[I am buying] I am looking to buy a power supply for the canon k30290 printer
avatar255 21086 9
  • #1 10737359
    avatar255
    Rate: 61
    I am looking to buy a Canon k30290 power supply.
    Input: 100V 89A
    Output: 24V 0.5A
    32V 0.85A
    Contact via PW.
    Contact the author of the topic by Private Message (PM icon).
  • #2 10741456
  • #3 10742706
    avatar255
    Rate: 61
    Canon PIXMA MP 520 The printer won't turn on. only turns on for a second after a long time of non-use.
  • #4 10743135
    endriuf
    Printers specialist
    Help: 621
    Rate: 1532
    This symptom occurs when the head makes a short circuit. Take it out and turn the printer back on.
  • #5 10743205
    avatar255
    Rate: 61
    I took out the heads and still won't turn on.
  • #6 10767106
    avatar255
    Rate: 61
    I unscrewed the printer, disconnected the display and the board from the control panel. I was able to turn it on, unfortunately I do not want to print a test page, i.e. it prints but as if the ink is running out. The printer has not been used for a long time, can the printhead be dry ??
    This is what the power supply looks like from the inside.
    I connected the black and red wires to the output plug, the red wire to pin 2 and the black wire to pin 1 and then to pin 3.
    On the display of the meter I got 7.5 with the settings and cables connected as in this photo
    Does it mean that the power supply is broken? The output on the housing is 24V and 32V ??
  • #7 10993176
    pokrzept
    did a colleague manage to solve the problem with the said power supply?
  • #8 11187562
    aldek51
    Rate: 14
    Buddy, avatar225, the inverter, i.e. the power supply is good. This is not a self-excited converter, so at idle it has an output voltage of 10.5V and 7.5V, but looking at your picture of the terminal block, it is counting from the left: pins 2 and 4 are ground. So between pin 2 or 4 and 1 you will have about 10v and between pin 2 or 4 and 3 it will be about 7.5v. only when you give the 5V voltage from another power supply to pin minus and pin 5, the converter will start working and pin 1 will be 33V and pin 3 -24V. From this a simple conclusion. You have damage in the printer. The protection is simply triggered, which blocks the power supply from firing.
    I have this device in the workshop, when I repair it, I will write what was the cause, because it also came with a damaged power supply :D
  • #9 11392737
    wanda29
    has the printer been repaired?
  • #10 16290709
    mariuszabczak
    I have a similar problem with the Canon Pixma ip4500 printer. In the free state, the first pin is 9.93 volts, which is correct, while the third pin is 6.5 volts should be 7.5.
    after connecting to the printer cube, the first pin has a difference of 10v, while on the third pin the voltage drops to 0.4 volts.
    after manual excitation and giving 5 volts to pin 5, the voltage on pin 1 increases to 32v, i.e. correctly, while only 21 volts on the third money, it should be 24v
    Could this make the printer refuse to start at all?
    Or rather, the power supply is ok and there is a problem with the printer board?
    It makes no difference if I take the head out ..
The discussion revolves around the search for a power supply for the Canon K30290 printer, with users sharing troubleshooting experiences related to power issues. One user reports that their Canon PIXMA MP 520 printer only powers on briefly after a long period of inactivity. Suggestions include checking for short circuits in the print head and verifying the power supply's output voltages. Users discuss measuring voltages at various pins of the power supply, noting discrepancies and potential issues with the printer's internal components. The conversation highlights the importance of proper voltage readings and the possibility of damage to the printer affecting power supply functionality.
