[DVB-T] Why are Polsat, Polsat 2, TVN and TVN7 missing on terrestrial TV?
hipek.xd 112311 19
Why are Polsat, TVN and related terrestrial channels missing even though other DVB-T multiplexes are received?
The missing channels are carried on MUX2, which the antenna installation is not receiving; Polsat 2 was not carried on a terrestrial multiplex at that time [#14532999] [#14533019] In the Rzeszów area, try manually tuning MUX2 on channel 23 from Tarnów or channel 32 from Sucha Góra; the received channels 45 and 50 indicate Tarnów for MUX1 and MUX3 [#14533289] [#14533622] The antenna system is likely inefficient, so inspect the antenna, cabling, direction and signal quality rather than relying only on automatic scanning [#14533180] [#14533968] Replace the antenna-box amplifier with a symmetrizer/balun and replace the powered separator at the TV with a good-quality antenna plug, then rescan manually [#14533289] [#14533622] Simply switching off the amplifier power is not a valid passive-antenna test because the unpowered amplifier can behave as a strong attenuator [#14533232]
  • #1 14532953
    hipek.xd
    Rate: 48
    Does anyone know why I do not have Polsat, Polsat 2, Polsat News, TVN or TVN7 channels on digital terrestrial television? As far as I know, they should be received without any problems. Other channels work fine, and these I just don't have (and can't find them).
  • #3 14532999
    janszy3643
    Help: 142
    Rate: 312
    You don't have a tuned receiver or you are not receiving MUX2
    : Polsat, TVN, TVN7, TV4, TV Puls, PULS 2, TV6 and Polsat Sport News
  • #4 14533019
    pietia86
    Help: 69
    Rate: 91
    From what I know, Polsat 2 is not on any mux.
    Polsat, TVN and TVN7 are on MUX 2. It looks like you just don't receive it.
    On this website you can check the frequencies for your locality. Tune the receiver to the frequency you need and check if you can find the channels. If not, you have to deal with the antenna.
  • #5 14533038
    hipek.xd
    Rate: 48
    When it comes to the location in which I live is Podkarpacie (near Rzeszów), the antenna is an ordinary mesh (but certainly functional, because the new one was bought), the TV is a Samsung LE40C530.
    That's right, I don't have any of these channels.
    E: I have all of MUX1 and MUX3 and none of MUX2.
  • #6 14533070
  • #7 14533073
    sosarek
    Help: 9320
    Rate: 15534
    You are probably using the Rzeszów / Sucha Góra transmitter - manually search channel 32.
    Z
    Pka, Poznań, 60-850
  • #8 14533119
    hipek.xd
    Rate: 48
    Unfortunately, I have no idea which transmitter I use: / Can I check it somehow? I can't find anything on channel 32.
    E: On channel 50, I have 8 channels, but if I approve, I don't have any new ones, so it's probably one of the ones I already have.
  • #10 14533147
    hipek.xd
    Rate: 48
    Neither at 29 nor at 52 I find anything for me.
  • #11 14533180
    irekr
    Help: 1192
    Rate: 1239
    It is characteristic of the vicinity of Rzeszów that the signals from Sucha Góra are not always the strongest. Depending on the location, you can receive a signal from three or even four objects.
    Did the author of the topic check the reception on the PASSIVE antenna, i.e. without an amplifier?
    Was scanning for channels manual or automatic?
    What channels do you receive MUX1 and MUX3 on? You can check it?
    What are the strength / quality indications on the received channels?
    If you are receiving channel 50, you probably have signals from Tarnów.
  • #12 14533191
    niewolno2
    Level 40  
    Help: 630
    Rate: 1260
    You still have the Leżajsk "Giedlarowa" channel 59.
  • #13 14533212
    hipek.xd
    Rate: 48
    Without the amplifier, the channels did not work at all (unless searching the channels again would change something).
    I scanned automatically (it detected 16 channels).
    Channel List:
    Spoiler:
    TVP1 HD- 1
    TVP2 HD -2
    TVP KRAKÓW - 3
    ESKA TV - 12
    TTV - 13
    POLO TV - 14
    ATM ENTERTAINMENT - 15
    TV TRWAM - 16
    TV FRAME - 17
    FOCUS TV - 18
    TVP ABC - 29
    TVP KULTURA - 30
    TVP HISTORY - 31
    TVP POLONIA - 32
    TVP ENTERTAINMENT - 33
    TVP INFO - 34
    E: At 59 also nothing.
  • #14 14533232
    irekr
    Help: 1192
    Rate: 1239
    "Without amplifier" is it without power or after removing the amplifier from the antenna?
    Turning off the power is not a solution, the amplifier then acts as a strong attenuator and it is no wonder that you do not receive anything.
    And like I asked above: on which channels are you receiving?
  • #15 14533247
    hipek.xd
    Rate: 48
    No power.
    I gave the channel list in the spoiler (unless we didn't understand each other and it's about the other channels :) ). How so how to check it?
    By the way, TVP Regionalna is TVP Krakow for me. Maybe it will help you somehow.
  • #16 14533289
    irekr
    Help: 1192
    Rate: 1239
    When asking about the channels, I meant the channels on which you receive individual MUXs. From what you write, you receive MUX1 and 3 from Tarnów on channels 45 and 50. And everything points to an inefficient antenna installation.
    I would start by disassembling the amplifier near the antenna, replacing it with a balun and disassembling the power supply. I know that you can only buy mesh antennas with amplifiers in stores, which I will not comment on.
  • #17 14533312
    hipek.xd
    Rate: 48
    That's right, I also find 8 channels on 45, so probably from Tarnów. So what exactly can I do? This was done by a friend of a friend who deals with it and he himself brought the antenna and he did everything also I have no idea what the antenna is.
  • #18 14533503
    LeDy
    Help: 1992
    Rate: 2940
    If you have no idea, call this friend of yours and let him do the rest to make everything work.
  • #20 14533968
    irekr
    Help: 1192
    Rate: 1239
    Just for the record: maybe give your position more precisely. If you live west of Rzeszów it is a very nice neighborhood but "quite unhappy" for radio waves. I know from practice that you are probably within the reach of both Tarnów and Sucha Góra, Święty Krzyż and even Prehiba. Depending on your location, the optimal pickup direction may vary widely.
    Personally, I would use a slightly larger and more directional antenna and choose its installation location very carefully.
    The suggestions of my colleagues above are most appropriate regarding the impedance transformer and antenna plugs. I hope that the friend who installs the antenna for you will not be particularly offended if he reads all that is written here.
    Successes.
The discussion revolves around the absence of Polsat, Polsat 2, Polsat News, TVN, and TVN7 channels on digital terrestrial television in the Podkarpacie region, specifically near Rzeszów. Users suggest that the issue may stem from not receiving MUX2, which carries these channels. Recommendations include checking the type of antenna, ensuring proper tuning of the receiver, and verifying the signal from local transmitters such as Rzeszów/Sucha Góra and Tarnów. Users also discuss the importance of using a suitable antenna, possibly a larger and more directional one, and the need for proper installation without an amplifier that could attenuate the signal. The conversation emphasizes the necessity of manual channel scanning and checking signal strength and quality.
