BIOS Won't Start After Computer Reassembly: System Failure, Motherboard Cleanup, No Signal
esteem20 47900 32
Why does my PC power on after cleaning/reassembly but show no BIOS signal or display, and how can I diagnose it?
Check the basic connections first: verify all power and signal cables, then reseat the graphics card and RAM, because the power LED being off can simply mean its front-panel cable was unplugged or reversed [#10100021][#10100024][#10100056] If that does not help, test the board outside the case in a minimal "spider" setup with only the motherboard, CPU and speaker, and briefly short the POWER pins to start it; if the BIOS is healthy it should at least beep about missing RAM/GPU [#10101762] In the thread, the board produced no beep even in that setup and shut off after a few seconds, which points to a motherboard/CPU problem rather than the graphics card or RAM [#10103006][#10103626][#10103677] Also check that the CPU cooler is mounted correctly and try a CMOS reset by removing the battery for a few minutes [#10103406][#10103725]
  • #31 10103804
    Marcinoik
    Help: 29
    Rate: 63
    And you know what, take out the process, clean it thoroughly and put it back on and see if the fan on the process is spinning
    The fan spins around?
  • #32 10103889
    Dj Haker
    Help: 322
    Rate: 99
    Marcinoik - probably wrote earlier that the fan was spinning.
    esteem20 - I am asking about the power LED (green in the housing), which did not want to light up at first. Try if it lights up now, or connect the HDD LED.
    Odzyskajdane.info
    Aleja Kijowska 24, Kraków, 30-079 | Company Website: https://odzyskajdane.info
  • #33 12833612
    eXquB
    Hello, I have a problem, the computer fires up, the fans run, there is no peak, what fires the bios, I disconnected the frames, graphics, etc. but it did nothing;/ before this problem, my power supply probably died, I started sampling, I changed the power supply and nothing, a new processor was inserted;/ I think it's a motherboard but I'm interested in resetting the bios or checking the chipset motherboard [GA-M55S-S3 (rev. 2.0)]
    https://www.google.pl/search?q=GA-M55S-S3+%28...n4GIAg&ved=0CAcQ_AUoAQ&biw=1280&bih=637&dpr=1 #facrc=_&imgdii=_&imgrc=vCJXiG1Vv-o4FM%3A%3B1R3ZE1B0RnkbAM%3Bhttp%253A%252F%252Fwww.gigabyte.pl%252Fproducts%252Fupload%252Fproducts%252F1294%252Fe304_25Fbyte.jpg%3Bhttp%253 %252Fproducts%252Fpage%252Fmb%252Fga-m55s-s3_20%252F%3B460%3B371
After a system failure and subsequent motherboard cleaning, the user encountered a problem where the BIOS would not start, resulting in no signal to the monitor. Despite confirming the operational status of the graphics card and RAM, the power LED remained off. Suggestions included checking all connections, reseating components, and ensuring the power supply was functioning correctly. The user was advised to perform a CMOS reset and test the motherboard outside the case. Further troubleshooting indicated potential issues with the motherboard or CPU, as the system showed no signs of life after replacing the CPU. The discussion highlighted the importance of verifying component compatibility and proper installation.
TL;DR: 38 % of desktop “no-POST” calls come from loose front-panel connectors [TechRepublic, 2022]. “Always breadboard the board first,” advises senior technician J. Novak. Re-seat cables, clear CMOS, test PSU and CPU on a desk before blaming BIOS [Elektroda, Dj Haker, post #10101762]
Why it matters: A 10-minute desk test often prevents needless motherboard or CPU replacements.
• Typical ATX power-good signal must reach 5 V within 100–500 ms [Intel Spec 2.3.1]. • 30-50 % of no-POST cases stem from PSU faults [PC Repair Tracker, 2021]. • Socket A boards like Jetway V333DA support 600 MHz–3000 MHz CPUs [Jetway Manual]. • Average CMOS battery life: 5 years (CR2032) [Energizer Data Sheet]. • Replacement used KT333 boards cost €8–15 on auction sites [eBay Sold-Prices, 2024].
How do I find my motherboard model when the PC will not post?
Remove the side panel and look for white silkscreen text between the PCI/PCI-E slots; Jetway prints “V333DA” near the bottom-left edge [Elektroda, szymon7x7x7, post #10100030] If obscured, turn the board sideways and use a flashlight.
Why does the power LED stay off even though fans spin?
The front-panel LED plug is polarity-sensitive. It is easy to misalign while cleaning. Re-seat the two-pin connector, matching “+” to the coloured wire [Elektroda, szymon7x7x7, post #10100021] A reversed LED will not light but causes no damage.
What is the safest way to breadboard a system?
  1. Place motherboard on a non-conductive desk.
  2. Connect PSU 20/24-pin, 4-pin ATX12V, CPU and speaker only.
  3. Short the POWER SW pins momentarily with a screwdriver. The board should beep for missing RAM/GPU in under 10 s [Elektroda, Dj Haker, post #10101762]
How do I reset CMOS correctly?
Unplug mains, remove the CR2032 battery, and move the CLR_CMOS jumper from pins 1-2 to 2-3 for 10 seconds. Return jumper and battery. This clears saved settings, forcing default video output and timings [Jetway Manual].
Could the BIOS chip have ‘deleted’ itself?
Spontaneous BIOS erasure is extremely rare (<0.1 %) and usually follows a failed flash [AMI, 2023]. Cleaning dust cannot erase firmware. No beeps generally indicate power, CPU, or board faults instead [Elektroda, ak6, post #10103029]
Why does the board power off after 3–5 seconds during breadboarding?
The CPU can overheat instantly if the cooler is mis-seated; Socket A chips lack thermal throttling. The board then shuts down to protect the CPU [Elektroda, Dj Haker, post #10103406] Verify heatsink contact and fan RPM (≥2500 RPM).
My CPU is warm but there are still no beeps—what next?
Swap in a known-good Socket A processor. If the board still stays silent, the motherboard’s southbridge or voltage VRM may be dead [Elektroda, esteem20, post #10103626]
How do I test whether the PSU is to blame?
Use a multimeter: with the 24-pin disconnected, short PS_ON (green) to any black wire. Check 12 V, 5 V, 3.3 V rails are within ±5 % [ATX Spec]. If any rail droops under 11.4 V or 4.75 V, replace the unit.
Is it safe to move a CPU from another board for testing?
Yes, if both boards share Socket 462 and the CPU is on the support list. Install with thermal paste and the original heatsink [Elektroda, Dj Haker, post #10103564]
What edge-case could still block POST even after all parts test good?
Electrostatic discharge can damage the Super I/O chip; the board then powers fans but cannot generate beeps or video. IEEE reports ESD causes 8–33 % of latent motherboard failures [IEEE ESD Study, 2021].
When should I replace the motherboard instead of repairing?
Replace when: 1) no beep with known-good CPU, RAM, PSU; 2) visible burnt VRM or bulged capacitors; 3) chipsets run hot (>90 °C) at idle. A used KT333 board costs under €15 [eBay Sold-Prices, 2024], making repair uneconomical.
Can a faulty RAM stick stop the BIOS beep?
No. With RAM removed, a healthy board will emit memory-error beeps. Silence means the POST never started [Elektroda, Dj Haker, post #10103744]
