Opel Astra H – how to lock all doors with key if remote won't work?
paweltaki 65225 6
  • #1 10759412
    paweltaki
    Rate: 63
    Unfortunately, the remote control for the central locking has been damaged again and here is my question how can I emergency lock the door. Only the driver's door closes the key, the rest are unlocked. When I am in the car and I press the closing button, it closes all the doors, but when I get out, it opens all the doors (not only the driver's door). Thank you in advance for all suggestions.
    greet
    Paweltaki
  • #2 10759424
    Pawel wawa
    Help: 1262
    Rate: 4432
    Try through the back door. Close from the inside, then exit the rear ones and latch them. I don't know if it will be effective in your car. Repair of these locks will be 100% effective.
  • #3 10759622
    rob4028
    Help: 66
    Rate: 472
    On the inside of the door, next to the lock, you have a hole. Push the key there until you feel a "click". Slam the door. Do the same with the others.
    PS: manual !!!!!!!!
  • #4 10760083
    john1234
    Help: 42
    Rate: 90
    go to the car and close the door put the key into the ignition turn the ignition so that the lights come on press the key to close the door and hold for a moment while the locks should lock and unlock, then the remote control should work if the fault is more serious, close the door from the inside, leaving one open but the driver's door must be closed.
  • #6 10762957
    paweltaki
    Rate: 63
    thank you all for your help
    open the right passenger door, press the button to close the door inside the car located on the center console (then all doors are locked, including the open ones) we close the door and the car is closed.
    Regards
    Paweltaki
  • #7 19171787
    blumen77
    Rate: 12
    Hello. I had such a problem: the remote control in the "pocket knife" suddenly stopped working despite the efficient battery. The second spare was working normally. As if suddenly the car stopped recognizing the key for some reason. The method given by john1234 worked 100%. Thanks a lot. Regards.
The discussion revolves around issues with the remote control for the central locking system of an Opel Astra H, which has become non-functional. The user seeks advice on how to manually lock the doors. Various solutions are proposed, including using the back door to lock from the inside, utilizing a specific hole next to the lock, and a method involving the ignition key to reset the remote control functionality. The user later confirms a successful method of locking all doors by pressing the central locking button inside the car while closing the passenger door.
