Excel File Locked for Editing by 'Another User': Overcoming Network Name Recognition Issue
wicy 21455 4
  • #1 11050715
    wicy
    Help: 30
    Rate: 111
    When opening an excel file on the network, I get the message: the .xls file is locked for editing by the user "another user".
    The problem is that excel gives as "another user" my network name. Even though I don't have any programs running, I blocked xls myself?
    The file cannot be overwritten or deleted from the network. I can't edit and save it. How to deal with the problem?
  • #2 11050754
    whyki
    Help: 38
    Rate: 59
    Make sure you have write permission to the drive where the file is located. These symptoms are like the disk is read-only.
  • #3 11050760
    wicy
    Help: 30
    Rate: 111
    I have permissions because I created this file myself. I can use "save as" to save the file under a different name. I can't replace these files afterwards.
    However, I do not have any administrative rights.
  • #4 11050790
    whyki
    Help: 38
    Rate: 59
    but by entering a given location you can delete the file through explorer? Can you create files but not delete anymore?
    Added after 29 [seconds]:
    write what operating system
  • #5 11050806
    wicy
    Help: 30
    Rate: 111
    On a network location I can save and delete (e.g. create another txt file and delete it), I can open a file and save it. I can't open for editing (because I can open only for reading) only this one xls because I have it locked by myself.
    Added after 14 [minutes]:
    Thanks for your interest, problem solved.
    The "other user" is actually a different user, although the info window lists my login as the person using the file.
    Some glitch I guess...
    I didn't realize that ".xls file is locked for editing by user "xx" should be read not as locked by "xx" but locked for "xx" :D
