Excel 2007: Sum Not Updating When Changing Values – Manual Calculation Mode Issue
s_90 70132 6
  • #1 11033122
    s_90
    Hello - could you please help me? I have a problem with Excel 2007, well: I enter numerical values into Excel - it gives a summation (sums me up) but when I change the values or add another, it does not change the previously calculated value, i.e. it remains as it was -> for example, it enters: 2 2 2 2 2 - -> excel calculates that it is 10 ---> I change now to 2 3 2 2 2 -> and exscel instead of changing the value to 11, it has 10
    if I make a new excel file, it is fine and everything changes - but I can't convert to another file because I have had this one for 5 years and I have everything in it there. How to fix it ?
  • #2 11033161
    bmserwis
    Level 36  
    Help: 262
    Rate: 201
    Upload said file.
  • #3 11033229
    s_90
    Unable to put .xcls file -> I can send to e-mail
  • #4 11033951
    adamas_nt
    Help: 1508
    Rate: 659
    But packed (RAR, ZIP) it is possible.
  • #5 11038753
    Antidotum ex
    Try to select the whole area you are adding up, then right click and select Format Cells / Numbers / Numeric and OK - it should help.
    kisses
  • #6 11039071
    marek003
    Level 40  
    Help: 801
    Rate: 488
    Or maybe you have automatic recalculation turned off.
    Change the number and press F9
    If it recalculates, check the options automatically instead of manual recalculation.
    [in 2010 tab file / options / formulas block "calculation options"]
  • #7 14515060
    nasa-photon
    Rate: 12
    you can edit the cell value and confirm with enter ... then it obtains the general format ...
The discussion revolves around an issue in Excel 2007 where the sum of numerical values does not update when changes are made to the input values. The user reports that while the sum calculates correctly initially, it remains static despite modifications. Suggestions from other users include checking if automatic recalculation is disabled, using the F9 key to force a recalculation, and ensuring the cell format is set to numeric. There are also recommendations to upload the file for further assistance, although the user expresses difficulty in sharing the file directly.
