Compatibility of Philips 22DC786/23 Radio and Philips 22SY686/23 Display in BMW 97 Model
Andrzej Ł 6872 4
  • #1 10982400
    Andrzej Ł
    Help: 27
    Rate: 106
    Well, the customer bought a BMW high-end vintage 97.
    In the middle of the inserted radio radio Philips 22DC786 / 23 / PH7860S3002061 / 65.12-8 360 750
    and the PHILIPS 22SY686 / 23 / 65.82-8 361 087 display.
    No connection cable.
    Are both segments dedicated to each other?
    On the Leszek website I found a description of the LCD connector, the radio has a different A connector, as in the description of PH7850 two rows of five pins. The description shows that the changer and other signals. All welcome info and a description of the wire to check both blocks (if they match) before I invest in the cable.
  • #2 14578723
    carradio
    I have a bmw car radio that is made of 2 parts, sadly I bought it like this, I'd need some cable to connect them or info how to connect and if possible also a pin configuration for the marked place on this picture (yellow mark) Compatibility of Philips 22DC786/23 Radio and Philips 22SY686/23 Display in BMW 97 Model Compatibility of Philips 22DC786/23 Radio and Philips 22SY686/23 Display in BMW 97 Model Compatibility of Philips 22DC786/23 Radio and Philips 22SY686/23 Display in BMW 97 Model
  • #3 14602741
    djlj24
    Car audio specialist
    Help: 1104
    Rate: 1327
    The 10 pin connector on the radio is only CDC audio input. LCD is connected using I-Bus (pin 7 on main connector).
  • #4 15638678
    sphinx1987
    Hello and I am asking if anyone can know what cable should connect both segments of the radio? Or where to get such a cable. I am already looking for six months and I can not find anything. Or though the schematic sequence of pins.
  • #5 15640642
    djlj24
    Help: 1104
    Rate: 1327
    It's worth reading sticky posts, there you can find the information you are looking for.
