Computer Fails to Recognize 4WORLD HDD Media Center USB External Drive: Solutions & Alternatives
WooHoooArt 101484 13
How can I make a 4WORLD HDD Media Center USB external drive visible to Windows when it is not detected?
Check the drive in Windows Disk Management first: right-click My Computer, choose Manage, then Disk Management, or run `compmgmt.msc` from Start -> Run [#10562146][#12931426] If the disk appears as unknown or uninitialized, and initialization reports that no sectors can be found, the problem is likely with the disk, its connection, or its power supply rather than a simple missing drive letter [#13135377] Try connecting it directly to a rear USB port, not the front panel or through an extension, because that solved the issue for one user [#12931171] If the enclosure is underpowered, use a better USB power source/cable since USB external drives in housings may need a decent supply to spin up properly [#13718236] If you need to save data, boot Hiren's Boot Mini Windows and see whether it detects the disk so you can copy the files before trying further fixes [#10708193]
  • #1 10558438
    WooHoooArt
    Hello, I have a problem in PA, I see the computer hard drive and my computer does not ...
    I do not know if it is a Good Department but I am asking for urgent help
    [img] http://hosting.webthemes.pl/upload/original/Dysk.jpg
    I have read many guides, e.g. Scribing to a different port, etc., nothing works; /
    Change the way of pasting graphics: https://www.elektroda.pl/rtvforum/topic2053101.html
    [jankolo]
  • #2 10559405
    vixy
    Rate: 16
    START -> 'computer management' -> Storage -> Disk management
    is this disk there?
  • #3 10562122
    WooHoooArt
    I do not have such a Path
  • #4 10562146
    Kasek21
    Help: 4981
    Rate: 3547
    Right click on My computer -> Manage -> Disk management .
  • #5 10563261
    vixy
    Rate: 16
    what you need to enter in the apostrophe, or do as a colleague advised above
  • #6 10563454
    markbit
    Rate: 10
    colleagues are right you need to check if there is .... "computer -> Manage -> Disk management." if there will be no partitions, make them yourself and it sucks; if there is no disk, give the model ... we will help
  • #8 10564685
    jankolo
    Rest in Peace
    Help: 1792
    Rate: 587
    WooHoooArt : I repeat the request.
  • #9 10708193
    markbit
    Rate: 10
    if you care about data, download hiren's boot and start mini Windows, maybe he will see the disk, then copy the data, if not, then there is probably something wrong with the disk
    or you need drivers, there may also be a voltage on the usb too small for this disk, so you need a special cable .... many possibilities if it does not go, first connect it to another pc and then write ;)
  • #10 12931171
    ProiX
    People, I have a solution :D I went about it myself after many attempts. Connect the drive from the back to the usb. Not in the front, not through an extension, normally in the back. If that doesn't work, I'm using the finest Xfast USB program. I recommend ProiX :)
  • #11 12931426
    mati211p
    HDD and data recovery specialist
    Help: 2585
    Rate: 1133
    Instead of looking for a path, you can also choose start -> run: type compmgmt.msc and click enter, then just go to disk management, but rather a bit late advice, but maybe someone will need it.
  • #12 13135377
    eVr1
    He sees the disk as unknown, uninitialized in disk management. After "initialize disk" the message: "Could not find any sectors on the disk"
  • #13 13718126
    mariolawasilewska
    My computer sees the disk as uninitialized and unallocated when I want to give it a name, a CRC error window pops up, please advise me what to do in order not to lose what I have on the disk pliss
  • #14 13718236
    safbot1st
    Help: 2719
    Rate: 1585
    Please create your own topic in accordance with the regulations
    https://www.elektroda.pl/rtvforum/topic2367809.html
    and provide a complete list of equipment.
    The USB external drive in the housing must have a decent USB power supply - otherwise it will not work properly or even "spin the plate".
The discussion revolves around a user experiencing issues with their 4WORLD HDD Media Center USB external drive not being recognized by their computer. Various troubleshooting steps are suggested, including checking the drive's status in Disk Management, ensuring proper USB connections (preferably using rear ports), and using diagnostic tools like DriveLetterView and USBDeview. Users also recommend using Hiren's Boot CD for data recovery and ensuring adequate power supply to the drive. Some users report the drive being detected as uninitialized or unallocated, indicating potential data loss risks. Suggestions include initializing the disk and checking for driver issues or hardware faults.
