Astra G - Central locking does not work with the remote control
StrayBullet 7794 4
  • #1 16769232
    StrayBullet
    Hello. I was combining today at the central castle because he walked as he wanted, and while driving the door opened and closed and the alarm turned on himself, I looked into the central computer, it turned out that the cables rolled up with my fingers disconnected, I soldered them, put them back and it turns out the central lock does not work with the remote control, if I put the keys in the door lock and turn it, all the doors open / close only with the remote control does not react, I admit that I could have confused the sockets into which I put soldered cables, I do not know if it could cause any short circuit etc. I was thinking about buying a new module, probably destroyed it; / Maybe someone knows how to synchronize such a module with the key, do I have to go to an electromechanic? Regards.
  • #2 16769366
    viper19861
    Help: 55
    Rate: 54
    You get into the car closing the door, turn the ignition key and press the close button. If the control panel and remote control are ok then the car should react by closing and opening the door.
  • #3 16769659
    ADAMO66
    Rate: 14
    Hello. At the beginning I would check the battery of the remote control if it has the correct voltage and whether the contacts are not tarnished, then program as a colleague described earlier.
    Regards.
  • #4 16769759
    StrayBullet
    I did all this but it didn't help
  • #5 16769781
    ADAMO66
    Rate: 14
    This must be connected to a computer
    Added after 20 [minutes]:
    Maybe it will help
    • 3797 Vauxhall Astra G.pdf (354.67 KB) You must be logged in to download this attachment.
