Volkswagen Polo 1.2 - Understanding INSP Message on Dashboard and Kilometer Display
Manko86 44118 5
  • Clarifying Polo INSP service inspection reminder
    #1 16342636
    Manko86
    I have a car of a Volkswagen Polo 1.2 friend, but on the dashboard as the car is not lit normally you can see the kilometers traveled, but if you turn the ignition once without igniting the engine, instead of a flashing INSP sign appears
    After a while it goes out and if the car ignites, INSP disappears and you can see normally kilometers, but I wonder if it is normal or is it something that is INSP? Unless in Polo this is the inspection of the car and the INSP sign is from the beginning, but I am not sure if anyone could explain it to me?
  • #2 16342665
    Sławek 61
    Level 19  
    Help: 29
    Rate: 140
    The inspection inscription informs us to review the car. The site is deleted after
    connecting a computer, if we perform a self-inspection, we can delete the inscription inspection with a combination of buttons, it all depends what the VW POLO model is.
  • Clarifying ignition position for resetting the INSP service message
    #3 16342722
    Manko86
    Volkswagen Polo engine 1.2 year 2007, there is a description like this:
    https://vwpolo6n.wordpress.com/tag/kasowanie-komunikatu-service-insp-polo-6n/
    but I do not know if info from above cord:
    turn the key in the ignition switch to the ignition position
    means to light the engine or just turn it until the controls are activated.
    I tried to turn the key so that the controls would turn on the engine was not on fire, but it did not work. Maybe I need to light this car?
  • #4 16342900
    Sławek 61
    Level 19  
    Help: 29
    Rate: 140
    Turn the ignition key without igniting the engine and then according to the link mentioned above.
  • #5 16342941
    Manko86
    It's how I did it and it does not work, this scheme does not help either. Somewhere in there I read that like on a hot one, but I'm not sure and I would not like to try and not to damage something.
  • #6 16342958
    robokop
    Help: 1763
    Rate: 6371
    If it's a friend's car, why are you combing in it? The inscription "isnp" only informs about the need to inspect the car - oil change, etc. In no case does it affect the usefulness of the vehicle. The daylight reset button must be pressed, held and the ignition switched on - after approx. 10s. the inscription will be deleted. I close.
