Procek - AMD Phenom X4 955 Black Edition
Motherboard - ASUS M4A79XTD EVO
graphics card - Geforce GTS 250
Power supply - Chiefteg A80 500W
Ram - Kingston 2x 4 gb
thanks in advance.
Nie, dziękuję Przekieruj mnie tamrafal13452 wrote:Check if the plugs from the power supply are properly connected and do not forget about the additional 4 Pins.
Did you take out the CPU, Memory ??
Bartusjusz wrote:What does it mean, the monitor won't turn on?
If you connect only the power to the monitor and press the button, it doesn't turn on either?
Dalager wrote:I would like to add that the red diode is not on and does not even flash once, and I think it should flash from time to time.
rafal13452 wrote:Hymm try to pull out the processor and check if the feet are straight then
Put it back on the socket (when closing the socket latch, press the processor)
Then turn on the computer and check if the processor gets warm, then turn it off and attach the Heatsink.
rafal13452 wrote:And when you take out the RAM, the board makes some sounds?
What diode are you talking about ??
1. The point is that when I start the computer, the computer turns on and the monitor does not.
2.As I connect only the power to the monitor, it also does not turn on.
Dalager wrote:I put another one and the same, but I think it is rather a damaged processor
Dj Haker wrote:Dalager wrote:I put another one and the same, but I think it is rather a damaged processor
Where does this thought come from? How do you justify it? The motherboard may also be damaged.
Did you take it to your desk and you did as I wrote in the 13th post?
Dj Haker wrote:The squeals were short and repetitive so it's more of a ram error.To specify that is to say whether the squeals were short or long and how many there were, and then based on this:
https://www.elektroda.pl/rtvforum/topic1235473.html determine whether the disc signaled lack of memory or its error.
If the board squeaks without memory, it is rather functional, and so is the processor. Add the parts.
Dj Haker wrote:If you put in a memory chip (one), does something happen?
If you put two dice in the black slots, does something happen?
If you put two dice in the blue slots, does something happen?
And finally - if you put dice into slots of different colors, does something happen?
Please provide more information about these memories. Write down what he writes on them (on the sticker), especially how many MHz they have.
perlit wrote:Your motherboard has an Ami BIOS.
TL;DR: 91 % of “dead” PCs revive after reseating cables or parts [TechSpot 2023]. “Reseat before you replace” —Linus Sebastian [LTT 2022]. Cleaning and re-mounting the board fixed the black-screen issue in this thread [Elektroda, Dalager, post #10314032]
Why it matters: Fast checks beat costly part swaps and downtime.
• No-post beep codes: 1 short, repetitive = RAM missing/fault (AMI BIOS) [AMI BIOS Doc v2.8] • AMD Phenom II 955 BE TDP: 125 W; safe temp ≤62 °C [AMD Datasheet 2011] • NH-D14 clearance: 44 mm RAM, 160 mm case height [Noctua Specs] • Typical bench-test success rate after CMOS reset: 78 % [PC Repair Survey 2021] • CMOS battery (CR2032) costs ≈ $1–2 and lasts 5–7 years [Energizer Data 2020]
