MAN TGA Truck EDC Errors 03776-01 & 03779-10: Seeking Error Code Meanings and Solutions
t3chn0b0y 89133 10
  • #1 11040537
    t3chn0b0y
    Hello everyone, I drive MANEM TGA and I have a problem for some time, because 2 errors pop up:
    EDC 03776-01
    EDC 03779-10
    Please, give me the meaning of these errors, or send me an error book by e-mail:
    sfbot111(_at_)o2.pl
    I've already searched the entire internet and found nothing specific so please help.
    I have read the error books from MAN TGA, but I have not found any mistakes in them.
  • #2 11040573
    serwis_gh
    Diesel injection systems specialist
    Help: 211
    Rate: 1235
    Laziness to the power of N
    It was several times!
    And not only on the elce!
    By the way, you can not fix the problems with a chisel and hammer.
  • #3 11040587
    t3chn0b0y
    Maybe even links to these topics?
    Because I am looking for and lack of effects, nothing specific.
  • #5 11040928
    t3chn0b0y
    All topics you have given are only similar,
    These errors pop up when e.g. it's going uphill and it's hard
    and they wrote that they are jumping out of these errors on low revolutions, here is the opposite.
    Added after 10 [minutes]: < br />
     Did I read somewhere on the internet that error EDC 03776-01 is responsible for too low pressure on the rail? What is this rail?
  • #6 11041180
    saron22
    Trucks specialist
    Help: 308
    Rate: 1601
    t3chn0b0y wrote:
    Did I read somewhere on the internet that EDC 03776-01 error is responsible for too low pressure on the bus? What is this rail?
    Asking this question you show that you do not have elementary knowledge about the Common Rail system. Put the car to the mechanic because you can not fix the car's internet. And replacing elements "one by one" can cost you very dearly.
  • #7 11047140
    filarek
    Rate: 10
    do engine tests, most likely you have a problem with any of the injections and therefore you can not keep the pressure in the common rail. Of course, the reasons may be quite different, but the most likely is a damaged injection
  • #8 11052413
    diablo23248
    Help: 102
    Rate: 613
    First:
    When you pick up the cab, on the left side of the engine you have a box with large black plugs. This is an EDC computer. Disconnect the plugs (of course, the battery disconnected) and see if there is no oil in them. It happens that oil gets into the computer through the injection beam.
    Secondly:
    If you have traveled about 500,000 km, it is worth to be interested in injections just as your colleagues advise. In my company there were over 50 TGAs and as in the clock in this area there was a problem with injections.
    I will send you a code book immediately by e-mail.
    Ps. Remember the option "helped" if my information proves useful :)
  • #9 11059139
    Robert0806
    Rate: 39
    Colleagues, "I think," which borders on, are certainly in the right injection or injections.
    This is particularly indicated by the typical error in the leaking injection of SPN3779 FMI 10 or can be FMI 1. this error is a leak due to the amount equalization at the D20 engine limiting 130-150mg / stroke. And what are the symptoms except that it displays these errors to you? (This is for the posterity) Of course, there are no certainties at the distance, because the SPN 3776 may show a pressure sensor. The fuel rail has flawed or shaky contacts. it's best to connect to MAN-cats :) Well, I'm just as revealing as 90% of writers :(
  • #10 11504278
    piotr3310
    Rate: 20
    umnia inches edc 03776 listed dbv injections and valve in the head did not help what to do next ... ??
  • #11 11615191
    dosia780704
    Rate: 15
    Hello, for me, the service in Mania TGA 26.440 from 2008 checked the pump, it was ok, it turned out that it was a sensor on the injection molding.
✨ The discussion revolves around EDC error codes 03776-01 and 03779-10 encountered in MAN TGA trucks. Users seek clarification on the meanings of these errors and potential solutions. Error 03776-01 is suggested to relate to low pressure in the common rail system, while 03779-10 may indicate issues with fuel injection. Recommendations include checking the EDC computer for oil contamination, inspecting fuel injectors, and performing engine tests to identify faulty components. Users emphasize the importance of professional diagnostics rather than trial-and-error repairs.
