Scania R730 2012 Gearbox Issue: GMS 14030 Fault Code and Reverse Gear Failure
casper1 4011 2
  • #1 20668669
    casper1
    Gear issue Scania R730 2012
    Fault code GMS 14030
    Won't go into reverse
    Any idea?
  • #2 20670640
    darfur5
    Help: 267
    Rate: 1715
    longitudinal movement backwards; no confirmation of completion of this move. One of the causes is a frayed wire or wiring harness to the acknowledgment sensor (on the back of the box). There may also be a faulty gear shift mechanism
  • #3 20672464
    saron22
    Trucks specialist
    Help: 308
    Rate: 1604
    Or a problem with the acknowledgment sensor itself. They too could be damaged.
