Alfa Romeo 147 - Remote control for the central locking alfa romeo 147
NapsterXD 7764 2
  • Remote button wear causes partial locking and trunk operation
    #1 16238375
    NapsterXD
    I have a problem with the remote from the central locking in alfie 147. I bought it not long ago and the owner said that it only opens with the key, I thought to change the batteries and it helped, but the door can only be closed or the trunk open, although you have to press very hard. However, the door still needs to be opened with the key ... What could be the reason for this? Can I unscrew the key without fear that it will unprogram it? Is it better not to touch it yourself?
  • #3 16239167
    KarizmoGSM
    Help: 95
    Rate: 292
    After all, it sends because from this gibberish I understood that "opens the trunk with the remote control"
    You have no idea, do not run, take it to someone who has a bit of knowledge, because the cost will be 3 times higher, first check if the body sees the door opening command, how is it not possible that only the buttons are made when it sees the trunk. Next is checking the locks!
    KariMax Paweł Kalkowski
    Kronikarska 8, Łódź, 92-624 | Company Website: www.cfiat.pl
