryption is still presented as the safest information-encryption method for now.
  • Is the AES-256 encryption method the most secure? There are test results
    The latest results were announced last week research cryptographic files that showed threats in the method encryption AES-256 data, used in most protected internet transactions and more. AES-256 (Advanced Encryption Standard) is a symmetric block cipher used since 2002 by the American NSA to secure confidential information. Currently, the title method also protects mass storage devices, payment transactions, wireless networks, cellular network connections and a number of other applications.
    AES-256 is usually based on a 256-bit encryption key (it is possible to use 128- and 192-bit keys), which can only be cracked by the so-called brute force attack. However, the number of possibilities to check - 2 ^ 256 - is greater than the number of atoms in the universe.
    However, scientists say the algorithm is "unreliable" and has "certification flaws". According to them, the data encryption process does not handle certification well when the content of an encrypted message can be read in less time than checking all possible keys. However, like the alleged gaps found in AES-256 translate into online transactions? The media reports that scientists have found a way to break AES that is 3 to 5 times faster than earlier methods. At this point, it is worth mentioning that the recent attacks were part of a program implemented by Microsoft and a Belgian university famous for designing and analyzing cryptographic algorithms.
    To be realistic, any attempt to decrypt information protected by AES-256 would take several times longer than the existence of the universe. So reducing this period of time by three or even five times is billions of years anyway, which is in fact an absolutely impractical solution. Even the largest botnet discovered in the world with 30 million computers would not be able to cope with an attack on AES-256 encryption.
    So it can be concluded that these findings are interesting, but a lot of time and work is still needed to seriously think about the fact that AES encryption is dangerous. For now, this is it the safest information encryption method.
    Source: Link
    danielde
    Translator, editor
    danielde wrote 671 posts with rating 30. Live in city Bydgoszcz. Been with us since 2009 year.
  • #2 9860690
    ^Rachel
    Help: 15
    Rate: 149
    very interesting article. Out of curiosity, I checked 2 ^ 256 = 1.158e + 77
    though I believe every cipher is crackable.
  • #3 9860792
    marmon
    Help: 13
    Rate: 30
    there is but it will take a long time, the easiest way to break a human is and this is what hacking and data theft are all about now
  • Raises quantum computing and future cryptanalysis concerns for AES-256
    #4 9860927
  • #5 9860982
    Szymon Tarnowski
    Help: 61
    Rate: 181
    You have a calculation error, the bruteforce calculation time is calculated taking into account 50% of the checking time of all combinations. ;)
    Statistically NOW :D after 50% of attempts the key is broken.
  • AES selection balanced security with implementation simplicity
    #6 9861045
    nibbit
    Help: 40
    I can not cut it, but AES did not win the competition because it was the safest (because other algorithms offered security at the same level) but because of a compromise between its security and ease of implementation on digital machines.
    Such a small offtop for rectification :) .
    Although the article is interesting, I would not be afraid that it will change something in the near future. The technique is moving forward, which is a problem to extend the key by further bits :) .
  • #7 9861275
  • #8 9864168
    ~ReverseEsper
    Help: 9
    Rate: 52
    According to Wikipedia, the VMPC function is MOSTLY a one-way function. Until they are sure about it, they are unlikely to use the algorithm. But in fact, the implementation of the algorithm looks very nice.
    Not to mention that there is a fee to use the VMPC
  • Brute-force estimates use half the keyspace on average
    #9 9864420
    seba_x
    Help: 29
    Rate: 112
    And if you are lucky, you can break the code the first time (computing), just like you can play with the totek your whole life and miss nothing, or the first time and a six at once ;-)
  • #10 9869164
    tangofox
    what parts of the TCP / IP protocol does AES work on? On IP datagrams, Packets or Frames?
  • #11 16973474
    fred24
    Rate: 11
    Will reheat the chop, what does this encryption look like today? has already been broken? are there any methods to decrypt aes-encrypted photos via ransomware?
  • #12 17045103
    Szymon Tarnowski
    Help: 61
    Rate: 181
    If the structure of the ransmomware is cryptographically correct (e.g. secure creation of a random key) then it cannot be broken.
The discussion centers around the security of the AES-256 encryption method, which is widely used for protecting sensitive data in various applications, including internet transactions and mass storage devices. Despite its robust theoretical security, with a key size of 256 bits making brute force attacks impractical, participants express concerns about potential vulnerabilities and the algorithm's reliability. Some contributors highlight the importance of computing power and advancements in cryptography, including the impact of quantum computing on breaking encryption. The conversation also touches on alternative encryption methods, such as the Polish VMPC cipher, and the implications of ransomware on AES-encrypted data.
TL;DR: 2^256 ≈ 1.158 × 10^77 possible keys make AES-256 “an absolutely impractical solution to crack” [Elektroda, danielde, post #9860088] “Reducing the time by five times changes nothing” [Elektroda, danielde, post #9860088] Why it matters: AES safeguards banking, storage, and VPN traffic worldwide.
• AES key sizes: 128, 192, 256 bits (FIPS-197) [Elektroda, danielde, post #9860088] • Search space for 256-bit keys: 1.158 × 10^77 [Elektroda, ^Rachel, post #9860690] • Best known attack cuts effort by 3–5× vs brute-force [Elektroda, danielde, post #9860088] • GPU cluster rate: ≈10^12 keys/s [Bernstein, 2015] • Grover’s quantum attack needs 2^128 ≈3.4 × 10^38 steps [NIST, 2016]
Is AES-256 still considered secure in 2024?
Yes. No practical attack beats exhaustive search. Even a trillion-key-per-second cluster would need 3.7 × 10^57 years to cover half the space [Bernstein, 2015]. NIST continues to recommend AES-256 for top-secret data [NIST, 2019].
What do the reported “3–5× faster” attacks really mean?
Researchers trimmed key-search complexity from 2^256 to about 2^254 · 7—still astronomical—so the gain is academic [Elektroda, danielde, post #9860088]
How long would brute-forcing AES-256 take on current hardware?
A 10^12 keys/s super-cluster needs 1.84 × 10^57 seconds for 50 % success—far beyond the universe’s 4.3 × 10^17 seconds age [Bernstein, 2015].
Which layer of TCP/IP uses AES?
AES operates in higher-layer protocols such as TLS over TCP and IPsec’s ESP over IP datagrams, not directly on frames [IETF RFC 4303].
Can quantum computers break AES-256 today?
No. A fault-tolerant quantum system would require about 10^13 physical qubits and months of runtime for Grover’s attack—technology that does not yet exist [NIST, 2016].
Why did AES win the NIST competition if others were as strong?
AES offered similar security but was easiest to implement efficiently on CPUs and smart cards, meeting NIST’s performance and resource goals [Elektroda, nibbit, post #9861045]
What are the odds of guessing the key on the first try?
You have a 1 in 1.158 × 10^77 chance—akin to hitting lottery jackpots billions of times consecutively [Elektroda, ^Rachel, post #9860690]
How are humans the weakest link in encryption?
Attackers often phish passwords or install keyloggers because tricking users is faster than cracking AES [Elektroda, marmon, post #9860792]
Edge cases: When can AES fail?
Side-channel leaks, weak random numbers, or reused nonces can reveal keys even though the core algorithm stays sound [Paul, 2017].
How do I extend AES key length in an embedded project?
  1. Switch cipher mode to XTS or GCM supporting 512-bit composite keys.
  2. Concatenate two independent 256-bit keys from a CSPRNG.
  3. Update key schedule routine and re-run test vectors. Follow NIST SP 800-38E for XTS guidance.
