Welding Current Settings: Guidelines for Proper Amperage and Electrode Size Selection
Dam_MS 137711 6
  • #1 9925074
    Dam_MS
    Rate: 12
    What current?
  • #3 9926794
    Dam_MS
    Rate: 12
    So in my case the current I need to set is 130 A?
  • Recommended welding current: 3040 A per millimeter
    #4 9929670
    ^ToM^
    Help: 495
    Rate: 2940
    Dam_MS wrote:
    Hello, I am a beginner in electrode welding. I have a question, what current should be set using the electrode Fi 3.25 by 4 mm ?
    I heard that the amount of current we operate depends on the diameter of the electrode - is the thesis with the multiplication of the diameter by 30 authentic? If not, how to convert it.
    Yes it's true. 30-40A per mm electrode So for 3 it will be between 90-120 and for 4 it will be between 120-160A. For elements made of thicker steel, we use the upper range.
  • Choosing welding current from electrode ratings and burn-through signs
    #5 9929802
    jump$
    Help: 7
    Rate: 115
    The manufacturers of electrodes provide their own parameters that are similar to each other, the welding current for a dedicated electrode is specified on its box or you can check the symbol on the electrode cover, i.e. welding current, purpose. It also matters whether the electrode is medium or thickly coated.
    You have to choose the welding parameters yourself, e.g. the amperage (welding current), you should feel it yourself, when the electrode starts sticking to you, you increase the current, because melting is important, overheating around the weld must be visible, but there must be no undercutting of the material, and for heavier things, you have to set a lower welding current so as not to burn the material and it is rather melting, or use smaller electrodes and take breaks.
    Sample dependency table:
  • #6 9930089
    SKM 1964
    Help: 150
    Rate: 661
    If you weld a little longer, you will get to the practice yourself. You won't need any tables. And at the beginning, the welder should have a smooth current control. Then it is easier to choose the welding current and try not to flash in your eyes.
  • #7 10374872
    Dam_MS
    Rate: 12
    Thanks, I'm almost perfect :)
    To close
The discussion focuses on selecting appropriate welding current settings based on electrode size. A guideline suggests using 30-40A per mm of electrode diameter, with specific ranges for 3mm (90-120A) and 4mm (120-160A) electrodes. It emphasizes the importance of following manufacturer specifications found on electrode packaging and adjusting amperage based on the welding conditions to avoid issues like sticking or undercutting. Practical experience is highlighted as crucial for mastering current control, with a recommendation for smooth current adjustment to enhance the welding process.
