ASUS k52j - Upgrading Seagate Momentus 5400.6 ST9320325AS to 120-200GB Drive with 250GB+ Capacity
djmixer7 3960 5
  • #1 16384005
    djmixer7
    Hello!
    I am looking for an ASUS K52J laptop drive.
    I currently have a Seagate Momentus 5400.6 ST9320325AS drive, but the drive has started to experience some problems, less by most, the drive is just old and anyway I plan to replace the drive with one with better performance, the drive requirements are from 120 to 200 and as for capacity is not less than 250GB, I have read various threads about which disk to choose but opinions are divided and I do not know what to choose myself, so I would ask for specific help in choosing a better disk than the current one.
    ps. I also understand that maybe for this price I have nothing to expect, but I am asking for some suggestions
  • #3 16384163
    kokapetyl
    Help: 1787
    Rate: 2102
    djmixer7 wrote:
    the disk is just old
    Years and years, its technical condition counts, and this can only be assessed after analyzing its SMART.
    djmixer7 wrote:
    plans to change the drive to one with better performance
    Then you should be interested in SSDs, but the price will be a little higher.
    If this disk of yours is not damaged, then replacing it with another (HDD) "new" will have almost no effect.
  • Dropped drive stutters; considering a faster 320GB replacement
    #4 16384249
    djmixer7
    Well, as I have already written, there are some problems with the disc, I did not want to delve into it in short, the disc was dropped on the ground and it stutters since then, and after 2 I am going to replace it with something with a higher rotational speed, but what is specifically worth recommending I am interested in specific proposals, such as from michals22.
    And not something with smaller capacity better and better performance?
    a friend recommended something like this "
    http://allegro.pl/dysk-twardy-320gb-western-digital-scorpio-black-i6199862618.html
  • #5 16384351
    Kamerzysta
    Help: 6
    Rate: 36
    7,200 rpm and 5,400 rpm is a difference you'll notice with the naked eye. As new, I would take this disc, it is from the black series.
  • #6 16384360
    kokapetyl
    Help: 1787
    Rate: 2102
    It must be beyond the earthly "eye"
