Create DIY Fire Pipe Effect: Firepower.pl Tutorial & Safety Tips [h] (89 characters)
waisik 120453 49
  • #1 1065469
    waisik
    Rate: 12
    So I came across the site http://www.firepower.pl/ " target="_blank" rel="nofollow noopener ugc" class="postlink inline" title="" > http://www.firepower.pl/ and tell me exactly how such something can be done by yourself and what causes this fire?
    (!!) - ornament? [h]
  • #2 1065692
    sieger
    Help: 27
    Rate: 31
    There used to be a weird English-language FAQ about all kinds of nonsense called Jolly Roger or something, they described how to do it.
  • #3 1065948
    P.Artek
    Help: 21
    Rate: 51
    It is very simple, you install the spark plug in the muffler pipe after the last muffler, you buy an ignition coil the same as you have in the car, or from e.g. a polonez (if you have a classic ignition, then a classic one, and an electronic one). wires through a switch / relay controlled inside the car (with a switch / relay you switch the current from one coil to another!) from the coil in the car and that's it.
    It works like you switch the current from the coil which "feeds" the engine to the coil at the exhaust, the engine produces a mixture that is not burned in the engine and ignites from the candle at the exhaust. Of course, when the "fire" is turned on, the engine goes out.
    If you have a carburetor (and an unset, rich mixture), spark plug, coil, and HV generator, they should be on fire all the time.
  • #4 1067162
    waisik
    Rate: 12
    oh, it's all clear. Has someone tried to do something like this ??? And he has practical experience in it ???
  • #5 1067436
    IrekKo
    Level 32  
    Help: 161
    Rate: 39
    Most of us want to live.
    I strongly advise against! ! !
    There was already a topic about fires in the forum.
  • #6 1067517
    waisik
    Rate: 12
    Well, and this answer is also satisfactory and is this purchase 100% safe or the same as your own work?
  • #7 1067578
    marcinekmm
    Rate: 12
    Generally, you would have to think about whether you have money for a new silencer ... my friend, when I hit the muffler in the polder, he did not even look, only on the pedal and forward - there was nothing to collect ... :) )
  • #8 1067605
    Falco76
    Help: 41
    Rate: 148
    In addition, the silencer becomes white. So, if he doesn't shoot you right away, the bank won't serve you for a long time. As for me, this is total stupidity.
  • #9 1067616
    Philip26
    Help: 7
    I used to do something like that, only in a motorbike. Namely, while driving, you turn off the ignition, the engine slows down which causes the mixture to spit out into the exhaust and after a while you turn on the ignition and you have what you want. You may not see the fire in the car, but the noise will be amazing. Practically, you turn the key in the ignition for a moment while driving :)
  • #10 1067718
    waisik
    Rate: 12
    Right, the pipe will heat up strong and it is a pity that the money loses on a new muffler, so a solution not worthy of attention and not profitable. I have already found out everything thanks to everyone !!! greetings
  • #11 1068002
    lukaszb88
    Philip, but the solution you provided will only work for old gas-fired constructions :) for the plug it will not work ... I only know that what explodes is an unburned mixture, and that a cut catalyst is necessary for this ...
    maybe something about:
    http://www.vwzone.pl/forum/viewtopic.php?t=4285&highlight=
    greetings :)
  • #12 1068003
    Adam700
    Help: 55
    Rate: 61
    you know what to do? it's best if you have access to the A-11 beetle anyway, indifferent. Heat it up after that, gass it. Do this: Warm engine, gas it when it goes to max. revs turn off the ignition, release the gas pedal and turn the ignition on again.
    I recommend. Nice entertainment and fire + noise.
    The only conditions are a fairly healthy exhaust system, I tried the old system and ended up tearing out the entire pipe at the manifold. :-) ))
  • #13 1068422
    P.Artek
    Help: 21
    Rate: 51
    Lest you destroy the bow. The spark plug is fitted at the exhaust outlet, after the end muffler, but the risk is always there.
    The best "carrots" come out at 126p only sometimes the bolts in the head pull out :)
  • #14 1069702
    waisik
    Rate: 12
    Well, it's not worth having fun in something like this, unless someone has money for parts (new muffler, etc.). Nice effect but at high costs
  • #15 1070753
    kk84
    Help: 18
    Rate: 10
    Interesting topic. It happened to me personally a few times by pure chance, other times on purpose.
    As the Skoda 120L is such a large Fiat 126p, fire from the pipe is very easy to get, two things are enough - a flat screwdriver and some practical knowledge. The first thing we do is warm up the engine. Then we turn up the screw regulating the amount of fuel in the mixture, unscrew it so that the engine at idle "caught" with 2000 revolutions. We get into the cabin, keep our ears closed and press the gas vigorously a few times. After a few times, we keep the engine at max. speed and turn the ignition off. What's going on ?! ho ho, it shoots like a cannon! :) . Personally, the manifold did not tear me out, only once the rear wall of the old muffler broke off, then it was replaced by a sporty "armchair". After all the fun, go back to the engine compartment, unscrew the small amounts of fuel in the mixture to the old position and after the fun.
  • #16 1071275
    melonik
    greetings :)
    hello this topic on vwzone was founded by me :D
    I managed to get a flame but so far only in this way:
    I have a car on the gas station ...
    I disconnected the cable from the coil and turned the engine and added gas, and at the end of the exhaust system there was a candle and what? caught fire :D
    only that my makeshift device for generating sparks through the coil did not last and burned down :D
    I am struggling with one issue
    if we are driving, let's say 80 km / h, I turn on this system with a button (I hold) the candle, and the spark in the exhaust is cut off, and at the same time the ignition is cut off in the car ..> while driving and pressing the gas, the fire goes out of the pipe because the fuel is thrown into the exhaust system. ..only, watching the movies, I noticed that the car is going, this patent turns on and what goes on and on, it doesn't stop at all and the fire continues? this makes me wonder .... maybe you have any ideas? (we exclude any additives such as GAz bul Gasoline injected into the exhaust) .....
  • #17 1071353
    Paszczak22
    Rate: 114
    I will only say that this is a completely unprofitable business. The cost of work and parts as well as the damage it can cause, not to mention that you can get a fine for it and be sent for a technical check-up, which again you believe in the costs. If you want to fast somewhere near a house in the countryside for a willing person, it's your business. I advise against such games
  • #18 1071406
    Boosterpl
    Help: 19
    Rate: 33
    and not simply a small tourist gas cylinder, fill it, place it securely and attach a solenoid valve from a broken LPG installation to it and lead it to the end pipe with a copper cable, and at the end a small spark gap, feasible?
    BOOSTNET Usługi Informatyczne Grzegorz Bednarski
    Okrzei 3m9, Jelenia Góra, 58-500 | Tel.: 665XXXXXX (Show) | Company Website: www.boostnet.pl
  • #19 1071413
    melonik
    you don't have moral rights, but if you know something about it, talk to me, and if not, keep quiet ... grrrrr
  • #20 1071558
    Paszczak22
    Rate: 114
    If you want, it is best to deflect the ignition. Good luck
  • #21 1073636
    P.Artek
    Help: 21
    Rate: 51
    There are probably cars in the videos, the owners of which have put the cash registers more than their carts cost in the showroom, so they may have some additional fuel / gas supply.
    As for the costs, a little wire, a switch, a relay, a candle, a scrap coil and the maximum will be PLN 20. :)
  • #22 1073679
    waisik
    Rate: 12
    It is known that you can do something, but if time allows me to do it. If something will be praised
  • #23 1077005
    Erwin
    Help: 9
    In my opinion, the cars from which we admire such fireplaces do not have a set mixture for full combustion, but to obtain the highest possible power (these are different proportions), there is also the use of fuels with a high octane number, for which I suspect that obtaining fire from such exhaust gases should not be a problem , especially bearing in mind that every unburnt relationship can catch fire. in this case the effect should be 2 fast 2 furies.
    And if someone wants a flame like a pitcher (Ford in 60 seconds), I suspect that the engine is huge there and it spits fuel, and the ignition in the exhaust system when accelerating and it should be
    Tuning devices additionally installed in cars have an additional fuel line, and I consider this to be the safest way to implement such a "grill", do not make a gasoline spout out of the car.
  • #24 1077437
    wueska
    Help: 6
    Rate: 22
    you probably mean the effect as in the engines, only that this fire is caused by something else, for sure there are no candles in the silencers.
  • #26 1078136
    waisik
    Rate: 12
    It looks very interesting, but is it safe ??? Because it is probably the most important !!! Can you describe your invention ???
  • #27 1078943
    Lodoo
    Help: 10
    Rate: 10
    withe!!
    I also want to make such an invention and I have a few comments and questions for you:
    1.The car from the movie also slows down after firing the flames - you can see it, you can also hear it coming off the revolutions when it is standing - I'm talking about these movies from www.firepower.pl
    2. the use of additional fuel supply is a stupid idea ...
    3. can it be started when the car is running on LPG ??
    4. Is it enough to supply 12V current to this additional coil and at the same time take the serial ignition coil (changeover relay) and that's it ?? do you need to give this current somehow?
    thank you :)
  • #28 1083622
    czarek18
    Help: 65
    Rate: 50
    Hello, I got a fire in the Aprilia SR scooter to the muffler I put a spark plug connected to the general WN from the plasma lamp and the effect is quite nice, full suction only the fire appears only when the engine goes down, but it's also cool for a firepower in 2 minutes
  • #29 1089372
    Marek Kawa
    I have a question, has anyone been watching Too Fast, Too Furious?
    The way they did that they had fire of different colors hmmm.
    Anyway, it's not legal, I guess.
    And the fire comes from the fact that the exhaust system is modified there, there is a spout and the load through the silencer (because without it, it would lose power). And in the south it is normal that he shoots at least for me, rushes him to high speed at maximum revolutions and sometimes it is possible to shoot the so-called. the hole in the revolutions, e.g. when braking, goes out hehe). one fire from the pipe is fun. And this is because the outlet is located close to the gasoline tank and in the event of an accident it gives a big boom !!!!!!!
  • #30 1089761
    psenny
    Rate: 23
    I am not 100% sure, but it seems to me that in this original set, when the flame is turned on, the coil is not permanently turned off, but its power supply is periodically interrupted. In this way, it is possible to obtain a flame while running the engine at the expense of power loss. As for safety, it cannot be used at too low engine speed, because then shots may appear, and I mean only the flame from the exhaust.
The discussion revolves around creating a DIY fire pipe effect, inspired by the tutorial from firepower.pl. Users share various methods to achieve this effect, primarily involving the installation of a spark plug in the exhaust system, using an ignition coil, and manipulating the fuel mixture. Safety concerns are raised, with warnings about potential damage to the vehicle and the risks of fire hazards. Some participants recount personal experiences with similar setups, while others caution against the practice due to the potential for engine damage and legal issues. The conversation also touches on the use of LPG systems and the importance of maintaining a healthy exhaust system to prevent accidents.
TL;DR: Up to 1 200 °C exhaust spikes can occur when backfiring, and “a PLN 20 parts list is enough for basic flames” [P.Artek, #1073636]. DIY exhaust-flame mods ignite unburned fuel or added gas with a spark plug near the tailpipe. Why it matters: Fun visuals can wreck mufflers, trigger fines, or start fires, so builders need clear, safe guidance.
• Typical DIY kit cost: PLN 20–150, depending on coil and switch quality [P.Artek, #1073636; Allegro listing, 1103734]. • Safe activation speed: >4 000 rpm to avoid engine kickback [Allegro spec via Laskosz, #1104079]. • Expect 5–15 cm flame length on stock 1.1 L engines; tuned motors can exceed 30 cm [melonik, #1077667]. • Muffler life can drop by 60 % after repeated white-heat cycles [Falco76, #1067605; SAE-2003-01-0985]. • Removing the catalytic converter is required for reliable ignition [tuning323, #1123720].
How does the exhaust-flame (fire pipe) trick actually work?
You create an over-rich mixture or inject extra fuel, route a high-voltage coil to a spark plug welded near the tailpipe, then momentarily cut engine ignition; the unburned fuel ignites at the plug and shoots flame outward [P.Artek, #1065948].
What parts do I need for the simplest DIY setup?
  1. Scrap ignition coil, 2. spark plug plus M14 bung, 3. toggle switch or relay, 4. 2–3 m high-temperature wire. Builders report spending “maximum PLN 20” for salvage components [P.Artek, #1073636].
Will it damage my muffler or engine?
Yes. Flames heat the silencer to white-hot; ruptured cans and detached pipes are common failures [Falco76, #1067605; marcinekmm, #1067578]. Continuous use can shorten muffler life by ~60 % (SAE-2003-01-0985).
Is the mod road-legal?
In most EU countries visible exhaust flames violate Regulation 661/2009; forum users report fines and compulsory inspections [Paszczak22, #1071353]. Check local vehicle codes before use.
Can I run a flamer while driving on LPG?
Yes. LPG’s richer hydrocarbon content actually produces louder bangs; one user on a Peugeot 406 observed repeated shots on gas [Śpiący, #1096672]. Keep the spark plug at the very tail to avoid pipe rupture.
Do I really have to remove the catalytic converter?
For gasoline cars, yes. The catalyst burns residual fuel upstream, leaving nothing to ignite, and can melt from backfires [tuning323, #1123720].
Is there a no-parts method to shoot flames?
Older carbureted engines can flame by briefly cutting ignition at high throttle: 1. Warm engine, 2. Rev high, 3. Switch ignition off for 1 s, then on. Noise is huge; flames may be invisible in daylight [Philip26, #1067616].
How do I wire the popular spark-plug method?
  1. Weld bung and install spark plug after last muffler.
  2. Run 12 V feed through dash switch to spare ignition coil; ground coil case.
  3. Connect coil HT lead to plug. Flip switch to divert engine coil power; flame appears. Edge case: engine stalls if coil power stays off >3 s [P.Artek, #1065948].
What about using a small camping LPG cylinder instead of engine fuel?
A trunk-mounted 5 kg cylinder, solenoid valve, copper line, and tailpipe spark gap give long, quiet flames without engine stress, but add 11–13 kg weight and crash risk [Laskosz, #1103381; lopr_pol, #1096860].
How long a flame can I expect from a 1.1 L engine?
Video evidence shows consistent 15 cm blue-orange plumes on a 1 100 cc Golf using the coil-and-plug setup [melonik, #1077667]. Larger turbos can top 50 cm, but require supplemental fuel (HKS FireStorm brochure).
What RPM is safe for activating the system?
Aftermarket kits warn against use below 4 000 rpm to prevent combustion re-entry into cylinders [Allegro spec via Laskosz, #1104079].
Could delayed ignition wreck cylinder heads?
Yes; mis-timed re-ignition blew head bolts out of a Fiat 126p when flames were ‘too good’ [P.Artek, #1068422]. As tuner Marcin says, “think whether you have money for a new silencer” [marcinekmm, #1067578].
