Scania Irizar 2001 Bus: Semi-Automatic 8 Gears, 420hp - Odd Gears & Reverse Absent
maydayxxx 5855 3
  • #1 10901893
    maydayxxx
    Rate: 60
    Hello, I have a problem with the Scania IRIZAR 2001 bus, semi-automatic 8 gears 420 hp. Do I have even odd runs? 2 4 6 8 does not have odd and reverse or did anyone meet with a similar situation? I will add that when driving backwards I have RNR as if the selector was in a neutral position
  • #2 10909274
    koala5
    Rate: 59
    check the electrovalves on the pickup box
    3.1.13. It is forbidden to publish entries that violate the spelling rules of the Polish language, careless and incomprehensible. S.
  • #3 10909473
    maydayxxx
    Rate: 60
    ok, I went to the Scania site for a repaired problem. it turned out that the reason was the elbow from the air near the box, it damaged the new ones. The cost of the repair itself cost 130 zlotys, but of course you have to add 370 zlotys for the same entry into the review. Maybe someone will be useful someday. greetings
  • #4 10911293
    koala5
    Rate: 59
    well, but like the knee, you could hear the escaping air when choosing the odd gear when trying to repair
