Understanding Error Codes edc 5 03044-03 & scr 5 05556-10 in MAN TGX EUR 6 Truck
Jan Gora 25593 5
  • #1 17616620
    Jan Gora
    Hello, who can tell me what they mean?
  • #2 17617692
    darfur5
    Help: 267
    Rate: 1715
    3044-03; EGR position, signal inconsistent. SCR 5556-10; return line blocked.
  • #3 17618204
    Jan Gora
    Thank you, can you tell me what to do with this problem, how to fix it
  • #4 17618255
    darfur5
    Help: 267
    Rate: 1715
    You will not do it on the road. You need to check the proper operation of the EGR throttle and its wiring, replace the return line in AdBlue with one with a larger diameter and check the operation of this system.
  • #5 17618659
    Jan Gora
    EGR, I know where it is and this return pipe I do not know, you will tell me where to look for it, and whether cleaning alone would help
  • #6 17626942
    kakibara
    Help: 202
    Rate: 1284
    Return line from the adblue pump to the tank - it is possible that "cleaning" will help him.
    Do you have access to a computer? Because you need to check the damper actuation, its movement, etc.
    Ps for now, do not buy the flaps blind because you will fall slightly in price.
