Connecting Radio Scenic 98 CD to Display with ISO and Mini ISO Cubes: Conversion Guidance
person 22323 8
  • #1 8235726
    person
    Hi, I have a cassette radio in my scenic area recently bought such a radio CD
    The old cassette radio had 2 ISO cubes and one longitudinal one from the remote control + display. And the CD radio has 2 ISO cubes that match but the control and display are here on the mini ISO cubes.
    I found a schematic on the net how to convert it but first I would like to ask if such a rework will work.
    This is how the output of the cassette radio looks like
    and so after reworking (radio CD output)
    And my display looks like this
    stolarek_1988
    Help: 42
    Rate: 55
    The radio tuner list (the one you have) works with the AFFA2 + display
    you must check the type of display you have. I see that you have photos from studio24. After reading the type you will know if it is enough to replace the wires and the other cube or display should also be replaced
  • #3 8241749
    person
    I am glad that someone finally spoke, I will be doing the first change in the week and this photo is from studi24 and there is my showing shown with the symbol SAGEM AFFA2 + P7700428029 (Megane, Laguna) with watch / medium thermometer (only until 11.1999 )
    I will write how I will be after the first attempts thanks for the answer
    amator2
    Help: 5
    Rate: 32
    I also used the cable once, unfortunately it did not work. I had to exchange the display. AFFA2 ++ was needed. The new display looked identical, it had identical sockets. He differed only in the sign. The old pilot was working properly.
    Slawek
    • Connecting Radio Scenic 98 CD to Display with ISO and Mini ISO Cubes: Conversion Guidance wymiana_LCD.jpg (58.48 KB) You must be logged in to download this attachment.
  • #5 8242671
    person
    And tell me because this AFFA2 ++ display has 2 red and gray outputs or one big red one ??
    amator2
    Help: 5
    Rate: 32
    I had a model with identical sockets, as I wrote earlier. I also had a model with one big red connector, which also works after a small mechanical processing of plugs. There is also a model for the newer line "Update list", but the socket for connecting the wires is completely different and it works only with newer receivers (mostly with models with an aluminum heatsink instead of copper).
    UPDATE:
    List of displays that I have personally checked:
    RADIOSAT display: AFFA2 + 21648755-7 P7700428029 (1999)
    TUNER LIST display: AFFA 2 ++ 21656217-8A (2000)
    UPDATE LIST display: AFFA2 21677127-2 8200380298 --A (2005)
    TUNER LIST display: AFFA + 21656209-5 P7700436307 A (2000) checked!
    Apparently, the position of the plus AFFA2 is very important, with or without a space.
    The display for TUNER LIST has a connector for the pilot more orange than the display for RADIOSAT. The UPDATE LIST display has one black, double-row 24 pin connector.
    I have not heard that there is one universal display and it is not a matter of changing the data in the eeprom memory.
    However, knowing Renault engineers is probably a million other markings, models and housings that fit or not ....
    Maybe I helped a little bit?
    Slawek
  • #7 8242944
    person
    The power cube and speaker cube is the same as the standard. I go driving in a circle can find a display
    Nawigator
    Help: 167
    Rate: 160
    TunerList does not work with AFFA + rather.
    https://www.elektroda.pl/rtvforum/topic1702453.html
    The display from the photo is Radiosat.
    The TunerList display can be seen even without the power supply under the inscription TunerList.
    N.
  • #9 8257886
    person
    Hello, thank you for your help, the AFFA2 + screen has been solved and everything is going well
The discussion revolves around connecting a Radio Scenic 98 CD to a display using ISO and Mini ISO cubes. The user initially inquired about the compatibility of their new CD radio with the existing display and control system, which utilized two ISO cubes and a longitudinal connector from a cassette radio. Responses highlighted the importance of verifying the display type, specifically the SAGEM AFFA2 + P7700428029 model, and the necessity of potentially replacing the display to ensure compatibility. Users shared experiences indicating that the AFFA2 ++ display was required for successful operation, with some noting that identical-looking displays could have different connectors. A list of compatible display models was provided, emphasizing the significance of connector types and configurations. Ultimately, the user confirmed successful integration after resolving the display issue.
