Accidentally Filled Diesel in Opel Astra F 1.6 16V (X16XEL) Gasoline Tank: Effects & Solutions
barfin22 66301 9
  • #1 5952117
    barfin22
    I am ashamed to admit it, but well ... returning home today I ran out of gas, so I called my friend, my friend came and I went with the bubble to the stations.
    As I was in a rush, by accident, instead of refueling with gasoline, I poured diesel.
    After pouring it into the tank, the firing attempt gave nothing. I "shook" it for a while longer and gave it up. That's when I thought that I might have made a mistake and went back to the station to make sure and it was indeed: /
    The car got home and now the question is, could it be bad for the engine? When I poured the tank it was completely empty and then I didn't even start it so maybe it won't be that bad ??
    Unlucky car is the Opel Astra F 1.6 16V (X16XEL)
    Regards
  • #2 5952125
    any56
    Help: 656
    Rate: 838
    How much did you pour it?
  • #3 5952132
    barfin22
    Fortunately, only for PLN 20.
  • #4 5952168
    kaczmarj
    Help: 43
    Rate: 76
    pour everything out - even from the fuel filter. Fill the diesel fuel and bleed the installation (pour crude oil fully into the fuel filter). There should not be any problems.
    Pour a lot of oil - if there is a residual gasoline, it will mix in a small proportion.
  • #5 5952236
    Pawel wawa
    Help: 1262
    Rate: 4423
    kaczmarj wrote:
    pour everything out - even from the fuel filter. Fill the diesel fuel and bleed the installation (pour oil fully into the fuel filter). There should not be any problems.
    Buddy, this is an asterka with a gasoline engine !!!!
    And to the author:
    Pour it out of the tank, replace the filters and off you go, you haven't damaged anything, you're lucky you didn't fill the diesel with petrol, then there are costs, and nothing happened to you.
    You can even be tempted to pour full petrol plus 0.5 denatured alcohol, it will also go, without draining, but I recommend replacing the filter.
  • #6 5952327
    mczapski
    Level 40  
    Help: 467
    Rate: 1656
    It's scary to comment. First of all, nothing terrible happened except to admire absent-mindedness or ignorance. But you might have a problem. Namely, only stupidity can I call the stubborn ride to the last drop. You've probably pulled out all the dirt from the tank that got stuck in the pump, filter and maybe the injectors. After cleaning the fuel system, it is basically enough to top up the gasoline and drive forward (if, for example, the fuel pump is still alive). And for the sake of formalities, you probably filled up with diesel, not diesel?
  • #7 5952369
    globus
    Help: 56
    Rate: 103
    A colleague of Mczapski is right, fill the gasoline up and go.
  • #8 5952954
    bartek_j
    Help: 255
    Rate: 816
    And if you want to empty everything from the tank, it is best to disconnect the fuel filter (the rear wheel wheel) and power the fuel pump. + 12V on the fuse, second from the left, supply or play with the key (after turning on the key, the pump is powered for a few seconds).
  • #9 5953211
    szakkkalll
    Help: 7
    Rate: 51
    do not overdo it, pouring diesel into a gasoline engine is nothing terrible, vice versa, yes. Fill up with gasoline, remove all spark plugs, and crank the starter a little to blow pus out of the hoses. Then screw in the candles, light up and enjoy the ride.
  • #10 5953238
    Hucul
    Help: 382
    Rate: 469
    mczapski wrote:
    ... Namely, only stupidity can I call the stubborn ride to the last drop. You probably got all the dirt out of the tank ...
    This fuel from the tank is taken from the surface or from the bottom :?: These legends about sucking all the dirt from the tank make me laugh as the fuel is constantly mixed while driving, and the pump takes the fuel right at the bottom. :D
    I suggest, like my colleagues above: drain diesel fuel, pour gasoline, drive a few kilometers and replace the fuel filter.
✨ The discussion revolves around a user who accidentally filled the diesel fuel into the gasoline tank of an Opel Astra F 1.6 16V (X16XEL). The user expressed concern about potential damage to the engine after realizing the mistake. Responses from other forum members suggested that since the tank was empty before filling, the risk of damage is minimal. Recommendations included draining the diesel from the tank and fuel filter, refilling with gasoline, and possibly replacing the fuel filter. Some users advised cranking the engine without spark plugs to clear out any residual diesel. Overall, the consensus is that with proper steps taken, the vehicle should be fine.
