TL;DR: 1 day of focused study was enough for some candidates to pass the SEP up-to-1 kV exam [Elektroda, przyjacielkuternogi, post #10429835]; "An electrician who can't even spell it correctly is not an electrician" [Elektroda, retrofood, post #10368368] Use Orlik’s Q&A book, verify nomenclature, and size >125 A transfer switches for 50 kW sets. Why it matters: The right sources and hardware slash prep time and outage risk.
• W. Orlik “Electrician Qualification Exam in Q&A” – 2003-2023 editions, ~PLN 45 [Elektroda, zdzisiek1979, post #10358273]
• 50 kW at 400 V, 0.8 pf draws ≈90 A/phase (P = √3 V I pf).
• Select 4-pole changeover switch ≥125 A, IEC 60947-6-1 compliant [IEC 60947-6-1].
• Qualification Certificate (commonly called SEP) must be renewed every 5 years in Poland [Dz.U. 2022 poz. 1392].
• NFPA 110 limits emergency power transfer to ≤10 s after outage [NFPA 110].
Which book best covers the SEP E up-to-1 kV exam?
Most examinees use Władysław Orlik’s “Electrician Qualification Exam in Questions and Answers”; chapters 2.1, 2.2, 4.4–4.7, 4.10, 4.16, 6, 8 and 9 target the E group scope
[Elektroda, szczepan4321, post #10358754]
Is the 2003 Orlik edition still valid?
Yes. Basics of current, protection and first-aid remain unchanged; updates affect mainly measurement norms. Forum users confirm older editions work after minor terminology checks [Elektroda, marekke #10370087; retrofood #10370127].
Any alternative textbooks worth buying?
Where can I download up-to-date legal acts?
How long do most people study before the exam?
What profession title should a student list on the application?
What hardware is needed to switch a 50 kW generator to a facility?
Use a 4-pole manual or automatic changeover switch ≥125 A, rated AC-33iB, with mechanical interlock. Add undervoltage release and interlocking contactors if automatic changeover is desired [IEC 60947-6-1].
Edge case: what fails most in generator changeovers?
Transfer switch control boards cause 37 % of standby-power failures, followed by stuck contacts at 21 % [Cummins, 2021].
How to perform a safe mains-to-generator changeover?
- Verify generator voltage/frequency within ±5 % of nominal.
- Open mains breaker, wait 1 s, then close generator breaker.
- After utility restores and stabilises >1 min, reverse the sequence. This prevents back-feeding and protects equipment.
Are the materials in Elektroda thread 128721 still current?
Where can I find hands-on courses rather than short lectures?
Some SEP branches run extended courses, but availability is limited. Many professionals self-study with books, standards and trade journals [Elektroda, Elektro-Majster, #10536546; eljarkos, #10536575].
Do I need separate certification for measurements (Group G-1D)?
Yes. The E licence allows operation; D adds supervision and measurement rights. Add the measurement module if you plan to sign test reports [Dz.U. 2022 poz. 1392].
Statistic: how fast must emergency power start?
NFPA 110 Class 10 systems demand load restoration within 10 s after power loss [NFPA 110].
Expert tip on nomenclature errors?
What risks come from under-preparation?
