Samsung PS-42Q96HDX Plasma TV Chassis F30a: Picture & Sound Issues after 3-4 Minutes of Usage
yakomos 5208 2
  • #1 10980673
    yakomos
    Here is my problem: I have a Samsung Plasma TV type chassis PS42Q96HDX F30A. The problem is when you use it everything is perfect for 3 to 4 minutes and then more and more of his picture but you hear a small cli click click ..... I cut the area and I reconnected after 12 minutes and everything works again for 3 to 4 minutes. I looked in vain but is not the solution. Thank you for your help at all.
  • #2 11009166
    totalvoxel
    Yakomos, maybe your TV hasn't got a good flow of energy?
    You can tweak the stream of energy in settings, in your TV.
    Look at instructions!
  • #3 11190230
    Kytan666
    Check the power supply section, look for bulged caps, and dry joints. Check the ticking sound location.
    Post your findings
