DVB-T Reception Issue: Unable to Receive MUX 3 in Garbów, Lubelskie Voivodeship
yogii79 18054 10
How can I get MUX 3 reception in Garbów, Lubelskie Voivodeship when the other DVB-T multiplexes work?
Check whether your location in Garbów should receive MUX 3 from Lublin-Piaski rather than Ryki, because the transmitter choice depends on the exact reception point and the Emitel coverage map can show that reception is possible or not possible depending on the site [#16912157][#16912635] MUX 3 has two relevant versions here: Warsaw on channel 42 with low power (4 kW) and Lublin on channel 52 with the same power as MUX 1 and MUX 2 (20 kW) [#16917023] Do a manual tune on channel 52 and check the signal parameters there, since that is the stronger MUX 3 signal for this area [#16917023] If you still miss only MUX 3, try reception with a passive antenna and inspect the antenna/cabling, because partial reception does not prove the power supply is good [#16917023][#16917450]
  • #1 16912059
    yogii79
    Hello . I have a problem with receiving MUX 3 the rest works what can be done to solve the problem. The location is Garbów Lubelskie Voivodeship
  • #2 16912157
    LeDy
    Help: 1990
    Rate: 2937
    https://emimaps.emitel.pl/ For this channel, they write about the possibility of no reception.
    Enter and see Garbów, lubelskie, Poland
    What installation?
  • #3 16912635
    _kli_
    Help: 760
    Rate: 1038
    This app is misleading. Emitel let out the sell. In particular, this applies to mux-3, where in many locations the message "Possible lack of range using a typical TV antenna" appears - even in the immediate vicinity of the transmitter.
    In this particular situation, there is no coverage, because the application introduced data for weak (4 kW) lighting from Dęblin. Just enter the Humps, mark mux-3 and click, for example, the icon denoting Lublin - Piaski transmitter, to find out that this place is within its reach.
    In which direction is the antenna set? According to the maps below, depending on the location of the reception site in Garbów, transmitters may be included
    http://mapy.tvradio.cba.pl/Telewizja/MUX3/Deblin_Ryki/Lublin/ (mux 1-3, 8)
    http://mapy.tvradio.cba.pl/Telewizja/MUX3/Lublin_Piaski/ (mux 1-3, 8)
    http://mapy.tvradio.cba.pl/Telewizja/MUX3/Lublin_BozyDar/ (mux-3, 8)
  • #4 16915132
    yogii79
    Hello iinstalacja is a simple mesh antenna I will add to receive all other MUXY. The antenna is set to Ryki
  • #5 16915232
    maksar
    Help: 177
    Rate: 1030
    Replace the power supply or replace it with a new one.
  • #6 16916906
    yogii79
    The power supply is new, since I receive the remaining MUXY
    With each transmitter does not receive Piaski, Ryki, Lublin receives only MUX 1 and MUX2
  • #7 16917000
    andpol 33
    Help: 513
    Rate: 1146
    The power supply may give too low voltage (dried electrolyte) and precisely what the higher the channel, the faster the interference will occur.
  • #8 16917023
    _kli_
    Help: 760
    Rate: 1038
    Roars are given by two mux-3 versions - Lublin and Warsaw. Warszawska (at 42) is broadcast with low power (4 kW), and Lublin (k.52) with the same as mux 1 and 2 (20 kW).
    On manual programming, check the signal parameters at k. 52.
    Partial pickup does not necessarily indicate the efficiency of the power supply. Have you tried reception on a passive antenna?
  • #9 16917106
    yogii79
    Give me everything as I will be there. I live in Lublin, my uncle lives in Garbów. He attends for all the hints, which may be the cause of the problem
  • #10 16917117
    andpol 33
    Help: 513
    Rate: 1146
    It would be nice to see the antenna or the can and the water does not pour into it.
  • #11 16917450
    maksar
    Help: 177
    Rate: 1030
    Write correctly can not and hints negate. Just to work.
    yogii79 wrote:
    The power supply is new when I pick up
    1. How old is this power supply?
    2. Have you heard about LTE?
The discussion revolves around a DVB-T reception issue in Garbów, Lubelskie Voivodeship, where the user is unable to receive MUX 3 while other multiplexes are functioning. Responses suggest checking the reception maps for coverage, as MUX 3 may have limited range due to low power transmission from nearby transmitters. Recommendations include verifying the antenna direction, considering the use of a passive antenna, and ensuring the power supply is functioning correctly. Users also discuss potential interference from LTE signals and the condition of the antenna and its installation.
